Old 11-29-2012, 02:24 PM   #1
Croat83
My Ride: E46 coupe
door opening and xenon fault?
Hi,
I just got myself 2001 320Ci and noticed two problems.
first, when I try to unlock the car it will unlock passenger side only if I press button for two times! Is this normal?
second, previous owner installed Depo projector headlamps with xenon, works like a dream but I get error on dash for non functional headlamps?
any solution?
Croat83 is offline   Reply With Quote
Old 11-29-2012, 04:33 PM   #2
Zell
Zell's Avatar
My Ride: so turbo wow
1. Yes, normal. One click does driver, and also reconnects the door handles to the lock mechanism internally, a second click does the passenger.
2. The Depo headlamps are most likely causing this error. I don't know how the E46 knows when lights are out, but I can almost bet that's the issue. Remove the Depo headlamps and go OEM Xenon. Get some used ones. Depo headlights are pretty low-quality anyway. The beam pattern is bad.
Old 11-29-2012, 05:13 PM   #3
Croat83
My Ride: E46 coupe
Thanks for answer!
one more...I have folding outside mirrors, is there any way to make them fold by pressing buttons on the key? I managed to fold them only from cabin switch
