The infamous P0174 and P0171 problem - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 11-30-2012, 04:41 PM   #1
E462005
My Ride: 2005 325
Changed out both lower and upper intake boot and cleaned out MAF sensor.....cleared the codes and now they are back.
E462005 is offline   Reply With Quote
Old 11-30-2012, 08:38 PM   #2
tommy d
My Ride: 2005 330i
You have an air leak somewhere else. Keep looking.
Current Vehicles in my stable:
2005 BMW 330i - 126K miles
2005 Mazda Tribute s - 117K miles
1998 Ford Taurus SE - 115K miles
1987 Ford Mustang LX 5.0 - 248K miles
tommy d is online now   Reply With Quote
Old 11-30-2012, 09:12 PM   #3
jfoj
My Ride: 330CiC, M5, X5, E93
Suggest you read the first link below in my signature.
I think you may find a few possible solutions in this post?
Old 12-01-2012, 01:59 AM   #4
GLOK1132
My Ride: 2002 325i
+1 Solved my problem with a new DISA O-ring.
GLOK1132 is offline   Reply With Quote
Old 12-01-2012, 08:22 PM   #5
Hamsocne
My Ride: 2002 330Ci
I replaced the Disa and that P0174 code went away.
Hamsocne is offline   Reply With Quote
Old 12-01-2012, 10:23 PM   #6
E462005
My Ride: 2005 325
I'm going to have to check on that DISA. I've taking it out before but that was several months ago o ring looked fine but I will double check
Old 12-02-2012, 05:04 AM   #7
jfoj
O-ring ALWAYS looks fine, but it is garbage and the fit is important.
If you remove the DISA and the first 1/4" of movement offers no resistance, the DISA basically falls out, you need to replace the O-ring. Also note there are other problems that the DISA can have as well as MANY other places for vacuum leaks to occur.
Even if the DISA O-ring solves or improves your problem, likely you have other problems with the SAP vacuum lines, CCV lines, intake boots and crankcase leaks.
Old 12-02-2012, 10:29 AM   #8
Orchazum
My Ride: Steel Grey 330i
Oh the frustrations , be sure to read jfoj threads , very good write up.just hope your not in my situation
Multi Color Angel Eyes, MD, K&N, Sharked, Y-Rated Shoes
Orchazum is offline   Reply With Quote
Old 12-03-2012, 07:44 AM   #9
loangolfer
My Ride: 2001 330x1
Long time reader first time writer. Thanks to all that participate in this forum. You guys are great! Got my wife a 2001 330xi in '09 been replacing & fixing ever since.Just finished the PVC /cold weather update. What a bear! It took 4 dip stick tubes & 4.5 weeks in the garage because the M54 in the XI is somehow different from the other 3.0's. I ended up cutting a notch in the tube (11 43 7 531 258) where the original had pressed in dimples. Now the P0171 P0174 codes came up. Based on the wretched condition of the tubes I took out for the PVC thing the DISA sounds like the next update I will do. Bavauto gets $209.95 for a new one, but I found a kit so I will try that as it's ($75-80) cheaper! BTW.... no I will not be trading this baby in as the wife LOVES it, so I will be checking here for info for my next Bimmer fix.
loangolfer is offline   Reply With Quote
Old 12-03-2012, 07:46 AM   #10
loangolfer
My Ride: 2001 330x1
Sorry guys here is link for the DISA repair kit.
http://www.germanautosolutions.com/b...repair_kit.php
Old 12-03-2012, 07:59 AM   #11
SeanC
My Ride: 330i
We all know about this kit. It won't solve your DISA problem 100% if the problem is with the diaphragm inside the DISA. The kit is good for the problems with the flap. A new DISA is $173 from thebmwpartstore.com.
Black Sapphire MetallicNatural BrownSilver Cube e46 330i ZHP/6MT - Sold
HellrotDove Grey e36///M3 - RIP
Black Sapphire MetallicNevada BrownDark Bamboo e70 X5 xDrive4.8
Alpine WhiteCoral RedAluminum f30 328i Sportline/6MT
Imola RedBlackBlack Aluminum e46 330i ZHP/6MT
SeanC is offline   Reply With Quote
Old 12-03-2012, 08:07 AM   #12
jfoj
^+1 Amen, logical minds do exist!
GAS kit is not the end all solution.
If you want a solid solution, buy a replacement OEM DISA, buy 2-3 of the correct size O-rings (3/32" thickness for the 325/330) and install a new O-ring on your new DISA before you install it in the intake. The injected silicon O-ring on the original DISA is crap anyway. Put the other 2 O-rings in an envelope in your trunk or glovebox.
You will have no problems for another 8 years and if you need to replace the O-ring in the next 8 years, you have them in stock and it will only take you 30 seconds once the DISA is removed again.
