Old 12-05-2012, 09:10 AM   #21
E462005
My Ride: 2005 325
Maybe I should just get the actual fan clutch tool off eBay-__- this is going to be a headache
E462005 is offline   Reply With Quote
Old 12-05-2012, 09:13 AM   #22
BimmersGarage
My Ride: E46 330i
Originally Posted by E462005 View Post
I'm just trying to get this job done this weekend I'm buying all my parts tomorrow and all I'm missing is the wrench. I'm scared something will break while driving if I keep putting this off. I've had this noise going on for 2 weeks now.
The procedure is fairly basic. The only thing that concerns most first time DIY-ers is the tightness of the WP nut and the lack of space to work within (initially...)
Watch my vid to get an idea of what to expect -
BimmersGarage is offline   Reply With Quote
Old 12-05-2012, 09:15 AM   #23
WDE46
My Ride: '13 128i, '04 330Ci
I ordered this off Amazon yesterday:
http://www.amazon.com/gp/product/B00...ls_o01_s00_i00
I figure $30 isn't much to do the job right. I'll at least get 2-3 uses out of it anyway.
That's a ton of room to work with compared with some other projects. The steering guibo comes to mind as my most cramped project so far. It's only rivaled by the driver side control arm inner ball joint nut.
Old 12-05-2012, 09:23 AM   #24
BimmersGarage
My Ride: E46 330i
I'd argue and say the A/C FSR replacement is the back bender so far. But, I may change my mind when I eventually do the steering guibo...
Old 12-05-2012, 09:30 AM   #25
WDE46
That was another shitty one. You can't really get a good position to hold yourself up so you just end up getting a back cramp. Also there is the lower intake boot hose clamps that are impossible to get to. I failed to reach mine when I tried to remove it. I think I'm gonna buy new clamps and cut the old ones off. The current position is ridiculous.
Old 12-05-2012, 10:03 AM   #26
E462005
My Ride: 2005 325
I know exactly what you mean. It was a pain but I eventually got it and turned it around so its easier to remove for next time.
Old 12-05-2012, 10:04 AM   #27
E462005
My Ride: 2005 325
[QUOTE=WDE46;14952975]I ordered this off Amazon yesterday:
Yea I seen them on eBay as well.
Old 12-05-2012, 10:14 AM   #28
E462005
My Ride: 2005 325
So all I need is the 32mm wrench and something to hold the WP?
Old 12-05-2012, 10:27 AM   #29
WDE46
Correct.
Also, I should point out the button to the right of the "quote" button. You can click that on multiple replies to quote multiple things in one reply. I just discovered it last week. It's awesome.
Old 12-05-2012, 10:53 AM   #30
BimmersGarage
My Ride: E46 330i
Technically.. Yes, that's really it. So, if you have a thin/flat enough 32mm wrench and "something" to prevent the WP from spinning, you're good to go. Once you use that special tool once, you'll get the idea of what needs to be done.
I just don't recommend whacking the wrench (Ever) to loosen the Fan clutch nut. But to each their own.
What took you so long to figure that out?
Old 12-05-2012, 11:08 AM   #31
E462005
My Ride: 2005 325
[QUOTE=BimmersGarage;14953207]Technically.. Yes, that's really it. So, if you have a thin/flat enough 32mm wrench and "something" to prevent the WP from spinning, you're good to go. Once you use that special tool once, you'll get the idea of what needs to be done.
Ok so I got myself a borrowed 32mm wrench. Now Im told that a thick, not to thick tho, long screw driver and I can hold the WP in place with that correct?
Old 12-05-2012, 11:58 AM   #32
BimmersGarage
My Ride: E46 330i
You can.
All you're trying to do now is to prevent the waterpump pulley from turning while you unscrew the fan clutch nut... so whatever you find that can do that should work.
Old 12-05-2012, 12:00 PM   #33
E462005
My Ride: 2005 325
You can.
Alright thks. I'll be taking pictures hopefully of the work.
Old 12-05-2012, 12:06 PM   #34
wildirish317
My Ride: 2004 325Ci vert
Damn that just made my day-__- I bought the car with 105,000 miles. It's at 114k now.
Welcome to the world of owning a used E46. If you don't know the service history when purchased, plan on spending up to $2,000 the first year of ownership just to take care of the critical maintenance items so you can drive worry free. Once you get past that, your maintenance costs will fall off dramatically.
“The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed.”
Originally Posted by Mike Miller
I just don't know what I'd do with 560 hp that doesn't involve getting arrested.
wildirish317 is offline   Reply With Quote
Old 12-05-2012, 12:30 PM   #35
E462005
My Ride: 2005 325
Yep I know I will be spending that
Old 12-05-2012, 12:38 PM   #36
WDE46
I have no idea really. I have been an active forum member on probably 25-30 forums using vBulletin over the years and I never noticed it. I guess I never needed it until now. Most of my other forums were for gaming or CAD stuff, so I was usually only addressing one person at a time.
Old 12-05-2012, 01:05 PM   #37
wildirish317
This was news to me too. Watch out people, I'm now EDUCATED!!
Thanks guys.
Old 12-05-2012, 01:44 PM   #38
FenderGuy05
My Ride: 2002 BMW 325i
+1
First year of ownership I probably spent around 1500 dollars, with one big job left (suspension) and after that, just regular maintainance cost.
FenderGuy05 is offline   Reply With Quote
Old 12-05-2012, 01:49 PM   #39
tks
My Ride: slower than yours
What's the mallet for? -_-
WTB:: Natural Brown Sedan Full Interior
tks is offline   Reply With Quote
Old 12-05-2012, 02:53 PM   #40
WDE46
Hitting the wrench and shocking the nut free as opposed to holding the WP pulley and smoothly breaking the nut free.
