Old 11-27-2012, 12:57 PM   #21
jfoj
My Ride: 330CiC, M5, X5, E93
Full jfoj treatment!! Most of what you likely need.
ID:	479874   Click image for larger version
Name:	E46 Lower Intake Boot.jpg
ID:	479875   Click image for larger version
Name:	E46 Upper Intake Boot.jpg
ID:	479876   Click image for larger version
Name:	DISA O-ring.jpg
Name:	SAP Vacuum Hose.jpg
ID:	479878   Click image for larger version
Name:	E46 Fuel Filter.jpg
ID:	479879   Click image for larger version
Name:	E46 Valve Cover Gasket.jpg
ID:	479880   Click image for larger version
Old 11-27-2012, 01:24 PM   #22
My Ride: Lexus
http://realoem.com/bmw/showparts.do?...51&hg=12&fg=05
The Bosch FGR7DQP aka "Platinum +4" 4-prong plug or NGK BKR6EQUP 4-prong plug is spec'd for the 330i (and probably 325 as well--didn't check)
And I agree on the full JFOJ treatment--replace it all otherwise all that rubber is just prone to leaking and cracking.
Don't forget the IAT o-ring and the vacuum canister controlling the exhaust flap.
Old 11-27-2012, 02:02 PM   #23
boostedisbetter
boostedisbetter's Avatar
My Ride: 2008 S2000, 2009 CBR
I've done both boots, DISA repair and o-ring... Have the sparks and VCG in my closet(been there for 4 months ) think my fuel filter and ccv is next
Awesome info as always!
Mango, IAT o ring and vac canister??
Originally Posted by Green_Shine View Post
(2/14/2017)Trump, by definition is a nitwit. He has every opportunity to make sound decisions, and he is incapable. I can't see this guy lasting 4 years without resigning or being impeached.
boostedisbetter is offline   Reply With Quote
Old 11-27-2012, 02:10 PM   #24
My Ride: Lexus
Yes. For starters. Theres multiple potential areas for vacuum leaks. Those are just two of them. Next to the line that feeds the vacuum canister is another port blocked off by a rubber cap. That rubber cap is completely rotted on all E46s and can cause a vacuum leak.
Old 11-27-2012, 02:14 PM   #25
boostedisbetter
So this never worked out? : http://forum.e46fanatics.com/showthread.php?t=948243
What is the IAT though?
Old 11-27-2012, 02:19 PM   #26
My Ride: Lexus
Yeah it worked out. I just left the canister there for next time I'm down there. But it's disconnected.
The IAT is the intake air temp sensor. it sits on top of the manifold. remove the fuel rail cover, unplug the sensor, and simply pull up on the sensor itself. it pops out. the seal there can cause a vacuum leak.
BMW part#13621743299
Edit: 15 and 16 are the parts/ports I was talking about. Cap them.
(some of these people that are angry at me will take advantage of this and use this information--fine by me, but they should stop giving me a hard time since i'm giving them lots of tips and pointers)
Old 11-27-2012, 02:35 PM   #27
boostedisbetter
OOOO mango, you know they really love ya! haha, such a burden to be so well informed isn't it
The IAT is #3 ?
Thanks man, I'll check out those vac lines.
Old 11-27-2012, 03:14 PM   #28
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
Tampa, if replacing IAT, be sure to blow around it before you remove it. Years of dust will have formed a small pile of dirt around it...try to avoid it dropping into intake mani if you can...compressed air would be perfect...if not, small probe and a vacuum cleaner.
Might as well get another iat o-ring for your temp sensor on lower cooling hose.
Facebook.com/DMAXstandup
Mangofy your E46!
Old 11-27-2012, 03:38 PM   #29
boostedisbetter
Cool, I have a compressor so that will work. So the #4 IAT o-ring is the same part number for that lower cooling hose o-ring?
edit: nevermind, found my answer http://www.bimmerfest.com/forums/sho...d.php?t=409007
Haven't done my coolant overhaul yet, that's going to happen with my CCV and VCG install, all at once. Parts are piling up
Old 12-17-2012, 02:16 PM   #30
ELCID86
My Ride: 2004 330i (ZHP) x2
My 20 YO just called and ask if I had done anything to his car??-- "no why?" His response: "I put the new gas cap on and the Service Engine light went out!" -Yeah. I hope it was that easy... hanging on to the new oil separator to dipstick tube, DISA & dip stick O-rings just in case.
ELCID86 is offline   Reply With Quote
p0171, p0174
