E46 Xi Forum
Old 11-29-2012, 09:26 PM   #1
SlimE46
My Ride: 330xi e46
Vibration under driverside floor
Long story short i bought a POS. im stuck with it now and tryin to get in in ok condition. Recently when i drove my axel was clicking and i thought the combination of the clicking and vibration under my driverside floor was just the axel being bad. Changed the axel now and the clicking and crazy steering wheel vibration is gone but the abnormal annoying clunking and rapid shaking of what i think is the shaft that runs from the torque converter to the center differential is making the noise. Idk if its a bearning or the shaft is wobbling or what but does anyone know a test or what i can do to pinpoint this before it breaks? Its starting to get really bad its sooo loud and the vibrations are gettin worse by the week! This is my DD please help!
SlimE46 is offline   Reply With Quote
Old 11-30-2012, 06:21 AM   #2
tomoyer
My Ride: 03 325xi, 03 330xi
Send a message via Yahoo to tomoyer
Just a quick guess at your problem from what you have said, sounds like the center bearing and/or guibo are bad and it will get worse until they completely fall apart. These are on the main drive shaft and a PIA to inspect because you need to take the exhaust stem down and remove several covers.
tomoyer is offline   Reply With Quote
Old 11-30-2012, 06:26 AM   #3
jeepo23
My Ride: 02 330
This shaking you get, does it depend with climate? Or speed? RPM?
I have the same issue.. Replaced my rear axles.. still there. Mine happens between 2-2.5k rpm.. Also when its cold out.
GUIBO and CSB both replaced as well without any luck.
Im starting to believe its the subframe bushings that hold the differential in, which might be busted and have play in them now allowing the diff to move around.
Here is my thread on this vibration/jerk... lots of replies but nothing helped it.
http://forum.e46fanatics.com/showthread.php?t=951154
jeepo23 is offline   Reply With Quote
Old 12-03-2012, 12:07 PM   #4
SlimE46
My Ride: 330xi e46
My car does it usually when its cold out. Usually first drive of the morning on my way to work, lower rpms is really bad , very shakey and lots of rumble when accelerator is depressed, when i don't touch the gas it goes away
Old 12-03-2012, 12:10 PM   #5
jeepo23
My Ride: 02 330
I hear ya. Hop into my thread and see some of the advice.
Couple of us are trying different things to see if this gets resolved.
In leaning towards a bushing because its affected by temperature or something with the axles (even tho I rebuild and changed my rear ones)
Old 12-03-2012, 04:54 PM   #6
bmwbob89
My Ride: M-5 325 X3 528 740
Does it feel like your going over a rumble strip. If so its either a bad front axle or I've seen torque converters fail and do this.
bmwbob89 is offline   Reply With Quote
Old 12-03-2012, 09:52 PM   #7
SlimE46
My Ride: 330xi e46
Well i just replaced the front axel which was bad. The only way i can describe this in detail is as follows.
Sound: if you took two gears and spun them together, then on one gear took a bunch of teeth off of it and spun it together again. That chattery, break is what the sound is comparable too. Now add a little "rumble" from a fast rotation and thats exactly what it sounds like
Feel: when it happens, right under my seat or under my pedals it feels like a big ass rock is on a string swinging back and forth (left to right)
Old 12-03-2012, 10:10 PM   #8
SlimE46
My Ride: 330xi e46
I really think its my transfer case fml...
Old 12-03-2012, 10:33 PM   #9
SlimE46
My Ride: 330xi e46
http://www.bimmerfest.com/forums/sho...d.php?t=389924 my symptoms are exactly as described here. Only it does it when it feels like it..? I noticed today. In the morning it was pretty cold. Did it right away, then stopped for a second and drove normal. Then once i hit the highway it did it all the way to work. Then after work, it didnt do it for about 4 minutes worth of driving then all of a sudden bam! I hear the dreaded clunking and vibrations.
