Old 12-08-2012, 12:05 AM   #1
andycai
My Ride: M3
Question How to jumpstart 2002 M3
Hi Folks, I came back from vacation and found my M3 battery is discharged. I tried to jumpstart it using another car (2009 VW Routan) without success(lights are on but car won't start). Any thoughts? Thanks for the advice.
Ps. I did research before I post.
andycai is offline   Reply With Quote
Old 12-08-2012, 12:08 AM   #2
tks
My Ride: slower than yours
Roll it down a hill and get in second..
WTB:: Natural Brown Sedan Full Interior
tks is offline   Reply With Quote
Old 12-08-2012, 12:09 AM   #3
330ciandr6
My Ride: .
Send a message via AIM to 330ciandr6 Send a message via Yahoo to 330ciandr6
Battery is probably incredibly weak, and its possible it won't hold a charge. Either replace the battery, or let it charge for a while off of the VW while its running.
Have a oil or coolant leak? Click here!:http://forum.e46fanatics.com/showthr...732&highlight=
ABS/DSC/Brake/Airbag light on?? Click here!:http://forum.e46fanatics.com/showthr...648&highlight=
330ciandr6 is offline   Reply With Quote
Old 12-08-2012, 12:20 AM   #4
andycai
My Ride: M3
Old 12-08-2012, 12:51 AM   #5
peytonracer4
:D
peytonracer4's Avatar
My Ride: '00 328i
When the batteries die in these cars they're typically dead.
I know when my battery died it was toast. I had to get a new one.
Old 12-08-2012, 11:04 AM   #6
tylermaslanik
My Ride: 3 Pedal 323Ci
Sounds like the battery needs to be replaced. Check it with a voltometer or multimeter though. Might be something else.
tylermaslanik is offline   Reply With Quote
Old 12-08-2012, 11:08 AM   #7
tock172
My Ride: '12 135i DCT
Likely the original battery. Don't be fooled and throw your money away for a Bosch battery or something like that. Our cars take conventional batteries that are available all over the place. I'm not 100% sure about the M3, but for non-Ms a battery from almost any auto parts store with a good warranty/return policy will fit perfectly. There are only ~3 car battery manufacturing companies on earth. The only real difference between all the batteries on the market is the labeling and the price.
Past: 1999 Techno Violet Metallic M3
Present: 2012 135i DCT
Old 12-08-2012, 01:05 PM   #8
Chris C
My Ride: 2001 325Ci
If it's the original battery, then it''s likely it can't hold a charge anymore. Get a new battery. I'm not certain about M cars but I'd try to shop around for a battery instead of going to the dealer. The dealer battery is going to be expensive. Good luck.
Chris C is offline   Reply With Quote
Old 12-08-2012, 01:13 PM   #9
jhaurimn
My Ride: 01' 330ci
Might be time for a new battery. To prevent this from happening in the future get a battery tender.
PAST
2001 330ci - 117xxx (sold)
PRESENT
2001 M3 - 90xxx
1989 325i - 2??,???
jhaurimn is offline   Reply With Quote
Old 12-08-2012, 01:30 PM   #10
Alex323Ci
My Ride: M3 & 323Ci (sold)
well even if your battery was dead the car should start off the donor car's battery/jump. make sure the cable connections under the hood are good and rev the donors car up. now even if it starts you should be aware like many have said to get your battery tested or plan to buy a new battery as its likely no good.
if you have time to hunt around you can get a non-dealer substitute battery for less. me I bought a Bosch battery from Pep Boys with 2 discounts so price was $118. it's an exact battery of the BMW one. it has a bit more CCA and better warranty.
Old 12-08-2012, 01:32 PM   #11
tks
There could be nothing wrong with your battery, why people are immediately jumping to "it's your battery" is unnecessary.
Obviously, there are parasitic drains that over time take away from the battery, leave your car sitting long enough and you'll have a dead battery.
As far as jump starting, BMW recommends that it be jumped from the hood terminals (not directly at the battery due to a possibility of surges) and make sure you have good clean connections for the ground and power. Your connections could have enough resistance that it isn't providing a clean enough path for electricity so even though it can power on the lights, there's not enough voltage to power the starter, which needs a lot more current.
Old 12-08-2012, 02:15 PM   #12
Alex323Ci
Oops, I re-read you just came back from vacation and battery wouldn't start your M3. like I said, jump it as I posted or even push start it. drive it a while to charge the battery before shutting off. or charge it by a battery charger. unless the battery is old and weak you should be good to go.
Old 12-08-2012, 02:47 PM   #13
Hamsocne
My Ride: 2002 330Ci
I had a dead car that would start. Got a jump and went for a cruise hoping it would recharge a tiny bit as it was Saturday evening and when I got home it didn't start. Tried a few times though.
I came on here and searched hoping it was just the battery and read after too many attempts the car locks out the key for theft prevention purposes. My other key started the car.
I would still get a battery and I hope that is all you need.
I have no explanation for why it wouldn't start almost immediately or for minutes later which initiated the theft prevention function and yet it did start two hours later.
Hamsocne is offline   Reply With Quote
Old 12-09-2012, 10:14 AM   #14
Rahul1986
My Ride: Bmw
Hi my battery is dead now how to jumt start
Rahul1986 is offline   Reply With Quote
Old 12-09-2012, 10:15 AM   #15
Rahul1986
My Ride: Bmw
I have connected it with another car with the jump leads but still it's dead shall I wait
Old 12-09-2012, 10:16 AM   #16
Rahul1986
My Ride: Bmw
My car is 318 2.0
