Old 11-30-2012, 12:27 AM   #1
DBrown
My Ride: BMW 325 Ci
Washer fluid leaking
So I've owned my car for a while now, and I top up my fluid regularly. Tonight for the first time I had my fluid level low sensor trip. Got out, tank is bone dry. So I top it up to have all the fluid I put in, pour out all over my feet. I lifted the tank out and inspected it, tank holds fluid fine. Fluid seems to be leaking out of the front sprayer on the passenger side, or something around there. Is there a specific weak point of the system around there? Anyone ever experienced this ?
2001 325 Ci
DBrown is offline   Reply With Quote
Old 11-30-2012, 10:39 AM   #2
BimmersGarage
My Ride: E46 330i
Only thing I can think of is an internal leak/failure of the washer pump unit. When that happens, it allows fluids to pass through. Check to see if there is any evidence around the unit, usually you'll see rust residue...
BimmersGarage is offline   Reply With Quote
Old 11-30-2012, 10:46 AM   #3
GT172I
My Ride: M3 ZCP, 335is, 330ci
I also had a leak on mine where the pump for the headlight washers wasn't sealing properly to the tank gasket. Of course I found this after disassembling and cleaning the entire headlight/hose/sprayers. Slapped a little RTV on it and good to go. When I was researching it however I did find a couple instances of the check valve on the sprayer failing and allowing fluid to dribble out.
APEX ARC-8's | UUC EVO3 SSK | UUC TSE3-L | H&R sways
Stebel Truck Horn | Misc cosmetic stuff
GT172I is offline   Reply With Quote
Old 11-30-2012, 07:43 PM   #4
DBrown
My Ride: BMW 325 Ci
Took mine apart today, when you fill it up it leaks out around the headlight washer cylinder (the part that extends out) so gotta replace it and the nozzle looks like. Ordered parts from ecs, should get em in a few days. For anyone who has the same problem as mine here's a good, DIY. It's relevant to all years mines an 2001 and came apart the same as the DIY.
Here's the link,
http://forums.bimmerforums.com/forum....php?t=1757442
2001 325 Ci
Old 03-13-2014, 04:33 PM   #5
aftCG
My Ride: 330i
Not to blow too much dust off of an old thread, but my left headlight was leaking washer fluid and it was the cylinder as pointed out in the last post. $65 part on ebay, so not the cheapest repair I've done but not too bad.
The link posted is a good DIY write up. The cylinder itself is not serviceable, so I'm on the hunt right now.
aftCG is offline   Reply With Quote
washer fluid leak
