Old 02-13-2013, 11:40 AM   #81
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
Originally Posted by A4RingedONE8T View Post
BOV can be placed a variety of places to alter the performance of the setup. Closest to the turbo is best for the turbo because it's instantly venting any pressure from coming back at the turbo causing compressor surge. Close to the turbo also creates the most lag as it is completely venting any positive pressure from the source and will cause the most lag between shifts. Primarily as it has to completely "refill" the desired boost before the pull starts again in the next gear. Moving the BOV away from the turbo lessens the amount of lag because it is keeping some positive pressure on the turbo side of the system. Most of the time I go for where works best with what's going on with that particular setup. I chose the location on this car for ease of fitment, clearance with fog lights, lack of clearance on the hot side because of turbo placement, and also far enough away from the blow through MAF that will be in the straight piece of pipe directly before the throttle body.
Really good info, thanks for explaining the application.
In the motorsports environment they can control the BOV very similar to how the waste-gate is controlled, and have off-throttle closed loop control of the charge pipe pressure. Basically, they target XX PSI off throttle, in addition to using a bypass valve or through-engine flow control to keep the turbine wheel spinning at target speed.
A street application is totally different, and I can understand how moving the BOV further away from the compressor can be beneficial for throttle response.
Very nice work!
Old 02-13-2013, 09:23 PM   #82
AAblown
My Ride: e46 m3, e36 m3, H2
Tial uses a pretty large vac line compared to what's really needed. I've put Tial valves all over the place all with different length vac lines and none have ever shown any delayed response. The one on my car is probably the longest/furthest I have done and still no issues
I put the BOV where it is just for best fitment, no other reason.
I knew you could turn metal into artwork but your knowledge of everything is impressive
AAblown is offline   Reply With Quote
Old 02-14-2013, 09:03 AM   #83
A4RingedONE8T
My Ride: Turbo ///M Roadster
All stuff I've learned just from experiencing it
A4RingedONE8T is offline   Reply With Quote
Old 02-19-2013, 04:37 PM   #84
A4RingedONE8T
Well, it's nearing the end for this build, most things are buttoned up with just a few items remaining. Just ordered all AN fittings and hose for oil/coolant lines now that all hardware is placed. Waiting on a few interior/console pieces to arrive (customer requested all peeling interior parts be replaced), M-tech II bumper fitted however waiting on a few OEM mounting brackets that differed from the original 325 bumper. Lastly waiting on a tune and blow through MAF and we should be seeing what this project has in store!
Nipples? Bungs? Lots of them
AEM wideband for mirror display
Lots of wires, OEM and aftermarket but as clean as it gets!
AC lines, boost control solenoid, and vac lines ran
Active Autowerke fan clutch
Completed engine bay
Purty!
HPF who?
Enjoy!
-Shawn-
Old 02-19-2013, 06:49 PM   #85
Hageee
My Ride: E46 330xiA
Send a message via ICQ to Hageee
Original Trasmission Control Unit? No Chance to get this one working without CAN-H/CAN-L ! And you're unable to obtain a correct load-signal without using the MAF-Sensor. The Transmission will go into limp mode and write into the failure-memory: "FEHLER 08 - LASTSIGNAL"
And if it's working (what i didn't think, Sorry...) you will ruin your Level10 Tranny, becouse of wrong pressure apply to fwd clutch and tcc...
Hageee is offline   Reply With Quote
Old 02-19-2013, 08:21 PM   #86
A4RingedONE8T
Uh, relax and maybe read the thread? There will be a blow through MAF sensor, I even commented just at the top of this post that it wasn't installed yet and regardless if there wasn't, the person tuning this car knows what's up for this type of setup more than pretty much anyone on the face of the planet.
Old 02-19-2013, 09:04 PM   #87
Mr.Makeveli
My Ride: 2001 325i(sedan)
Lookin good man lookin good!
Mr.Makeveli is offline   Reply With Quote
Old 02-19-2013, 11:41 PM   #88
lab rat
My Ride: '02 330iT
holy sleeper!
