Sponsored by The Tire Rack
Old 11-28-2012, 11:23 AM   #1
ajai
My Ride: 330ci***65104; 328i
Best psi for 2000 330ci on 225/40/18
on 34 all around.. Seems too high?
What's the recommend from bmw
missed the ci, welcome the i
ajai is offline   Reply With Quote
Old 11-28-2012, 11:26 AM   #2
zabalzae
My Ride: 01 330ci
I run 35 all around..
zabalzae is offline   Reply With Quote
Old 12-01-2012, 11:45 AM   #3
ajai
does making the rear a bit higher psi make the car balance better? make it less understeer?
Old 12-01-2012, 11:58 AM   #4
E46Moonlight
My Ride: 2000 323i
35 all around! Don't mess with it, different psi in the front or rear is not gonna make you a better driver.
E46Moonlight is offline   Reply With Quote
Old 12-01-2012, 02:31 PM   #5
ajai
I tried 35 all around, the car accelerate faster. but bouncy.
and I feel 34 seems to have more traction. Anyone run 34 here?
I have Dunlop star. anyone with that?
also do your traction control light goes on on bumpy rounds?
Old 12-01-2012, 09:49 PM   #6
E46Moonlight
My Ride: 2000 323i
Is this for daily driving, track, drag? If so psi is not gonna feel any different by 1 psi. Your butt dyno might feel it, otherwise no big difference.
Old 12-02-2012, 12:24 AM   #7
ajai
well in mine I feel a huge different of the accelerate.
the car feel lighter maybe u should say. So pick up faster
But 34 seems to have more traction.
Old 12-02-2012, 10:37 AM   #8
E46Moonlight
My Ride: 2000 323i
Ok buddy
Old 12-03-2012, 01:31 AM   #9
fth001
My Ride: 325i, e36m3, s13
So 34.5 psi should be the best of both worlds.
fth001 is offline   Reply With Quote
Old 12-03-2012, 08:05 AM   #10
Steven747
My Ride: 05 330ci
i have 225/40 on all 4 corners. i do Michelin recommendation of 39 on every corner
Old 12-06-2012, 04:53 PM   #11
ryohei
My Ride: '06 325ci w/ sport
Exactly.
Sent from my SCH-I535 using Bimmer App
ryohei is offline   Reply With Quote
Old 12-07-2012, 11:19 AM   #12
Rudy@Tirerack
Moderator
Rudy@Tirerack's Avatar
My Ride: 1-800-428-8355 X4664
There will be no real world difference between 34 and 35 psi. If you're feeling anything its the placebo effect.
Refer to 'Rudy/E46Fanatics' as your previous contact when you order online. Credit E46Fanatics.com by clicking here.
Rudy@Tirerack is offline   Reply With Quote
Old 12-07-2012, 11:24 AM   #13
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
I run 36 all around on 225/40 and 255/35
Old 12-07-2012, 11:59 AM   #14
peytonracer4
:D
peytonracer4's Avatar
My Ride: '00 328i
Traction control light coming on on bumpy roads means your suspension is done.
There's no difference between 34 and 35 on the street.
The door jam (just like on every other car in the world) tells you the recommended pressures for your tires.
Anywhere between 32 and 38 should be fine for the typical e46
Just so this is clear: decreasing your pressure does not increase traction on pavement.
However neither does increasing your pressure.
There's an exact pressure for each tire to be under certain conditions for maximum grip.
It all depends on weight of car, temp of road, suspension, tire, tire temp, road conditions and so on.
To simply say that "increasing or decreasing your pressure adds grip" is ignorant. Especially for street driving because you're not loosing grip. And if you are something on your car is inadequate or you drive like an idiot.
My car will grip to worlds end on the street.
Track driving is another story and 0% of people in this thread do it. I guarantee it
Old 12-07-2012, 02:08 PM   #15
ajai
Thanks for the detail.
My suspension is on new coilover, I guess maybe I set it too stiff.
the reason why I concern so much about the grip is because hong kong have very bad road condition, bumpy and very oily.
especially in rain, the oil on the street are crazy. And from my knowledge they use different materials for the roads then America or Canada.
when I was in Canada I never got this kind of problem.
also I know it'ssound stupid that I said I feel the different from 34 to 35.
But maybe it's due to I have a little overboosted rack, so I seriously can feel a bit different.
Old 12-07-2012, 02:45 PM   #16
peytonracer4
:D
My Ride: '00 328i
If you're on crappy roads your best shot for good traction is good tires. They will make much more difference than pressure. A quality tread pattern will help.
Oil is very slippery no matter what pressure or tire. If you encounter oil just be careful. That's all you can really do.
Old 12-08-2012, 12:40 AM   #17
ajai
most people use z1 star here , or re001 .
ps2 or etc is just not suitable here.
Old 12-08-2012, 11:44 PM   #18
ajai
I find a weird thing is that, I have front -2.30 camber , 0.1 toe out
however the tire wear is at the outer side where the tread meet the side wall.
I suppose it should wear the inside since it's neg camber. if that is the case which cause my tire so slippery, if I change it to the opposite side and also put them in rear instead, will it solve the problem? since the outer will become inner wear, and the rear doesn't need to turn so it casue less affect I guess?
Old 12-09-2012, 08:21 PM   #19
Grande D
My Ride: E36 M3
The Z1 is quite a good tire.
It will change your life!
Old 12-10-2012, 12:09 AM   #20
always-there
My Ride: 2002 BMW 330I
I usually do 35psi, but I'm doing 32 at the moment. : ) Less bouncy.
