Old 07-30-2016, 03:37 AM   #1
330cijunkie
My Ride: 2001 bmw 330ci
S54 dishing out 19 psi
2003 BMW m3. Can a stock, never opened s54 motor with a 62 turbo run 19 psi on 91 pump. Wouldn't that put the block in danger? Wouldnt you have to be running e85 to get 19 out of that motor without putting the block at risk? Explain? I don't understand life...
330cijunkie is offline   Reply With Quote
Old 07-30-2016, 06:43 AM   #2
cosmos328Ci
My Ride: 398.5 whp. Mainline.
Just reduce timing.
cosmos328Ci is offline   Reply With Quote
Old 08-07-2016, 09:40 AM   #3
Nicholas1996
My Ride: 2003 M3
Most likely needs ms109 or some other fuel. But if you reduce timing like mentioned before , it will be safer
Nicholas1996 is offline   Reply With Quote
Old 08-08-2016, 10:39 AM   #4
mike@maximumpsi
My Ride: 02M3T
Nobody is running a turbocharged stock s54 19psi on 91 octane for long.
02 M3 - Maximum PSI S2 turbo kit - 9.74@145.99, stock motor, stock ECU, first in the 9's
97 M3 - Maximum PSI turbocharged - 8.94@164.33, stock ECU, first in the 9's, first in the 8's
16 M3 - Maximum PSI full bolt ons - 10.27@137, quickest in the US
BMW SOB's turbo E30 - 8.72@158.39
Maximum PSI - Home of the quickest BMW's in the US
Click here for E46Fanatics 1/4 mile standings
Follow us on Facebook and Instagram!
mike@maximumpsi is offline   Reply With Quote
