Australia
Old 11-26-2012, 11:00 PM   #1
Mallee
My Ride: 2002 E46 M3
Aircon re-gas/service
My aircon is blowing hot air on the drivers side.
I suspect this means I need to re-gas, and probably replace one of the hoses to kill an (as yet) undiagnosed leak, I've tried to call Worx but I'm not getting an answer, any one recommend a good Air con place?
I've had enough of Melbourne BMW on kings way.
Mallee is offline   Reply With Quote
Old 11-26-2012, 11:27 PM   #2
fgin
My Ride: e46 facelift
Is it cooling as it should on the passenger vent ?
fgin is offline   Reply With Quote
Old 11-26-2012, 11:39 PM   #3
Mallee
Not as much as it should, but yes it is cooler on the passenger side vent.
Old 11-27-2012, 12:28 AM   #4
fgin
if it needs re-gassing then that should mean there is a leak as its a closed system. So you might need to get them to find the leak and fix it.
Old 11-27-2012, 12:34 AM   #5
gueste46
Banned User
You may need to regas (gas can include a dye visible under ultra violet light) in order for them to find the leak. They will gas and then check it again in a couple of weeks to try and see where the leak is. They can then repair the problem and may need to regas again.
gueste46 is offline   Reply With Quote
Old 11-27-2012, 02:56 AM   #6
Ballistic325
My Ride: slow and steady
Exactamundo.
Heaps of threads in the General section about this issue - sometimes it is a simple re-gas and fix the leak, other times it can be more than that (bad valves and other hardware).
As fgin said, it's a closed system and therefore definitely a leak somewhere.
Good luck!
I can help with
* Reading Codes / Coding your car
* R&R FCAs, Tie Rods, Sway links....
* RTABs
Need an RTAB tool? Or clutch fan and water pump tools? PM me.
Ballistic325 is offline   Reply With Quote
Old 11-30-2012, 12:01 AM   #7
Mallee
Good luck!
Apparently a 40-50ml gas loss per year is considered acceptable/normal, or so I've been told by the air con people I've called.
I'm not going to fix a problem that is "normal" operation, that said I'm also not going to leave a problem unattended.
