Sponsored by BAVSOUND
Old 11-27-2012, 04:11 PM   #1
miweber929
My Ride: 02 330xi
Replacing the head unit in my 02 xi w/HK
I am finding some conflicting infomation and need to know what I need to do to hook all this stuff up.
My head unit in my 02 330xi sucks and I want to add iPod, bluetooth and I need HD radio for my work (to monitor our HD stations on air). So I bought a Kenwood KDC-x896 head unit, dash kit, wiring harness, Axxess steering control unit and PAC speaker level to line level conrtoller, all from Crutchfield. What I need to know is:
- Do I need the line level converter for the amp? Most factory amps in my experience are speaker level in as otherwise you need different wiring. If so where do I install it, at the amp or in the dash? Where do I find an amp wiring diagram if that is where I should install it?
- Are there any gotchas in the dash I need to know about before wiring this stuff up? Looks pretty straight forward, but I haven't found much info.
- Anything else I need to know?
Thanks!
Mike
miweber929 is offline   Reply With Quote
Old 11-27-2012, 05:28 PM   #2
markusmarkus
My Ride: 2001 330Ci
The oem audio system uses balanced signals between the head unit and the amp.
"What is Balanced Audio?
Balanced audio is a method of minimizing unwanted noise from interference in audio cables. The idea is that any interference picked up in a balanced cable is eliminated at the point where the cable plugs into a sound mixer or other equipment.
Balanced audio works on the principle that two identical signals which are opposite polarities (often erroneously called "out of phase") will cancel each other out. The cables used in such systems are designed to carry two versions of the signal and manipulate the polarities of these signals to eliminate noise.
This will make more sense when we look at how balanced cables work, but first we need to take a step backwards and look at unbalanced audio cables."
The outputs from your new head unit are probably simple line level outputs. It won't work with the oem amp.
Old 04-01-2013, 03:16 PM   #3
halo0
My Ride: '02 330i 5mt
So you're saying it's not possible to replace the head unit in an HK-equipped car? That seems unlikely.
^Click, stop by and say hi.^ ------ 5% off Redline leather
halo0 is offline   Reply With Quote
Old 04-02-2013, 12:31 AM   #4
eJack
My Ride: 2004 330Ci ZHP
The OEM HK amp was the worst component in the audio system. If you are going through the trouble of replacing the head unit, you should definitely also replace that (garbage) amp.
eJack
2004 330Ci ZHP
BMW Performance Style 269 Wheels
BMW Performance Carbon Fiber Strut Brace
THIEL Audio PowerPlane Loudspeakers
THIEL Audio 12" Subwoofer
JL Audio Slash 300/2v2 Stereo Amplifier
JL Audio Slash 500/1v2 Sub Amplifier
USA Spec PA-12 iPod Interface
BMW Business CD stock head unit - yes it sounds great once you disconnect that garbage H/K amp!
eJack is offline   Reply With Quote
Old 04-02-2013, 04:40 AM   #5
ccaudio1
My Ride: 330i
what wire harness did you buy from crutchfield? is it the one with the rca out? or the one with just the speaker wires?
ccaudio1 is offline   Reply With Quote
Old 04-02-2013, 09:04 AM   #6
halo0
That is certainly an eventual possibility but for now I just want to get a new HU in there. I used the trick in my last car of splicing RCA jacks into the crutchfield wiring harness to feed line level signals to a bose amp from the aftermarket HU's line level outs. I don't see why that wouldn't work with the HK setup.
