Thread Tools Search this Thread Rating: Thread Rating: 11 votes, 5.00 average. Display Modes
Old 11-29-2012, 09:45 AM   #1
Patton323I
My Ride: R1100GS E46 E53
Post Window Regulator DIY
As we all know, the long list of Preventative Maintenance (PM) items for our cars is long, and at times, expensive. The window regulator is yet another aspect of our cars that, with time, will ultimately fail. However as I can tell, there is no official DIY addressing this issue. This will be my first DIY
*Note*
As of right now, I don't have any pictures of myself doing this repair. What I am simply providing at this point, is reference material to source parts and conduct a successful DIY repair. When I do my next window regulator, I will update with pictures and detailed step by step instructions.
The Problem:
Failure of the window regulator, or related components, resulting in inoperable window function.
Common solutions, and talking points:
A lot of people have had this issue. As such, a lot of solutions have been presented. Some people opt for replacing the clips that hold the window itself in place. My issue with this is, if you are already in the door to replace one plastic component, it is very likely that the rest of the plastic components are not far from failing. These parts are cheep and not hard to replace.
Many people on this forum will argue that any part purchased on Ebay is cheep, unreliable, parts made in china (they are). In my experience with doing 3 window regulators in BMW's, previously this was not the case. However, now I cannot recommend the Ebay regulators. There are fitment issues and they do not have good longevity. ECS Tuning is a good source for window regulators. FCP Euro also carries a wide array of quality parts. They can be sourced anywhere from $40 - $140 depending on the brand you go with. The genuine BMW part is well over $120, not including shipping costs.
All that being said, it is far more cost effective and reliable to simply replace the entire window regulator assembly. From a PM standpoint, it may be beneficial, to mitigate failure, to replace the component every 2 years, depending on usage. These figures will of course vary per individual usage.
Where to source parts:
ECS Tuning, or FCP Euro as previously stated. Enter search term "E46 window" or follow links.
Driver side (front left):
http://www.ecstuning.com/BMW-E46-323...tor/ES2776543/
Passenger side (front right):
http://www.ecstuning.com/BMW-E46-323...tor/ES2776542/
Rear drivers side (rear left):
http://www.ecstuning.com/BMW-E46-323...tor/ES2776546/
Rear passenger side (rear right):
http://www.ecstuning.com/BMW-E46-323...tor/ES2776547/
Equipment needed:
Standard torques bit set
Standard mechanics socket set in metric.
Number 2 flat tip screw driver or applicable trim removal tool.
1 Roll of duct tape, or similar adhesive material.
Applicable window regulator assembly
Procedure:
As stated above, I don't have pictures of my self doing this procedure yet.
However I do have a nice video DIY for everyone to follow! Front window regulator Is similar install. Video by edzgarage.
Window Regulator Installation BMW 325i e46:
Here is also a link to another thread that addresses this issue! The more information the better!
http://forum.e46fanatics.com/showthread.php?t=356847
I hope this Helps some people out. I will update this when I do my next regulator. Any positive/constructive feedback, please leave comments. Any negative feedback, please file it in shredder.
Patton323I is offline   Reply With Quote
Old 12-11-2012, 11:45 AM   #2
cyberlando
My Ride: 2002 M3
goooddd shitt broo my driver side one has a messeded up clip!
Engine:
[] Euro Headers [] Euro Cats [] OEM Section 2 AR20[] B&B Exhaust [] AFE Stage 2
Interior:
[] Led Interior [] DICE Module [] Auxilary 3.5 jack [] 4 channel Amp with component speakers.....and more
Suspension/Handling:
[] KW V3 [] Eibach F&R Sways [] Vibratechnics Tranny mount [] UUC RTAB
[] Vibratechnics Motor Mount [] SSBL [] Turner Camber Plates
[] 90A Akg Subframe Bushings [] Akg Differential Bushings [] Subframe Renforcement
cyberlando is offline   Reply With Quote
Old 04-03-2013, 01:53 AM   #3
akita328
My Ride: 2000 328i sport/prem
This DIY is great! Thanks for taking the time to do this! I'm just about to do this myself...
akita328 is offline   Reply With Quote
Old 04-03-2013, 01:59 AM   #4
Bimmer4Lyfe
Location: 129 West 81st St. 5A, New York, New York 10024
My Ride: 02 325i
Not to take anything away... Nice write up & video
Hard to believe you didn't see this
Actually your post and this post compliment each other nicely
Bimmer4Lyfe is offline   Reply With Quote
Old 04-18-2013, 11:03 AM   #5
Patton323I
I didn't know there was another write up. But if I can add anything to the cause, then that's better than not helping at all in my opinion.
Old 04-18-2013, 10:25 PM   #6
akita328
The other write-up is for the front window regulator, which is a bit different. Yours is for the rear, and it's EXCELLENT for that.
Thus, both combined complements each other very very nicely
from what I've read, given my rear regulator broke, I can expect the other 3 to go bad soon... so will need both DIY very handy.
