Old 12-20-2012, 04:14 AM   #1
Snapasaurus
My Ride: 2005 325i SULEV
Cold start squeak?
Hey guys, i've been searching around to find out whats squeaking under my hood and I cant seem to pinpoint it. It only happens when the car is cold and idling, it goes away once the engine heats up or I accelerate.
I found a video of the exact sound:
Idler pulley maybe?
Thanks in advanced.
Snapasaurus is offline   Reply With Quote
Old 12-20-2012, 05:18 AM   #2
z0mghii
My Ride: 2004 BMW 325i
I have this exact sound on my car. 2004 325i. Wondering what it is also...
z0mghii is offline   Reply With Quote
Old 12-20-2012, 05:46 AM   #3
tootall
My Ride: 2011 328iT 3 pedals
Sounds like a water pump or pulley squeal to me. Mine had a similar noise and I replaced the water pump and now it is quiet.
BMWCCA member since 1990
Upgrade your 328 with a 330 intake: http://forum.e90fanatics.com/showthread.php?t=1095889
tootall is offline   Reply With Quote
Old 12-20-2012, 08:32 PM   #4
Snapasaurus
Is the noise just due to wear? Should I replace it immediately?
Old 12-20-2012, 08:40 PM   #5
E46330iguy
My Ride: Supercharged 330i
Its a pully or belt, Take the belt off and check pullies, replace belt if its worn
Winter Authority When Hell freezes over,we'll play Hockey there too
you've Met a terrible fate haven't you ?
KONI /Michelin/Stoptec/Borla/ Bimmerbrake / MTechII/AA Stage one (for now) Automatic--->5 speed swap/ UUC High performance clutch kit
Questions about Header wrap? clickHere
Supercharger build thread click Here
E46330iguy is offline   Reply With Quote
Old 12-20-2012, 09:01 PM   #6
swordsman11868
My Ride: 2003 325i
Mine was the idler pulley. Squeeked only when cold.
Replaced and sound is gone. Haven't done the tensioners yet but they're I'm the mail.
It's much easier to PRESERVE an E46 than it is to RESTORE one.
BMW Wiki: http://www.bimmerfest.com/wiki/index.php
E46Fanatics inspiration Robolop: http://forum.e46fanatics.com/showthr...87566&page=101
2016 Beheadings in Saudi Arabia: 92.
swordsman11868 is offline   Reply With Quote
Old 12-22-2012, 01:46 PM   #7
Snapasaurus
Bump for more info.
Old 12-22-2012, 05:41 PM   #8
E46330iguy
Originally Posted by Snapasaurus View Post
Bump for more info.
Have your took anything apart yet? The belt literally takes 5 min to take off, All we can give you is speculation. You have to check out the pullies yourself and report back
Old 12-22-2012, 05:46 PM   #9
HiHoBrian
My Ride: 05 M3
If your car has 50k miles or more you should replace your idle and tension pullies and belts. The tensioner would be smart to replace as well. The next step from a squeak is a melted pully then the belt is torn off,gets caught in the fan and blows out your radiator and coolant hoses.
Now you you can't say we diddnt tell you so.
sent from my ATARI sc1224
HiHoBrian is offline   Reply With Quote
Old 12-22-2012, 06:41 PM   #10
Zell
Zell's Avatar
My Ride: so turbo wow
I've sort of heard a noise similar to that, but I've replaced all my belts and pulleys.
Not sure if it's something with the belts or VANOS rattle, it kind of reminds me more of marbles in a tin can.
Old 12-22-2012, 07:36 PM   #11
tech4tech
My Ride: e46, 325i
Sounds like your idler and tensioner pulleys.
tech4tech is offline   Reply With Quote
Old 12-22-2012, 10:43 PM   #12
MTL_E46
My Ride: 02 325xi
^+1
All is explained here:
MTL_E46 is offline   Reply With Quote