Because sleeper
Old 02-19-2013, 11:58 PM   #89
lrinco01
My Ride: 01 Turbo M3, 10 'X5M
Send a message via Yahoo to lrinco01
yes, Yes, YESSS!!!!
Can't wait for Video's of this car running!
any chance this project will make it out to MFest VII ??
Leonel Aka " Rico"
BMWCCA # 403748
01 BMW E46 M3 / 6 SPD / Tiag / Imola
HPF Turbo....
Custom Built S54
Flex fuel
8XX rwhp
FOR SALE:
http://www.m3post.com/forums/showthread.php?t=727953
Custom Silver CF 6Speed E46 M3 sport steering wheel
http://forum.e46fanatics.com/showthread.php?t=1051908
lrinco01 is offline   Reply With Quote
Old 02-20-2013, 12:18 AM   #90
Commanderwiggin
My Ride: 900rwhp Turbo M3
Yes who's HPF car...sexy color that's for sure!
900+RWHP, PT6870 w/ Custom FSR Turbo Kit, AEM Infinity, Lab22 Motor
Old 02-20-2013, 02:37 PM   #91
Think0rz
My Ride: 05 AW M3
this thread just continues to deliver can't wait for the vids!!
Think0rz is offline   Reply With Quote
Old 02-20-2013, 02:50 PM   #92
777eThOd*
My Ride: spins too much
Yeah, this is gonna turn out to sick.. Can't wait!
2007 BMW 335i FBO 6MT - Current
2013 Nissan Nismo 370Z - Current
2004 Non-M Facelift Coupe - SOLD
2006 BMW M3 - SOLD
777eThOd* is offline   Reply With Quote
Old 02-20-2013, 03:35 PM   #93
A4RingedONE8T
Originally Posted by lab rat View Post
holy sleeper!
Indeed! Just what the customer wants!
Originally Posted by lrinco01 View Post
yes, Yes, YESSS!!!!
Video's as soon as it's going, should be visiting the east coast very soon for dyno tuning! Most definitely not going to Mfest, this car will be seen daily around the streets of Tampa and that's about it. The owner is not a boost junky or even a performance BMW junky, he just loves his 325 that he bought brand new from the showroom years ago and wants more power. After visiting another shop here in Tampa and being taken for a ride for a 1.5yr 205whp $18k build, he realized his loss, tossed the old setup and looked to us to build him what he was hoping for the first time around. Very few people will spend 18k on a turbo/motor setup in the first place, let alone spend it once, remove it at almost a complete loss, and then be ready to start over again just visiting our shop and speaking with us for the first time. Tony is a stand up customer most definitely deserving of this setup and I am extremely proud that he believed in me and our shop to build it for him, never with a bad attitude towards the car or questioning a budget considerably higher than his first go around. I only hope he loves the car and the way it turned out as much as I do, it's definitely taken him for a ride in the past, and hopefully a much better ride in the future!
Thanks guys! Very soon!!!
-Shawn-
Old 02-20-2013, 05:14 PM   #94
MarcusLSB
My Ride: X5, CT200h, CLK63 BS
Exhaust done, wheels mounted, hotside charge pipe complete
Dayum! Shawn always delivering the goods!
Old 02-20-2013, 07:14 PM   #95
Mr.Makeveli
Old 02-21-2013, 11:51 AM   #96
AAblown
Looking good boss
Old 02-21-2013, 12:55 PM   #97
A4RingedONE8T
Marcus, when you gonna let me build something for you??
ECU shipped to Nick G. of Technique Tuning today, another perfectly tuned DME coming soon to this car!
And a few more pictures
Old 02-21-2013, 03:04 PM   #98
Think0rz
My Ride: 05 AW M3
love it and for Nick G's tuning I'm very pleased man with his magic on my car
Old 02-21-2013, 03:06 PM   #99
A4RingedONE8T
Nick tuned my M-Roadster a few years ago, when it comes to stock DME tuning on certain platforms not many compare to him!
Old 02-21-2013, 09:17 PM   #100
TrippinBimmer
My Ride: Just Fast!
Amen!!!
Alpine White M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
