Old 12-05-2012, 03:13 PM   #41
BimmersGarage
My Ride: E46 330i
Yes, it shocks the nut free... Along with shocking the waterpump's bearing&seal which can lead to it failing prematurely.
Just a heads up.
BimmersGarage is offline   Reply With Quote
Old 12-05-2012, 03:45 PM   #42
WDE46
My Ride: '13 128i, '04 330Ci
Originally Posted by FenderGuy05 View Post
+1
First year of ownership I probably spent around 1500 dollars, with one big job left (suspension) and after that, just regular maintainance cost.
I think I have spent almost $2000 including tools. Parts cost not too bad though. I love buying tools hahaha. It's like a woman being obsessed with handbags except my handbag lasts 30 years and you can beat someone to death with it and fix ****.
Old 12-05-2012, 04:00 PM   #43
lcoleman
My Ride: '79 Massey Ferguson
...or a 5/8" works fine as well.
I find this surprising, considering the source.
I don't know why someone would be afraid to "whack" the wrench to get the fan off. It's much easier, fast, and safer for your knuckles.
Old 12-05-2012, 05:37 PM   #44
klax
My Ride: '04 325i
Just a note regarding the Torx bit to get the tensioner loose: Some of those bolts use either a Torx bit or an Allen bit, depends on the car. I think newer cars and all replacement bolts have the Allen (8mm I think?). When I replaced the tensioner bolt recently the replacement (from BMW) was an Allen.
klax is offline   Reply With Quote
Old 12-05-2012, 06:00 PM   #45
//Maxwelljuppercut
My Ride: e46
you do not have to remove the fan to do the belts. put the belt down between 2 of the fan blades, hold the belt with one hand and spin the fan with the other. after you make it all the way around once it will be off. repeat in reverse order to put it on.
//Maxwelljuppercut is offline   Reply With Quote
Old 12-05-2012, 06:56 PM   #46
WDE46
It will stress the already weak water pump bearing.
Very clever
Old 12-05-2012, 07:09 PM   #47
lcoleman
...the lateral load from the tension of the belt on the pulley is in all likelihood greater than what miniscule force is applied tapping the fan off. Have you ever done one with a hammer? It's easy, and much better than risking a bent a screwdriver (which generally requires a lot more force). I have done both, and will never try to "pry" one off again.
Old 12-06-2012, 08:57 AM   #48
E462005
My Ride: 2005 325
So are these the right parts. Idler pulley and belt tensioner?
ID:	481134   Click image for larger version
E462005 is offline   Reply With Quote
Old 12-06-2012, 09:00 AM   #49
E462005
My Ride: 2005 325
So is their like a visual picture or video of this?
Old 12-06-2012, 10:24 AM   #50
BimmersGarage
My Ride: E46 330i
Looks correct.
If you're just replacing the belt...
Really no need for a pic/vid. Just loosen the tensioner and slip the serpentine belt off, let it dangle from the waterpump and follow his simple step below >
Old 12-06-2012, 11:01 AM   #51
WDE46
Physics says otherwise. The screwdriver method won't send a shock down to the WP shaft. The force applied will be smaller for a longer duration. The hammer method will apply a surprisingly large force for a very short time. If you want to do it that way, you'll probably be fine, but I just don't like wacking things unless I know they're sturdy (control arms). To me it's not worth the risk of either damaging the WP or screwing up and causing collateral damage to other parts I don't have lying around.
Old 12-06-2012, 11:44 AM   #52
EDWAGON
My Ride: 2004 325xiT
Maybe I should just get the actual fan clutch tool off eBay-__- this is going to be a headache
I just bought the set off ebay , I could not for the life of me figure out where to place pulley holding tool without removing hoses , etc. I ended up using long screwdriver to hold wp pulley while using 32 mm wrench. ( just put in new fan, clutch and shroud).
EDWAGON is offline   Reply With Quote
Old 12-06-2012, 12:03 PM   #53
WDE46
That's unfortunate. When I do mine maybe I'll make a post on it if I can figure it out.
Old 12-06-2012, 01:15 PM   #54
E462005
My Ride: 2005 325
Well I should be getting this job done tomorrow. Lets make this awful noise go away!
Btw that's my baby
Old 12-06-2012, 05:13 PM   #55
//Maxwelljuppercut
My Ride: e46
i can make a video if you want.
Old 12-07-2012, 01:45 PM   #56
E462005
My Ride: 2005 325
No it's cool Thks for offering tho
Old 12-07-2012, 01:49 PM   #57
E462005
My Ride: 2005 325
Alright belts have been changed. Belts were bad. The only pulley I changed was the idler pulley. My power steering was leaking from the top and apparently fell into the idler pulley and ruined it. That's what it looked like to me. But the rest of pulleys and tensioners were good. And the fan did NOT have to be moved out the way! Did it from working on top and from the bottom! Easy job tho!
Btw that's the smaller belt. The bigger was cracked really bad.
Old 12-07-2012, 03:30 PM   #58
BimmersGarage
My Ride: E46 330i
Did you spin the tensioner pulley when you had the main belt off? Was it free spinning??
Old 12-07-2012, 04:01 PM   #59
E462005
My Ride: 2005 325
Yes it was
Old 12-07-2012, 04:05 PM   #60
E462005
My Ride: 2005 325
They didn't rattle and were not wobbly at all
