Old 11-29-2012, 02:48 PM   #1
muppit
My Ride: fred flitstones car
hi everyone
new to bmw,s but been well impressed with me new/old purchase have got a 2001 325 i es an absolute dream to drive aswell full service history ..... ok its done 165k but wouldnt think so , even the leather has been well looked after ............. now have a niggle when the side lights are turned on the indicator lights up aswell but goes off when headlights turned on ............... im assuming its an earth problem ?? but never owned one of these before after a bit of info on where earth would be ........ i take it headlight has to come out ??
cheers for any help guys
muppit is offline   Reply With Quote
Old 11-29-2012, 03:31 PM   #2
FenderGuy05
My Ride: 2002 BMW 325i
what exactly is a niggle? I'm trying to figure out what the symptoms are but can't descern more then my lights cause a problem. And by earth do you mean electical ground?
FenderGuy05 is offline   Reply With Quote
Old 11-29-2012, 04:07 PM   #3
muppit
yes my friend earth/ground .................... when side lights are on so is the driverside indicator bulb does that make sence
Old 11-29-2012, 04:21 PM   #4
///MPR77
My Ride: 02 ///M3 Tri-Ped
Welcome,
Just to clarify; When your running lights are on, you get a "bulb out" idicator on the dash?
Where is the indicator with relationship to the car diagram that lights up?
More Info!
If the rear error lights indicate, it can mean two things:
Brake Light Unit (bulb/s bad)
or
License Plate light/s is bad
or Tail light Ground pin is fouled, which happened to me on a 2001 325i i used to own.
If the front error light indicates
It can be Front turn signals
or
Headlights
If it is happening in the front and turning the headlights on corrects it "light goes away" then it could possibly be a problem with your ballast, if you have Xenons.
