Old 02-23-2013, 12:38 PM   #101
sunnyjay
My Ride: 01 330i
Great Job.
Originally Posted by A4RingedONE8T View Post
Marcus, when you gonna let me build something for you??
ECU shipped to Nick G. of Technique Tuning today, another perfectly tuned DME coming soon to this car!
And a few more pictures
sunnyjay is offline   Reply With Quote
Old 07-02-2013, 05:01 PM   #102
wrecklessfool
My Ride: is paid off
Any updates on this? Surely it must be running and in the owner's hands by now. Any issues with components used or tuning difficulties? Thanks for sharing the last 6 pages of the build with the community. I'm inspired.
wrecklessfool is offline   Reply With Quote
Old 07-02-2013, 11:57 PM   #103
Sedan Hussein
My Ride: e46
So glad you bumped this thread
Sedan Hussein is offline   Reply With Quote
Old 07-03-2013, 12:52 AM   #104
daniel_f.
My Ride: 330iC
indeed, 4 month should be enough to see how the transmission is going.
Im currently at baby vacancy!
Siemens MS42 wiki!
Siemens MS43 wiki!
Old 07-03-2013, 01:07 PM   #105
A4RingedONE8T
My Ride: Turbo ///M Roadster
Yes the car was completed a few months ago. The Level 10 tranny lasted about 1,100 miles and lost 4th and 5th gear. The transmission is currently at a local trans shop getting torn down to see what failed and whether it can be built properly to hold the power or if we will just see the same failures again. If it can be rebuilt it will return, if not the car will be getting swapped to manual.
Here's the dyno results: 8psi, 12psi, and 16psi
-Shawn-
A4RingedONE8T is offline   Reply With Quote
Old 07-03-2013, 02:11 PM   #106
Miles Enrico
My Ride: 2003 330xi
Too bad about the trans. I'm looking forward to hearing their verdict on whether it can be built for that much power or not!
Miles Enrico is offline   Reply With Quote
Old 07-03-2013, 02:39 PM   #107
A4RingedONE8T
For $8,000 spent on the trans with Level 10 previously, I'd hope we would not be in this situation ...
Old 07-03-2013, 03:17 PM   #108
Twin_Turbo_S54
My Ride: M3
Is Level 10 the company WHO did modify the trans?
La ilahe illallah = God is one and only
Twin_Turbo_S54 is offline   Reply With Quote
Old 07-03-2013, 03:30 PM   #109
A4RingedONE8T
When the car came to us the trans had already been built by Level10
Old 07-05-2013, 08:04 AM   #110
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
Even to me, that sounds like a lot.
IPT charged me approximately $5k for cryo'd hubs/splines, all new friction disks and seals, as well as valvebody mods and re-done TC.
This is just me, but if I were to have a failure, I'd buy another transmission for parts, and send the "failed" items out to be cryo treated, then to WPC.
If this transmission has a lock-up torque converter, that would be a major concern of mine. The TCU normally locks up the converter at vehicle speeds of 120 km/hr or above. If you shift from 3rd to 4th at WOT, I've found the TC to be locked on engagement which is quite a shock to the drivetrain.
The only way I can think of making these shifts easier on the drivetrain is to lock-out the lock-up function, and let the shifts sit on the converter. (As you experience from 1 - 2 normally.) At this time the only way I know how to facilitate that is with a stand-alone transmission controller.
Old 07-05-2013, 10:20 AM   #111
Twin_Turbo_S54
My Ride: M3
The only way I can think of making these shifts easier on the drivetrain is to lock-out the lock-up function, and let the shifts sit on the converter. (As you experience from 1 - 2 normally.) At thiime the only way I know how to facilitate that is with a stand-alone transmission controller.
Adam,
You may use Gear Cut Load Cell. This will trigger an ignition cut when the transmission shifts up. This will decrease the stress on drivetrain.
You may not cut ignition and still keep the drivetrain happy, as the shifts are so quick the drivetrain is not unloaded. Faster shifts make the drivetrain almost 100 % loaded.
To shift faster you need to play around line pressures.
You can also unlock converter at certain TPS, where even a slight throttle closing will unlock the converter. Lets say back off a little till the TPS reads % 75.
@ 75 TPS the converter unloks..... then WOT and converter locks.
If I can make my 330 transmission solid to hold 800-900 whp I will be happy as well Till that time I am working on other transmissions.
Bear in mind some transmissions dont like to shift from 1st to 2nd very fast, some dont like from 4th to 5th.....this depends on the transmission model and brand.
Old 08-04-2013, 01:23 PM   #112
Miles Enrico
My Ride: 2003 330xi
Any updates on the transmission situation?
Old 08-05-2013, 07:42 AM   #113
A4RingedONE8T
Level10 offered minimal assistance so a 6spd ZHP swap is in progress
Old 08-05-2013, 07:56 AM   #114
mike@maximumpsi
My Ride: 02M3T
that is a better solution in the end
02 M3 - Maximum PSI S2 turbo kit - 9.74@145.99, stock motor, stock ECU, first in the 9's
97 M3 - Maximum PSI turbocharged - 8.94@164.33, stock ECU, first in the 9's, first in the 8's
16 M3 - Maximum PSI full bolt ons - 10.27@137, quickest in the US
BMW SOB's turbo E30 - 8.72@158.39
Maximum PSI - Home of the quickest BMW's in the US
Click here for E46Fanatics 1/4 mile standings
Follow us on Facebook and Instagram!
mike@maximumpsi is offline   Reply With Quote
Old 08-05-2013, 08:14 AM   #115
A4RingedONE8T
Oh yes!
Old 08-05-2013, 01:50 PM   #116
Viral@ActiveAutowerke
Past Site Sponsor
My Ride: E46 M3
Viral@ActiveAutowerke is offline   Reply With Quote
Old 08-07-2013, 08:46 PM   #117
secono330ci
My Ride: 04' 330ci/15' A3 TDI
Any ideas on the clutch yet?
Oh...and the "$300 here, $600 there" scenario will turn into "$3000 here, $6000 there". I've had an enourmous amount of labor put into my car. (Luckily the majority of it was done by myself) Also, I've spent over $5k on my tool set since I started my project. You've been warned...
secono330ci is offline   Reply With Quote
Old 08-08-2013, 08:34 AM   #118
A4RingedONE8T
Clutchmasters FX400 6 puck unsprung w/ CM Billet steel 16lb flywheel
Old 08-10-2013, 11:30 AM   #119
MalibuMafiaV
My Ride: E60 M5 & Stg3 AudiS4
Tony's Built 3.0l GT35R E46 325 4dr - Lutz Performance
Wow what a build!. Beautiful!
TheMalibuMafia.com
Instagram
BMW 2006 M5 - REALLY LOUD
BMW 2007 335i - ST GT35R
Audi S4 2000 Stage 3 - Dat turbo spool - SOLD
BMW 2000 3-series - Supercharged Because race car SOLD
Maserati 2004 M128 GT - HREs/tint/straight piped SOLD
BMW 2006 M3 - stock - SOLD
MalibuMafiaV is offline   Reply With Quote
Old 08-10-2013, 11:43 AM   #120
2000_328CI
2000_328CI's Avatar
My Ride: 328Ci | Range Rover
Oh em gee
| 435 HP 328Ci | RRT Racing | Designer Wraps | Active Autowerke | Vorsteiner | STATUS Racing |
Timeless Motor Group