Old 12-04-2012, 07:23 AM   #10
jeepo23
My Ride: 02 330
Torque converter as in transfer case?
If it was a front axle you would feel it in the steering wheel, correct?
I believe you and I have different problems. You actually hear sounds? Did you change your fluids?
What's the mileage on your car?
Old 12-04-2012, 10:10 AM   #11
Sean McClellan
My Ride: 2004 325xi
Well now that makes 3 of us E46 XI owners who are experiencing the exact same phenomenon. Have you checked your transfer case input and output shafts for any play? (side to side, up and down)
Sean McClellan is offline   Reply With Quote
Old 12-04-2012, 12:16 PM   #12
miweber929
My Ride: 02 330xi
Make that 4, I am having the issues as well, hoping the shop will get back to me today with some ideas on what's up.
miweber929 is offline   Reply With Quote
Old 12-04-2012, 12:55 PM   #13
jeepo23
My Ride: 02 330
I got an idea.. everyone replace something different and their car and we see whose gets fixed.
1) Transfer case bushing
2) subframe bushings
3) new driveshaft or just rebalance old one
4) replace all 4 axles
5) put in a new torque converter
Old 12-04-2012, 01:58 PM   #14
SlimE46
My Ride: 330xi e46
Fortunately for ALL of us, i happen to work at a BMW dealership. Im going to try and have a technician look at it today. But they also have been saying that for a while now hence why I'm posting on here instead... Smh. Ill let you guys know what the verdict is asap and maybe we can get this problem solved.
Old 12-05-2012, 12:49 AM   #15
Derek325
My Ride: 2001 325xi Touring
My car as well. Just started a few days ago. Mine will only do it when driving over 50 mph and going up a hill around 2500 rpm. My front drive shaft out of the transfer case has a bit of play in it but I don't know that it is enough to cause the vibration. I am going to change the transfer case oil tomorrow and then remove the front drive shaft and take it for a drive to see if the vibration goes away. I will post my findings. In my car the vibration is at a higher frequency then the wheel speed which is why I am leaning toward it being in the transfer case or the front driveshaft.
Derek325 is offline   Reply With Quote
Old 12-05-2012, 06:39 AM   #16
miweber929
My Ride: 02 330xi
At this point the shop couldn't identify anything outwardly wrong, however they do think the transfer case case bushing may be completely failed and the carrier bearing is possibly suspect (though the guibo they said is in great condition).
They are getting a quote together on replacement of those and pulling the wheels to check balance and visually inspect wheel bearings and hubs today. Not sure if I'm happy nothing major jumped out or more pissed there is no clear fix and the consensus between 5 of us now is "no idea" and no fix.
I love this car, but the noises and feels it makes on trips and at higher highway speeds is annoying enough to sell the damn thing!
Old 12-05-2012, 06:53 AM   #17
jeepo23
My Ride: 02 330
If you have vibrations going up a hill its most likely your axles. Check your rear axle boots for tears or leaking grease.
Well you and I have a busted transfer case bushing in common. Maybe that is the culprit after all.
With my since its affected with tempature it could very well be?
Old 12-05-2012, 09:06 PM   #18
Derek325
Well, I removed the front driveshaft tonight to see if I could drive it without, but the front output shaft flange just slides into the t case so that was a no go. I changed the t case fluid anyways and went for a drive after work and no vibrations. Problem solved or just didn't do it today? Time will tell.
Derek
Old 12-07-2012, 11:58 AM   #19
jeepo23
My Ride: 02 330
Derek
Hate to say it but I think that was just coincidence. Maybe the temperature wasn't as cold but I'm sure your going to get your vibration again.
Any luck with you other guys on findings?
Old 12-07-2012, 06:41 PM   #20
wvBimmer3Series
My Ride: '92 318ic, '01 325xi
Noise Here Too
Did you find out any possible cause?
wvBimmer3Series is offline   Reply With Quote
