Old 08-05-2015, 04:48 PM   #1
mr_y82
My Ride: 01 325xi Sedan
Valeo SMF non-SAC kit
edit: meant to include this more thorough review:
http://forum.e46fanatics.com/showthread.php?t=958649
I replaced my stock DMF and clutch with a Valeo SMF kit early this year, around 175,000 miles. I have about 4,000 on the kit so far and love the engagement, feel, and responsiveness (granted I don't know what the car felt like pre-172,000 miles... my only experience was with the worn DMF...see 3rd video).
As the weather warmed I did notice some gear (lash) rattle (clutch chatter to some), and wanted to post video(s) to warn potential Valeo customers, and to get people's thoughts on the severity. I can only really hear it in neutral with the clutch pedal out; inside the car, with windows up, it is not very apparent at all. So, it's not a nuisance, but is it a long term problem? I didn't expect this much noise from a sprung clutch disk and flywheel nearly as heavy as stock.
My parents are from the midwest, but I am in the south... was feeling it today, so excuse the accent, haha!
outside:
inside car, but door open:
tired old DMF!!!
part numbers:
Valeo 52401220 Clutch Conversion Kit
Below is for reference. I purchased the kit from FCP Euro, not Amazon...
http://www.amazon.com/Valeo-52401220...leo+clutch+kit
mr_y82 is offline   Reply With Quote
Old 08-05-2015, 05:10 PM   #2
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
I don't think that that's clutch "rattle".
I've had the UUC single disc LTW clutch kit ($1098) which weighed in at 24.5 lbs, it had what I'd refer to as typical clutch rattle. Using UUC's recommended clutch fluid "cocktail", my rattle got better, as in not as much chatter/rattle.
I then moved on to a UUC Twin disc LTW clutch setup, it weighed in at 25.5 lbs, this one extra pound of weight lessened the chatter/rattle by close to 50%. As a reference the Stock OE clutch & flywheel weigh in at roughly ~38 lbs, IIRC your Valeo kit weighs in at roughly ~37 lbs.
So to my ears, that does't sound like rattle to me. Maybe a bad throw out bearing ??
Rob43
SUMMIT POINT WV 1:24:229 SCCA
Old 08-05-2015, 06:06 PM   #3
mr_y82
Thanks. I considered that... didn't want to... My friend has a shop and did the install... He may have mentioned the provided throw out bearing didn't look great. I'll have him give it a listen.
Old 08-05-2015, 08:02 PM   #4
Jaundiced Outlook
My Ride: has a tailgate
The faint rattle I occasionally hear with my Valeo kit doesn't sound like that at all. I think you've got something else going on, as Rob43 mentioned.
2001 325iT 5-Speed
Jaundiced Outlook is offline   Reply With Quote
Old 08-06-2015, 05:39 PM   #5
mr_y82
Well great! lol... So... What damage am I doing until I get it fixed? Not really in a rush to drop the XI trans again... was not cheap! Maybe I can contact Valeo...
Old 08-06-2015, 06:08 PM   #6
Rob43
Rob43's Avatar
"IF" this problem of yours is really a noisy TOB, assuming it doesn't grenade it could easily go for years without any problems. So you could live with this problem year after year with no worries.
Rob43
Old 08-06-2015, 06:39 PM   #7
mr_y82
Cool... I'll jut pretend LWFW... RACECAR! heh.... My mechanic buddy will give it a listen tomorrow.
If it grenades... well I can cross that bridge if I get there.... For now my $4,700 car still drives great!
Old 08-07-2015, 09:51 AM   #8
RudyT
My Ride: 2001 330i
If it was the throw out bearing, you'd hear the noise when you press in the clutch. If the rattle goes down when A/C load is off, then it's clutch rattle.
RudyT is offline   Reply With Quote
Old 08-07-2015, 11:25 AM   #9
mr_y82
^noted... thanks!
Old 08-30-2015, 03:41 PM   #10
Andreasmario
My Ride: 330ci
Or pilot Bering ? Was the gearbox totally quiet before?
Andreasmario is offline   Reply With Quote
Old 08-30-2015, 05:57 PM   #11
mr_y82
^yes, I never noticed the noise before... if I had I would think maybe a front bearing in the transmission... I also posted back on the other thread:
http://forum.e46fanatics.com/showthr...958649&page=12
Thanks!
H&R Sport Springs on Bilstein Struts; Valeo SMF, non-SA Clutch, CDV delete, and E60 Shifter w/ ZHP knob; Beisan System VANOS Seals...
Mtech-II Front Bumper (PO got bumped in parking lot!); Eagle Eye LED Tail Lights... Lots of PM!!!
Old 11-19-2015, 12:03 PM   #12
MadToha
My Ride: E46 330 ESS Touring
Does anybody know what is the Valeo 52401220 kit's clutch disk size? 228 or 240mm?
E46 M54B30 MT Touring | ESS TwinScrew + SS Headers + S38 Flywheel&Clutch + MFactory LSD 3.07 + Koni Sport + Eibach Pro + ///M3-Look
imBMW.net = BMW + iBus + .NET MF + .NET PCL & UWP + Bluetooth + Arduino + STM32 + music + handsfree + DIY + DBus DS2 DME Logging + etc...
MadToha is offline   Reply With Quote
Old 11-28-2016, 06:50 PM   #13
mr_y82
^Sorry, a year late I do not....
I was watching some motortrend videos and found the exact sound of this kit... Don't feel so bad about it now, but upset Valeo never responded to multiple polite inquiries... They could have told me "it's just a Porshe noise" (kidding). Have to skip to 7:42, my timed link did not work.
chatter, clutch, gear rattle, smf, valeo
