Go Back   E46Fanatics > Other BMW Models > General BMW Model Discussion
All non E46 BMW model questions in here. Look below for E36, E90 and F30 specific forum. For additional model specific forums check out bimmerfest.com!
Old 11-30-2012, 12:06 AM   #1
heath\
My Ride: BMW
Angry I have e39 2000 540i HELP!!! :(
My brother was driving to school, and the car suddentley turned off on him..no noise or anything different.. He went to turn it back on and the temperature gauge SHOT up!!! But the car just left the house, it isnt hot..and not at 9 pm it's still at hot but the car never got hot!!!!! Help!!!!
heath\ is offline   Reply With Quote
Old 11-30-2012, 12:41 AM   #2
eneka
My Ride: 2003 325i
belt broke=alternator and water pump stops working=dying and overheating car
btw wrong forum.
eneka is offline   Reply With Quote
Old 11-30-2012, 12:46 AM   #3
heath\
My Ride: BMW
sorry but my car didnt overheat thats the thing!! when the tow truck came i was 1.3 miles from my house! it wasnt hot! it is now almost 10pm and when i turn the key in the car it still says hot but the car has BEEN cold!! and yes i know i am in the e46 posts but im desperate !!!! HELP!!!
Old 11-30-2012, 12:52 AM   #4
peytonracer4
:D
peytonracer4's Avatar
My Ride: '00 328i
Why did the car shut off? Did a belt actually break?
It sounds to me that you have some electrical issues. Check you battery to see if its good. Disconnect it for an hour.
Old 11-30-2012, 03:53 AM   #5
lucky_doggg7
My Ride: 2005 M3
On a M3, the ECU uses the water temp sensor to determine how warm/hot the engine is; it does not use a separate sensor that is screwed into the aluminum head, like that in the older Bosch FI systems.
I would guess that the BMW ECU would be "intelligent enough" to protect the expensive engine by shutting the car down if it detected a very high water temp from its sensor. If the E39 FI system is anything like the E46 M3 Siemens FI system, try buying a new water temp sensor and replace the old one and then see what happens. If replacing a water temp sensor doesn't appeal to you, take it to a shop that has a OBD II scan tool that can specifically read all the 540's sensors, and any stored trouble codes. Not all scan tools are created equal; most descent one's obtain generic info from the OBD II system, but you want the one that goes beyond generic info; you want a scan tool that can read and test all of the 540's electronics in the engine bay. That is the difference between a $250 scan tool and a $3,000 dollar scan tool. Good luck fellah.
Old 11-30-2012, 04:19 AM   #6
RayPooley
My Ride: 320i SE Coupe
^^^^ Sounds like sound advise.
Old 12-03-2012, 11:44 AM   #7
tim330i
E46Fanatics Owner
tim330i's Avatar
My Ride: 03 Ti Silver M3
Check out the E39 forum on Bimmerfest.com for help from other E39 owners -
http://www.bimmerfest.com/forums/forumdisplay.php?f=103
Tim
tim330i is offline   Reply With Quote
2000, 540, 540i, bmw, e39
