e 46 engine knock (after oil change to non-synthetic oil) -attached video as well - Page 3 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 12-04-2012, 03:15 PM   #41
maurer
My Ride: 04 Coupe
Doesn't sound like a rod knock to me either.
maurer is offline   Reply With Quote
Old 12-04-2012, 03:29 PM   #42
Guest021715
Account closed.
Originally Posted by 330iPilot View Post
LOL on all of those that think changing to regular oil had something to do with it. Car engines don't benefit from synthetic oil other than extended oil change intervals. Synthetic oil was originally developed for jet engines because regular oil couldn't withstand the temperatures and pressures that turbine engines produce. Conventional car engines won't produce temps or pressures high enough to break down the lubricative properties of conventional oil. There have been numerous studies done on this.
That being said, I still put synthetic in my BMW!
A little history on synthetic oil:
http://www.oil4kids.com/syn-hist.htm
Originally Posted by ilkercatal View Post
i WENT TO A BMW mechanic today here in brooklyn ( guy used to work at bmw factory in ermany, a russian guy)
He listened to the noise and he says 95 percent chance is the lifters. i told him will this sieze the engine, he goes i dont think so. I asked him also, how much to repair and he says 1000 to 2000 depends what is needed. So since my car is only worth like 3000$ i am just going to use it as it is and do all other maintence and live with this small noise. Or, if one of ya'll can give me a link on how to do this lifters change ( is it expensive to buy the parts, is it tedious job to do).
$1-2k for what? I'd get a new mechanic.
Did you check your spark plugs even? Sounds like one is loose or an exhaust leak.
Old 12-04-2012, 03:47 PM   #43
Stinger9
My Ride: '04 330Ci
Probably not prohibitively expensive to DIY, but the problem is you've got to remove the cams to get to the lifters. And that means you'll be messing with cam timing and removing the timing drive chains. Can be tricky.
I believe there are special tools designed to pull the lifters up and out of the head to swap out with the new ones.
Old 12-04-2012, 04:06 PM   #44
madunix
My Ride: Silver 01' BMW 325ci
cool video!
madunix is offline   Reply With Quote
Old 12-04-2012, 04:19 PM   #45
SeanC
My Ride: 330i
Can't believe most people on here never heard of lifter ticks before.
Car is at 180+ thousand miles, and the noise started happening after an oil change with some dyno noise. This is what happens if you don't use correct viscosity oil in high-mileage engines.
Just change the oil with the most viscous LL-01 synthetic to help with the noise next time around. It may still be there, but I wouldn't try and open up the engine just because of this.
Edit: Lifter noise is very common in e36 and e34 circles. The cure is what I said above.
Black Sapphire MetallicNatural BrownSilver Cube e46 330i ZHP/6MT - Sold
HellrotDove Grey e36///M3 - RIP
Black Sapphire MetallicNevada BrownDark Bamboo e70 X5 xDrive4.8
Alpine WhiteCoral RedAluminum f30 328i Sportline/6MT
Imola RedBlackBlack Aluminum e46 330i ZHP/6MT
SeanC is offline   Reply With Quote
Old 12-04-2012, 04:22 PM   #46
TerraPhantm
My Ride: M3 & ZHP
Not quite. The other advantage to synthetics is that they can be exposed to higher temperatures without degradation. An engine that's designed to run on synthetics may have a few localized regions of high temperatures.
Old 12-04-2012, 07:00 PM   #47
330iPilot
My Ride: Titanium Silver 330i
Not high enough to coke conventional oil. You need way higher temps than any regular old street car engine can produce.
330iPilot is offline   Reply With Quote
Old 12-04-2012, 07:45 PM   #48
Sapote
My Ride: E46 2000 323i wagon
non-synthetic oil won't damage or cause engine knock guys!!! engine oil is for engine. Synthetic oil might have other benifits (last longer between oil changes, ect.) but is not necessary.
Sapote
Sapote is offline   Reply With Quote
Old 12-05-2012, 03:26 AM   #49
sprintman
My Ride: Ex 325CI owner
Sapote
Sorta true, but the specs are. The E46 (non M) oil needs to have a viscosity of approx 12.0 cSt @ 100C, and a minimum HTHS of 3.5. Most XW30's don't come close to meeting these specs. This is why it's easier to just buy LL01 oil, or oil that at least meets ACEA A3,B3.
sprintman is offline   Reply With Quote
Old 12-05-2012, 04:42 AM   #50
cranker
My Ride: 2003 330 convert
changing the oil, has no effect on the engine i've had four bmw, i used 20w 50 in everyone engine ran fine the amount of time and mileage is the difference.
cranker is offline   Reply With Quote
Old 12-05-2012, 05:27 AM   #51
TerraPhantm
My Ride: M3 & ZHP
Perhaps in a single instance, but take higher than average temperatures over an extended period, and you've got an oil that probably wouldn't even last the usual 3K miles.
In this case, chances are the non-synthetic was pretty far from the specifications required of the E46.
Old 12-05-2012, 12:45 PM   #52
330iPilot
Higher than average temps aren't going to do it either. You need temps that regular internal combustion engines are incapable of producing in order to destroy conventional oil.
e46 engine knock
