Old 11-19-2012, 12:25 AM   #1
hoang031
My Ride: 01 325i
White smoke comes out when starting car
There seems to be white smoke that comes out in a burst whenever I start my car in the morning. After I drive around for a while and park/shut off my car. There's a burnt smell coming from my exhaust. What's going on?
Mods completed:
Dynavin clone install
Rear camera install
Alarm install
Eurotray with DIY micro/mini/ipod charging cable mod
Mods in progress:
OEM flashlight upgrade mod
hoang031 is offline   Reply With Quote
Old 11-19-2012, 07:49 AM   #2
Charl_323
My Ride: 323ci
Coming out of the pipes? Or from the pipes... from means something dripping out the pio
Pes check oil level car using oil? Do compression test. Let us know what you find
Charl_323 is offline   Reply With Quote
Old 11-19-2012, 09:27 AM   #3
Teddy7
My Ride: slides
Check your coolant level/color first and foremost. It's super quick/simple and will answer a couple questions. There are multiple scenarios which could be causing this. (Could be related with your valve stems, headgasket, etc.), but I wouldn't get too worried yet. Is the smoke white or does it have a blue tint to it? Could be worn piston rings. So two things first: check coolant color/level and try to determine hue of the smoke.
Teddy7 is offline   Reply With Quote
Old 11-19-2012, 09:32 AM   #4
Nerdy46
My Ride: 328i
Assuming the smoke is light blue in color id think your valve seals are shot. However it could just be condensation, it is getting cold out.
Nerdy46 is offline   Reply With Quote
Old 11-19-2012, 10:55 AM   #5
jasonbimmer
My Ride: 2001 BMW 330xi
its getting cold out so probably just some steam. we always get questions like how to change time twice a year and smoke from the exhaust when winter hits here.
2009 Mazda RX-8 R3
2013 Toyota FJ Cruiser
2008 YAMAHA YZF-R6
Old 11-19-2012, 11:01 AM   #6
aahmed2016
My Ride: 2003 330i ZSP/CP/PP
I would put my money on its just because its cold
Originally Posted by MercForHire View Post
Spends $2000 on car DVD + stereo -> Running 25000 mile oil changes and 87 gas with blown shocks
aahmed2016 is offline   Reply With Quote
Old 11-19-2012, 12:33 PM   #7
taveet330i
My Ride: Jet Black 2002 330i
It could be that you are burning rich meaning that your oil is mixing and burning
Dedication
_______________
Dedication
2002 Jet Black 330i|ZPP|Hellbeige interior|Carbon Fiber Interior Trim|Alzor 703 CSL Reps|Custom Flowmaster Catback Exhaust|LED Halo Rings|Black ECSTuning Kidney Grilles|Eonon D5150|
taveet330i is offline   Reply With Quote
Old 11-19-2012, 01:07 PM   #8
Nerdy46
My Ride: 328i
Dedication
running rich means your air/fuel ratio is off. Too much fuel.
Old 11-19-2012, 02:53 PM   #9
hoang031
My Ride: 01 325i
Just tried it again this morning at 53 degree F. It's WHITE smoke coming out in a burst when I start the car.
When I gun the pedal and it hits around 55-60, white smoke comes out of the exhaust in a burst.
Mods completed:
Rear camera install
Alarm install
Mods in progress:
Old 11-19-2012, 02:55 PM   #10
lcoleman
My Ride: '79 Massey Ferguson
Yep. Smell it, too.
Old 11-19-2012, 03:02 PM   #11
jasonbimmer
the thing is does it go away when the engine is warmed up?
2009 Mazda RX-8 R3
2008 YAMAHA YZF-R6
Old 11-19-2012, 03:46 PM   #12
NJFF26
My Ride: 02 325xi
Maybe CCV since its getting colder. Pull the connection off the VCG and see if its all mayo'd up. Quick check
NJFF26 is offline   Reply With Quote
Old 11-19-2012, 04:04 PM   #13
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
I'd start with a full tank of gas with Techron added first and a nice long drive of maybe an hour or so...and check fluids beforehand...and have extra with you...just in case.
It could be just water vapor because you don't drive enough...though that extra burst at speed could be head issue, ccv, seals too.
If you just got this car, then head/seals issue maybe is a little higher odds...but if you've had the car a while and this is the first of these symptoms...and you haven't overheated the car...then probably ccv...there's a chance the long drive will fix you up.
See me in June!
dmax on Facebook
Mangofy your E46!
Old 11-19-2012, 11:33 PM   #14
Charl_323
My Ride: 323ci
white oil burst sounds alot like oil. can be worned out rings or valve stem seals or even valve guides. smell it if it smells like oil. if its condensation it wont smell like oil obviously.
Old 11-20-2012, 08:17 AM   #15
IxNay
My Ride: 2000 328Ci 5sp SP
Could also be a leaky head gasket. I hope not for your sake, but it could be. Check your oil and coolant levels - see if you are losing fluid. Check the condition of your oil and coolant - if you have oil in your coolant, or coolant in your oil. Any of these conditions point to a leaky head gasket.
IxNay is offline   Reply With Quote
Old 11-30-2012, 09:06 PM   #16
njbmw90
My Ride: 2004 M3 CB/CINN
I have same problem thinking of having the valve stem seals changed. Anyone know of a cost to do it roughly?
njbmw90 is offline   Reply With Quote
