General Off-Topic
Old 11-30-2012, 10:17 PM   #61
yousharenow
My Ride: E46 ZHP
Send a message via AIM to yousharenow
The new Bodystyle is Siiiiick. And they fixed a lot for the engineering issues I had with earlier models such as turbo placement.
yousharenow is offline   Reply With Quote
Old 11-30-2012, 10:48 PM   #62
Lair
My Ride: e90,e90, $5k Boxster
Originally Posted by v8 5 View Post
you have two of the least desired convertibles on the planet, what are you talking about...
Why aren't you driving an Audi?
The Hunter S Thompson of e46f.
Lair is offline   Reply With Quote
Old 11-30-2012, 10:56 PM   #63
NFSx328ci
My Ride: TiAg E46
I would only take a new S5 but not to replaced a BMW. Just as a second daily driver
My babies; Supercharged 328ci, 2009 Alpine White 135i.
625awhp 99 GSX(SOLD), Straight Piped 2011 Grand Cherokee (SOLD)
NFSx328ci is offline   Reply With Quote
Old 11-30-2012, 11:07 PM   #64
SLVR JDM
My Ride: 4Runner
My next sedan will be an A6.
SLVR JDM is offline   Reply With Quote
Old 11-30-2012, 11:12 PM   #65
BMW_Matt
My Ride: Has AWD
Thinking next car will be a b5 s4.
BMW_Matt is offline   Reply With Quote
Old 11-30-2012, 11:19 PM   #66
Five_seveN
My Ride: rover james
Send a message via AIM to Five_seveN
see sig
Originally Posted by VaderDave View Post
I'm having a hard time imagining any set of responses that ends with anyone expressing admiration for Marshmallow.
Perhaps you should stop responding. It's a no-win for you here. :dunno:
Five_seveN is offline   Reply With Quote
Old 11-30-2012, 11:36 PM   #67
TerraPhantm
My Ride: M3 & ZHP
I would consider the new S4. Or any RS models if Audi ever starts importing them to the US again.
Old 11-30-2012, 11:41 PM   #68
Grande D
My Ride: E36 M3
The RS5 is.
I like all the new Audis. They're really great.
But every single one of them is just a tad boring.
It will change your life!
Old 11-30-2012, 11:57 PM   #69
jfoj
My Ride: 330CiC, M5, X5
Keep your E46 so you have something to drive when your Audi is getting repaired!!
Old 12-01-2012, 12:00 AM   #70
sea6speed
My Ride: 2010 335i Msport 6MT
You have absolutely no idea what you're talking about, tell me why I can't even change my serpentine belt without two special order BMW tools
Because you don't own a 3 series? Belts are as easy as an oil change if you have a manual.
sea6speed is offline   Reply With Quote
Old 12-01-2012, 12:02 AM   #71
morningisbad
My Ride: E46 M3 Vert
Considered an A4 as a winter car. Nice comfortable interior and AWD.
"When makin' a questionable decision, sometimes the only way to find the answer is to shut your eyes & mash the pedal to the metal, you guys."
-Karl Welzein
morningisbad is offline   Reply With Quote
Old 12-01-2012, 12:08 AM   #72
PH03NIX46
My Ride: 2003 M3
If I were looking at a winter beater, it'd be either an old TD Jetta (45mpg FTW!! and they're cheap), or a Subi of some sort.
Other than that...there was an $800 240sx for sale here not too long ago. I wish I had picked it up. Not a good winter beater...but hell, an $800 240sx..!
Eibach | Sportline | OEM Euro Headers | TTFS
PH03NIX46 is offline   Reply With Quote
Old 12-01-2012, 04:08 AM   #73
tystager93
My Ride: 2003 325XI
Get a C4 S4, they actually run 7 days a week. And are at a bargain now.
tystager93 is offline   Reply With Quote
Old 12-01-2012, 04:17 AM   #74
tystager93
My Ride: 2003 325XI
Originally Posted by MercForHire View Post
no
t
There needs to be a +1 button or something on these forums.
Old 12-01-2012, 07:06 AM   #75
mistrzmiasta
My Ride: GLK350,ML63, Duc1098
i once owned a volkswagen product disguised as a high end car , cayenne turbo. never again.
mistrzmiasta is offline   Reply With Quote
Old 12-01-2012, 07:24 AM   #76
WDE46
My Ride: 2004 330Ci OBM
Do you even own an E46? Everyone knows you only need a large adjustable wrench and a long screw driver to remove the fan. You can waste your money on the tool if you want. Getting the fan out is not hard. A belt replacement takes less than an hour if you're not incompetent.
no
Wow I'm glad someone else has noticed this car. I saw one on the road and thought "WHAT THE **** IS THAT? WHO THE HELL WOULD BUY THAT?" They really created a total abomination. This thing beats out the Pontiac Aztec. At least the Aztec was functional and it's in Breaking Bad. This Nissan thing is just ridiculous. The wheel fitment is one of the worst parts. They are like 4 inches in from the fenders and too small diameter overall.
Old 12-01-2012, 07:48 AM   #77
NOVAbimmer
My Ride: E60M
Yes, we're considering a Q5 to replace the 330
NOVAbimmer is offline   Reply With Quote
Old 12-01-2012, 09:49 AM   #78
Kyhai
My Ride: What ride?
I recently moved up from a AWD B5 A4 to a e90.
One thing I absolutely miss about the Audi is the security it provides in the wet and snow. Never felt that same sense of safety in the BMW driving in the same conditions.
Quattro > xi
Issues with the Audi?
Power steering rack leak
Vacuum line (brittle because of the heat)
Coolant flange (shittest design EVER)
Water pump and timing belt
Head gasket leak
Failed coil packs (recall)
O2 sensor
Seat heater
Front brake calipers stuck
Busted timing chain tensioner
Crankshaft seal leak
The Audi only had 130,000 miles on it and over $6,000 in repairs.
Kyhai is offline   Reply With Quote
Old 12-01-2012, 10:56 AM   #79
DUH I4GOT
My Ride: 2002 Silver 330 Ci
Send a message via AIM to DUH I4GOT Send a message via Yahoo to DUH I4GOT
I went from BMW to A6 Quattro. Well, BMW to Infiniti M45. Kept the M45 for 4 months then went to the Audi. Had the A6 for three trouble free years. Wanted another BMW but with the lack of a dealership around here I went with a Mercedes. Loved the drive/handling of the BMW but loved the Interior of the Audi best.
"You forgot that most of the people on this board are bangin' supermodels on a nightly basis, inbetween rounds of Halo 2 and bowls of Mac N cheese of course."
AVRed1
DUH I4GOT is offline   Reply With Quote
Old 12-01-2012, 11:06 AM   #80
mistrzmiasta
really? it's like a christmas tree in there. in my friend's q7 you have to connect a laptop to put the heat on high. it's like 3 years old i think and has a bunch of dead pixels already.
