Sponsored by BimmerWorld
Old 06-12-2010, 02:10 PM   #1
AlexB.
My Ride: Is not as slow
Send a message via AIM to AlexB.
No E-brake
Just did a full brake swap.. (rotors and pads) but now the E-brake is completely dead. And the button on the top of the handle is pressed at all times... Any ideas?
AlexB. is online now   Reply With Quote
Old 06-14-2010, 02:20 AM   #2
xqwizit
My Ride: '98 4Runner
Did your rear brakes include the spring mechanism which the e-brake cable attaches to? It goes under the brake rotor and you are probably missing that.
xqwizit is offline   Reply With Quote
Old 06-14-2010, 02:36 AM   #3
royceyokono
My Ride: 2005 325ci
does the ebrake engage when you hold the lever up? if so, maybe your button is stuck. try lifting the ebrake lever up, let it go and let itself slam down see if the button dislodges.
royceyokono is offline   Reply With Quote
Old 06-14-2010, 06:41 PM   #4
AlexB.
The button is lodged in... It will not release. I will try that.
Also when I did the brakes, I did not touch anything on the parking brake assembly. hopefully its just the button being stuck.
Old 07-31-2011, 12:23 AM   #5
E46_Project
My Ride: '02 325Ci
Bump
Anyone else experience this? EBrake will work when pulled but button is stuck and it will not latch when pulled.
E46_Project is offline   Reply With Quote
Old 07-31-2011, 04:27 AM   #6
SL Blak Soldier
My Ride: 3 Pedal SG S54B32
Send a message via AIM to SL Blak Soldier
Happens to me quiet frequently.
What happens is when you push the button in, it moves a lever in the ebrake mechanism. The stop for the lever gets bent open, and the lever gets stuck against that stop.
What you have to do is take off teh ebrake boot. Then you should see a little lever, in my car it's black. It's pretty easy to spot against the metal. just push that back up into the mechanism. that should release the button. What i'd do after that is get some pliers and carefully bend that metal stop so it actually stops the lever, instead of getting it stuck.
if you need more help lmk, i can get pics if you really need them. (i might not check back in the thread so just pm me)
SL Blak Soldier is offline   Reply With Quote
Old 04-04-2012, 03:52 PM   #7
SL Blak Soldier
here are some pics by request.
You can see the metal tab in these pictures that needs to be bent back into shape.
The metal tab is what stops the button from going in too much. So you just have to bend it back. When you push the ebrake button, it should stop the black lever from going any further. As you can see, mine needs to be bent back into shape!
ID:	445164   Click image for larger version
Old 04-04-2012, 06:13 PM   #8
bekurt
My Ride: E46 330ci
Is that red thing an arrow?
bekurt is offline   Reply With Quote
Old 11-25-2012, 04:27 PM   #9
Jaundiced Outlook
My Ride: has a tailgate
Resurrecting an old thread, but I had to thank SL Blak Soldier for posting the pictures, and saving me a lot of frustration. Had a stuck e-brake button, and this was exactly what was causing the problem.
2001 325iT 5-Speed
Jaundiced Outlook is offline   Reply With Quote
Old 11-29-2012, 02:17 PM   #10
bekurt
My Ride: E46 330ci
Thank you SL Black Soldier. You are a trooper!
ebrake, stuck
