Old 11-26-2012, 09:21 PM   #1
t.bird
My Ride: '04 330i ZHP
Oil leak in center of valve cover
My engine is leaking a bit of oil onto the exhaust. It looks to be coming from the center 4 bolts on the valve cover. I replaced the gasket a few months ago, no leak then...just doing some routine maintenance. Now some oil is pooling up in the center, around the ignition coil necks, it then runs off onto the exhaust. I replaced the rubber grommets when I did the VCG, am I missing something here? Should I try another new set of grommets?
t.bird is offline   Reply With Quote
Old 11-27-2012, 09:07 AM   #2
figjam911
My Ride: 1999-323i
Same problem with me!
1999-323i Steel Grey, black leather, CD stacker, tinted windows, reversing radar, sunroof and Pirellis on M-Sport 17" alloys, 245 mm wide on rear and 225 mm wide on front.
Colin Boucher
figjam911 is offline   Reply With Quote
Old 11-27-2012, 09:12 AM   #3
SeanC
My Ride: 330i
You should try another brand VCG if you used a Victor Reinz.
Black Sapphire MetallicNatural BrownSilver Cube e46 330i ZHP/6MT - Sold
HellrotDove Grey e36///M3 - RIP
Black Sapphire MetallicNevada BrownDark Bamboo e70 X5 xDrive4.8
Alpine WhiteCoral RedAluminum f30 328i Sportline/6MT
Imola RedBlackBlack Aluminum e46 330i ZHP/6MT
SeanC is offline   Reply With Quote
