Old 11-30-2012, 12:35 PM   #21
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
Must be nice to live in FL. I can probably guess who's tuning it
Originally Posted by A4RingedONE8T View Post
Tuned on the stock DME by someone you and I spoke about recently
Or it could be tuned on the stock DME like I said ... I wouldn't list something if it wasn't what was happening. This car WILL NOT be seeing any type of aftermarket ECU.
-Shawn-
Old 11-30-2012, 01:42 PM   #22
AAblown
My Ride: e46 m3, e36 m3, H2
sounds good, APEX makes some nice CSL looking wheels that are nice and wide
http://store.vacmotorsports.com/apex-wheels-c366.aspx
AAblown is offline   Reply With Quote
Old 11-30-2012, 03:45 PM   #23
Grande D
My Ride: E36 M3
Apex wheels are in the OP build list
It will change your life!
Old 11-30-2012, 04:01 PM   #24
WALKD U
My Ride: Just Fast!
-Shawn-
If its a Ms45. I am looking forward toward the results!
2005 AW/IR M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
2005 JB/BLK 330i ZHP
Stock
NAwhp/NAwtq SAE Corrected
1996 BLU/BLK M3
Stock
1988 SETA 325I
Stock
Old 11-30-2012, 07:47 PM   #25
AAblown
doh my bad...didnt see that.
Old 12-01-2012, 01:23 PM   #26
LoveBeingUseless
My Ride: 2003 325i Sedan
awesome build! really looking forward to it! subscribed
Front:18x10 et12 Rear: 18x10 et20
Check Out My Build Thread:
For more updates, Follow me on Instagram! @LoveBeingUseless
LoveBeingUseless is offline   Reply With Quote
Old 12-01-2012, 03:18 PM   #27
MarcusLSB
My Ride: X5, CT200h, CLK63 BS
-Shawn-
Very nice!
Old 12-03-2012, 08:42 AM   #28
A4RingedONE8T
My Ride: Turbo ///M Roadster
It's MS43. What are the issues with MS45 that you've heard or ran into?
A4RingedONE8T is offline   Reply With Quote
Old 12-05-2012, 11:58 PM   #29
sunnyjay
My Ride: 01 330i
In for the results.
sunnyjay is offline   Reply With Quote
Old 12-06-2012, 12:04 AM   #30
Grande D
My Ride: E36 M3
The MS45 has a bridge keeper.
Old 12-12-2012, 06:55 PM   #31
dgreen78
My Ride: 00' 323i
Great build guys! In for more pics! Any of the 3" exhaust?
07' 997TT
00' 323i 2jz
dgreen78 is offline   Reply With Quote
Old 12-12-2012, 07:35 PM   #32
WALKD U
My Ride: Just Fast!
LUCKY YOU! From what I been told the DME dont like alot of TQ and it has some TQ calculation on the DME that will limit the power. Also, said this DME was ahead of its time and it has so much on it that is useless. Making it that much harder to tune and etc. This is what I heard from 2 Turner so far but we will see what happens.
-TrippinBimmer
2005 AW/IR M3
MaximumPSI Stage4
Stock
1996 BLU/BLK M3
Stock
1988 SETA 325I
Stock
Old 12-13-2012, 08:59 AM   #33
A4RingedONE8T
We are just getting started with the project, none of the fab work has been done yet. Had a problem with one of the piston rings so waiting on a replacement from CP. I am also getting married this Saturday and will be out tomorrow (Friday) and all next week. After the holidays I will update the thread with some motor build pictures and we will be getting started with the fab.
-TrippinBimmer
Hmm, interesting. I wonder if Karl/AA or Nick G. have had these issues or were able to overcome them?
Old 12-13-2012, 12:00 PM   #34
SweTurbo
Big Pimpin'
My Ride: 323i -98
I had a 35R before my current , it was perfect for a 9ish compression on the B30
Cant wait to see how this turns out
Old 12-17-2012, 05:02 AM   #35
wrecklessfool
My Ride: is paid off
Very interested in following this build as it's nearly identical to what I have in mind for mine when I return from deployment.
I have a couple questions about the fuel delivery system...
What do you plan to use as a fuel pump and what pressure do you hope to achieve at the fuel rail? Will you be using the stock fuel rail? Do you plan to use an aftermarket fuel pressure regulator and fuel filter? If so, can you give details? And lastly, are the Siemens 630cc injectors plug and play (compatible with stock DME) and where can I get my hands on some?
I currently have a turbo kit installed that uses my stock DME and have a pretty good idea of who will be performing the tune on your build. I'll be going to the same tuner when the time comes.
wrecklessfool is offline   Reply With Quote
Old 12-27-2012, 09:06 AM   #36
A4RingedONE8T
Car already has a walbro hi pressure 255lph intank pump. Planning to use stock lines, rail, and regulator assuming we have no issues. Siemens 630's are plug and play except they are slightly taller than the stock injectors. You will need to use spacers on the rail to bolt it down properly.
Motor progress
Oil squirters cleaned and reinstalled
Crank installed, Raceware main studs torqued, main cap supports installed
Raceware head studs installed with Wurth timeserts
Oil baffle modified for main studs
Shortblock assembled
Head gasket on
Head on and torqued
Cam tray studs installed
More soon!
-Shawn-
Old 01-12-2013, 02:38 PM   #37
zaharias
My Ride: M3 E46 6MT 3/2005
Amazing work.. well done!!
zaharias is offline   Reply With Quote
Old 01-12-2013, 02:45 PM   #38
Russian172
My Ride: e46 sedan e46 m3
Subd
Russian172 is offline   Reply With Quote
Old 01-12-2013, 02:48 PM   #39
Think0rz
My Ride: 05 AW M3
awesome work as always love seeing updates to your work great stuff
Think0rz is offline   Reply With Quote
Old 01-23-2013, 09:26 AM   #40
A4RingedONE8T
Hey guys sorry for the lack of updates, we're still moving with the build, slowly but surely! I've been working a little slow for the last week or so, decided to rip my hand open cutting some metal and have 7 stitches in my hand. It's all good though, it didn't seem to affect my manifold building abilities
Every port welded in and out 360* including runners, wastegate flange, and turbo flange
I'm aware it's not equal length, wasn't going for that. Space was very limited for the manifold placing the turbo where I wanted it. Quick spool, 500whp, this manifold should work nicely!
-Shawn-
