Sponsored by BimmerWorld
Old 11-27-2012, 09:32 AM   #1
328isawesome
My Ride: Batmobile
Brake Master Cylinder Leaking... DSC On
When recently acquiring my current e46 the DSC light was on, it was one of those turn the car on and it turns on in a few seconds. Thought an alignment would fix it so planned on getting it done when it needed new tires. Now after I replaced all pads and rotors in the car I noticed that behind the pedal in the car there is brake fluid slowly leaking, after that in the drive way the car's brakes vibrated when slowly braking and now whenever the battery is connected some pump in the master cylinder (I believe) keeps working to the point that it drained my battery. I've read up on it and apparently the DSC system also detects when the pressure isn't right in the master cylinder so this might have been the DSC problem. Anywhoo, going to replace the master cylinder and check all relays and fuses. Any input is appreciated. Thanks!
Daily: Honda Fit EX 6-MT
PITA: 330i e90 6-MT
Past: 328i e36, 323i e46 Both Automatics
328isawesome is offline   Reply With Quote
Old 11-29-2012, 01:52 PM   #2
328isawesome
My Ride: Batmobile
Seriously, nobody has any input?
PITA: 330i e90 6-MT
Old 11-29-2012, 02:25 PM   #3
NC BMW fan
My Ride: 2003 325I
Sounds to me like a couple of things. 1) you have a leak in the master cylinder of some kind. It's troubling that you have brake fluid inside the car. That means its leaking into the brake booster, than into the car (see thread about brake booster).
2) there is no electrical connection to the master cylinder. That sounds like maybe an ABS module will not stop cycling.
Are you driving the car now? Do you have consistent firm pedal feel? The DSC light will come on if there is air in the system. leak=air.
I have a master cylinder if you are interested. $50. PM me, I'll send pics if you're interested.
NC BMW fan is offline   Reply With Quote
abs, brakes, dsc, master cylinder