Old 04-19-2013, 04:47 AM   #7
jayb328i
My Ride: E46 2000 328i
What, no air bag. I have done all of my window regulators at least once, and the video is a good start for someone who has never done this. It does not address the Air Bag and how to handle that--which is easy. But I would never work side-by-side with a live Air Bag before disconnecting the battery, which changes the video slightly. It also does not suggest changing the red grommet that holds one window screw, they sometimes go bad, and for a part that cost less than a dollar, good to change it. Lastly, I learned the hard way (after the first 2 window regulators) that replacing the plastic rain guard using the existing black sealer will not work in my E46's following your directions. That will, based on my experience, result in 100% chance of a water leak (puddle) inside your car, and 100% guarantee you will be re-opening the door to redo that. Special attention needs to be paid to how you reseal the plastic guard. Just following this video does not do that. I use a hair dryer to reactivate the black sealer so it attaches properly.
jayb328i is offline   Reply With Quote
Old 04-19-2013, 04:52 AM   #8
Patton323I
I haven't had an Issue with water entering the car. But I was quite ginger when removing the vapor barrier. The video is intended to be a guide. I wouldn't consider it a technical step by step as something you might get out of the TIS for example.
Old 04-19-2013, 06:22 AM   #9
jayb328i
As i said, good start. Just wanted those who undertake window regulator replacement to know that this is a easy thing to learn and do. Use this video provided as a good background, but need to look at some of the other postings, and from my own experience and write-ups of others, do not ignore how important the black re-seal is in the process. Thanks for the good video.
Old 11-25-2013, 06:31 PM   #10
fonzie
My Ride: 2001 BMW 330i
I know for the front window regulators you have to disconnect the battery due to the airbags. Does that need to be done for the rear windows as well?
fonzie is offline   Reply With Quote
Old 11-26-2013, 10:40 PM   #11
John in VA
My Ride: 328i/325xi
Some cars came with rear side airbags; in that case, yes.
John in VA
'13 328i xDrive
'06 330ci ZHP
'03 530i
'02 325xi
'00 328i
'86 535i
'85 535i
'85 325e - RIP
'74 2002tii
John in VA is offline   Reply With Quote
Old 11-26-2013, 11:52 PM   #12
fonzie
I don't think my 2001 330i has rear side airbags. Where would they be, in the C pillar?
Old 11-27-2013, 09:16 AM   #13
jayb328i
They would be in the door, similar to the front door. When you remove the panel you will see it there. The panel should have a blow-out section for the airbag to inflate, just like the front--and is probably marked (like the front) with airbag.
Old 04-24-2015, 09:24 AM   #14
330iPilot
My Ride: Titanium Silver 330i
Great video! Just a couple of small things to add. I learned these from snooping around the Internet from some other sites. I made sure to pull the window out and clean the entire thing. I also put some goof off on a rag and used a flat stick to clean all of the channels. Then I used dry silicone lubricant on all of the rubber channels. I like the goof off because the xylene in it gets the dirt out but doesn't dry out the rubber.
I had replaced regulators a couple times before and the windows just didn't seem to work all that well. When I cleaned and lubed all the channels with the proper lubricant they all worked just like new! The great thing about the dry silicone is that it doesn't get any crap on your window, but the rubber feels slicker than whale snot.
One more thing, if you've done it several times it helps to get some more of that sticky butyl rubber to re-seal the inner foam panel. Mine started leaking after the second time I replaced the regulator.
330iPilot is offline   Reply With Quote
Old 04-27-2015, 06:34 PM   #15
lllRazorlll
Modded ///Member
lllRazorlll's Avatar
My Ride: '00 328i
Are the front doors regulators the black ones and the rear doors regulators the silver ones? When you click on one of the links that's what shows up.
Also, don't the BMW brand regulators hold up a good amount of time to just get those? Not saying I want to spend $500 on window regulators, just trying to see if the aftermarket regulators are just as strong as the BMW brand ones
>IN SEARCH OF GRAY SEDAN SPORT SEATS<
lllRazorlll is offline   Reply With Quote
Old 04-27-2015, 06:52 PM   #16
Patton323I
Yes, I believe that the front are black and the rear are silver. Having had time to further examine the longevity of the ebay units, I can't recommend anyone getting those any more. Best to get the brand name ones with a better warranty.
Old 04-27-2015, 07:12 PM   #17
Fb16
My Ride: 2003 325i
Just tried to click on the links, items are not there anymore
Fb16 is offline   Reply With Quote
Old 04-27-2015, 07:29 PM   #18
Patton323I
Well the links are about 3 years old now, so it makes sense... But now they are updated.
Old 04-27-2015, 09:18 PM   #19
Fb16
My Ride: 2003 325i
Old 04-27-2015, 09:20 PM   #20
lllRazorlll
Modded ///Member
My Ride: '00 328i
Thanks for updating the links
diy, regulator, window
