#21 | |
I think your water pump is failing, but that's just my .02 worth of experience with my cooling system. I would bleed properly and definitely keep an eye on the temp gauge and coolant level. The little hole just inside the ET fill neck should piss coolant when there is good flow. Maybe check that out while you're poking around.
![]() WTB: Black sun visors & grab handles - PM ME! |
#22 |
Just bled the system and I'm still getting the same problem with only getting hotter air once the revs are higher, when idling the air starts to turn colder so it may sound like I have a problem with the heater core valve, does anyone know how much a heater core valve costs and how hard is it to replace?
#23 | ||
Weagle Weagle
ECS has great pictures. http://www.ecstuning.com/Search/64118369805/ES177235/ I'm not entirely sure that the valve is the problem. One person has suggested your water pump. I guess it's possible, but I feel it is unlikely since your car is not overheating and the waterpump doesn't fade out in terms of flow rates. It breaks the bearing and makes the belt jump off eventually but doesn't lose flow capacity. The problem would be with the valve assuming a valve can get stuck in a position b/w open or closed. If it's stuck partially open then it's just not letting enough water through at idle, but when you increase the RPM, the flow increases and gives you hot water to the core. You need to inspect these parts above before you buy the valve. It could just be a hose with a kink in it. Last edited by WDE46; 12-01-2012 at 08:04 AM. |
#24 |
It's your water pump/thermostat. Listen to what everyone is telling you. The water pump is moving more water when your revs are high. Hence the warm air when moving. If it was the control valve you would not have hot air at all. But its your money. Piss it away as you see fit.
#25 | |
Weagle Weagle
OP, can you tell us your cars water temperatures while at idle warmed up and while driving (at say 60-70 mph) warmed up? This will tell us if your thermostat is broken. Last edited by WDE46; 12-01-2012 at 08:28 AM. |
#26 |
Have you inspected your system, OP, as in getting under the car, making totally sure there are no coolant leaks, removing undertray, running car, making certain nothing is leaking? When I had this problem, it turned out to be a crack in the expansion tank, as I said earlier, that was very hard to find. I saw evidence of dried coolant nearby and after removing the tank I found the crack. I would think bleeding the system, without identifying the problem is pointless.
If you want to test the heater valve, then just bypass it temporarily, see if that fixes your problem. I'm still sticking with leak though. Air in the system will find its way to the heater core. |
#27 | |
![]() The impeller was just sitting there while the shaft spun freely. And to reinforce this even more, the bearings in the pump were quieter than a mouse, so there wasn't any indication that the pump had failed! I found a cheap replacement at Pep Boys for I think $60 made by Bosch with a metal impeller. Good luck with your problem.
#28 |
Weagle Weagle
#29 |
Could be enough flow to keep it cool at idle, but not enough to push into heater core?
Sent from my DROIDX using Bimmer App
#30 |
Coolant flush
/thread. |
#31 |
Had a new water pump put in last year so unless I'm really unlucky I don't believe that has broken down, going to try to replace the heater control valve tomorrow and see how that goes, if anyone has any tips on replacing the heater control valve please let me know
#32 |
Dont replace it just yet. Pop the hoses off and keep the electric connected. Have someone turn the heat on and off while looking through the valve to see if the plunger is moving up and down. It only moves a little so keep a close watch
#33 |
My Ride: 04 M56,LC 100,RX300
There is probably air in the system, bleed the cooling system before you do anything else.
Sent from my ADR6400L using Bimmer App
#34 |
How does a bad water pump sound? Im getting a high pitched whistle sometimes when I give it some throttle.. I know I replaced my water pump with a metal impeller (Graf) about 2 years ago.. Im also only getting heat when I rev to about 4k RPM
its gonna be a cold winter.. no its not air. as a side note, due to a hole in between my head and block that shoots coolant out, i was forced to resort to a stop leak product. i was fine for about 2 years like this. looks like that crap has caught up and clogged all types of stuff up.
![]() Last edited by EmFiftyFour; 12-01-2012 at 10:27 PM. |
#35 | |
Weagle Weagle
#36 | |
Sent from my SAMSUNG-SGH-I317 using Bimmer App Last edited by nicoled985; 01-31-2013 at 12:46 PM. |
#37 | |
Your last comment was two months ago. What's happened since then and is the problem solved? As you know, other people may have your same problem, so please let us all know the outcome.
I love my car as much today as the day I bought it |
#38 |
Sorry haven't posted, went on vacation then came back to reassess the problem. I removed both pipes going into the passenger side of the engine bayland flushed it all out with a hose.. a load of brown gunk came out, put it all back together and still no heat but it cleared out the system. Replaced the heater control valve and flushed the whole system. refilled it and bled it and now i get heat, i also had a minor leak somewhere so i dropped in some leak repairer which stopped the leaking so it was probably a combination of things which caused the issue. All fun and games now i got a whirling noise from the rear offside wheel so it looks like I got bearing to replace when it gets warmer.
#39 |
Weagle Weagle
Holy **** OP delivers!
#40 | |
![]() Last edited by EmFiftyFour; 02-08-2013 at 01:52 PM. |
