Old 11-28-2012, 08:32 PM   #1
white46m54
My Ride: 2001, 325i manual
clutc problem
My 2001 325i developed a problem lately after a new clutch was replaced 10 months ago. The car jerks just before I release fully the clutch. Sometime the car shakes a lot and sometimes a little and other times is normal. If I give more rpms before I release the clutch shakes less. Is the clutch disk slipping or is something else? Anew clutch can do that? Thanks for any good ideas.
white46m54 is offline   Reply With Quote
Old 11-28-2012, 09:04 PM   #2
Stinger9
My Ride: '04 330Ci
I'm not the clutch expert, but I believe misalignment can cause what ails your car.
Or a contaminated clutch plate.
Assume you did a new pressure plate at the same time?
Old 11-28-2012, 09:37 PM   #3
shovelit
My Ride: 03 325xi and 04 330x
+1 on contamination. Also bad springs in the disc. What kind of clutch is it?
shovelit is offline   Reply With Quote
Old 11-28-2012, 09:53 PM   #4
SweTurbo
Big Pimpin'
My Ride: 323i -98
A clutch cant be misaligned , you use an alignment tool when you install so the transmission will bolt up to the engine , once it's bolted up the clutch disk will center on the transmission input shaft as soon as you release the pressure plate(push the pedal).
Contamination does this , most common is the rear seal leaking and getting oil on the clutch disk.
Thats why you should pretty much always change the rear seal.
Old 11-28-2012, 10:11 PM   #5
white46m54
After I release the clutch the car do not shake at all. Only the moment before full release of the clutch, the car is shaking. Then, I accelerate fast and it has no problem.
Old 11-28-2012, 11:48 PM   #6
330iDiot
My Ride: 330i
Could be a bad DMF. Did you get a new one when they changed out the clutch?
330iDiot is offline   Reply With Quote
Old 11-29-2012, 12:11 AM   #7
Stinger9
My Ride: '04 330Ci
You'd have to be an idiot to think that everyone knows what a DMF is.
Old 11-29-2012, 12:49 AM   #8
pleiades
My Ride: M52TU
I know Stinger knows but ...
dual-mass flywheel
Not that this has anything to do with the issue here but ...
There's an alignment dowel on the crankshaft mount to ensure the flywheel is properly aligned. However, that dowel can be lost if it's say.... stuck to the old flywheel and the new DMF was installed without it by someone that wasn't alert.
This would probably create some timing issues but I'm not certain about that on the sixes.
So, white46m54..... what clutch did you have intalled, and did you get a new flywheel with it?
pleiades is offline   Reply With Quote
Old 11-29-2012, 01:09 AM   #9
Stinger9
My Ride: '04 330Ci
mea culpa: actually I didn't, but I couldn't pass up the joke.
I knew it was dual mass, but didn't know flywheel.
Not really that knowledgeable regarding clutches even tho I put a new one in several cars ago. Got corrected back in post #4 too!
Old 11-29-2012, 01:49 AM   #10
white46m54
The car has 210000 miles and the flywheel is the original.the mechanic changed the clutch and said nothing about flywheel.
Old 11-29-2012, 02:16 AM   #11
TitaniumCranium
/// Limitless
TitaniumCranium's Avatar
My Ride: 2002 BMW 330Ci
I'd be willing to bet that not replacing the DMF is causing your issues. When you get a new flywheel the surface is ground, kind of like new brake rotors. When a new clutch mates against that surface they break-in together. Some of the clutch material is transferred to the surface of the flywheel during the break-in process and they bed in much like brakes do. This break-in process provides for a smooth clutch release. IF you're still running the original DMF, it's probably burned, contaminated or just plain worn out. In every instance I've seen the flywheel takes more abuse and wears quicker than the the pressure plate does, no matter how well/precisely the tranny splines are greased (which allows the clutch disk to move back and forth during clutch release).
Did they replace just the clutch disk? Could be that they didn't replace the pressure plate either. How much did they charge for the work? Do you have a parts list?
/// MODS
Last edited by TitaniumCranium; 11-29-2012 at 02:18 AM. Reason: corrected an error...
Old 11-29-2012, 09:56 AM   #12
pleiades
My Ride: M52TU
I agree with Titanium. That mileage is a lot for any original clutch part. When you replace the clutches in these cars at these ages, you need to replace several things at a minimum.
Pilot bearing (and probably rear main seal "since you're there")
Flywheel
Clutch kit (disc, pressure plate, throw-out bearing)
.... and other assorted bits including any driveshaft components (giubo, centering guide sleeve, center support bearing) that are unbolted to get the trans out, any while-you're-there trans & shifter seals/bushings etc....
white46m54, do you know what your mech replaced? You do not want that flywheel to explode.
Old 11-29-2012, 10:42 AM   #13
white46m54
They replace the whole kit and the cost was $890.00. If it is contaminated, how can be fixed?
Old 11-29-2012, 11:15 AM   #14
E36bimmer
My Ride: 2004 330Ci ZHP
I just did my clutch and when I bough the parts they wouldn't let me buy just the clutch kit, I had to get the flywheel too. When I took it all apart the flywheel looked like crap, I am putting my money on your flywheel being worn out. like what was said above, it is similar to replacing brake pads and rotors at the same time.
04 ZHP alpine white
20% tint
K&N
Shadow trim, Blackout grills, 18" Black Staggered ASA AR1, LED's everywhere, Black euro plate
E36bimmer is offline   Reply With Quote
Old 11-29-2012, 12:15 PM   #15
Stinger9
My Ride: '04 330Ci
what kind of mileage on your car?
Old 11-29-2012, 04:17 PM   #16
E36bimmer
152,000 miles no record of clutch being replaced before this.
04 ZHP alpine white
20% tint
K&N
Old 11-29-2012, 04:47 PM   #17
Stinger9
My Ride: '04 330Ci
Encouraging!
Old 11-29-2012, 05:50 PM   #18
Wolrab
My Ride: 330Ci MT, 545i SMG
Encouraging!
I have 175,000 on the original clutch in my E60. Some guys are getting them replaced every 30,000. That's a factor of about 6 - there's a HUGE variation in clutch life that depends on driving style and conditions.
Engineers do it with a torque wrench
Wolrab is offline   Reply With Quote
Old 11-29-2012, 06:02 PM   #19
///MPR77
My Ride: 02 ///M3 Tri-Ped
I have my original flywheel, and I am at 296k, but I certainly cannot tell you that your flywheel is fine.
The problem you're describing is one I experience when the clutch is going bad.
It feels like the only way to get the car going without it shaking and stuttering, is to take off aggressively every single time, which is annoying.
Unfortunately, it seems as if you're going to have to drop the transmission again. I would take it back to the mechanic who installed it, and very diplomatically,tell him what is going on.
Possibly Sounds like an issue with the pressure plate though.
Good Luck.
