Old 11-28-2012, 12:11 PM   #1
dlandon
My Ride: 330ci
HELP! Valves Stuck!
delete
dlandon is offline   Reply With Quote
Old 11-28-2012, 06:22 PM   #2
jared_wiesner
My Ride: 1999 328i (M54b30)
Do the valves not close as you rotate the engine? They must or they would be bent. Given that the firing order goes from 2 to 4, it makes sense that they would both have their valves open to some extent at the same point in the cycle.
jared_wiesner is offline   Reply With Quote
Old 11-28-2012, 06:37 PM   #3
jared_wiesner
See the two sets of cam lobes both pointing roughly up. Those correspond with cylinder 2 and 4.
(I apologize for the blurry picture, I had to zoom way in on a pic from my cam install DIY)
Old 11-28-2012, 06:54 PM   #4
dlandon
My Ride: 330ci
I thought that might be the case, but wasn't sure. I'll put everything back together and get a compression / leak down test done to make sure it's all sound.
Thanks!
Old 11-28-2012, 08:03 PM   #5
BimmerBrakes
The Brake Newbie!
My Ride: 2005 ZHP BMW
Send a message via AIM to BimmerBrakes
they look normal...
BimmerBrakes is offline   Reply With Quote
Old 11-28-2012, 08:54 PM   #6
SoloII///M
My Ride: Many
This thread has much win.
John V
'02 330Ci - Megasquirt 3 tuned by PFTuning.com
SoloII///M is offline   Reply With Quote
