Old 12-01-2012, 10:07 PM   #1
TnT817
My Ride: 01 330ci
Depo Led tails brake light issue
I just got my smoked LED tails from khoalty and installed them. When I hit my brakes theres probably at least a 1 second delay between the 3rd brake light and the tail light brake lights, with the 3rd brake light going first. Not quite sure what the issue is. Possible the resistor built into the LED's is creating too much resistance causing a delayed signal?
TnT817 is offline   Reply With Quote
Old 12-03-2012, 07:16 PM   #2
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Might be. I don' have that issue with my Eagle Eye tail lights.
Old 12-03-2012, 11:16 PM   #3
TnT817
My Ride: 01 330ci
Anyway you could possibly ohm your resistor on your tails for me, so I can compare to mine?
Old 01-17-2013, 12:34 AM   #4
afstud
My Ride: 2003 ZHP 6-speed
anyone ever find a solution to this?
2003 330i ZHP 6 speed
afstud is offline   Reply With Quote
Old 01-17-2013, 12:39 AM   #5
Kris.R
My Ride: 2012 Dodge Charger
I have the same issue..
- Kris -
"America will never be destroyed from the outside. If we falter and lose our freedoms, it will be because we destroyed ourselves."
-Abraham Lincoln-
Kris.R is offline   Reply With Quote
Old 01-17-2013, 11:29 PM   #6
TnT817
My Ride: 01 330ci
I never found one other than turning on my running lights all the time. That makes the brake lights come on instantly.
Old 01-21-2013, 01:29 AM   #7
greenskycity
My Ride: 1999 328i
I've noticed this on other cars that are on the road that have a incandescent third brake light and led tails. Id say the brake signal goes to the third light first then to the tails. It's not a second delay but it's a good quarter to half second delay. I'd say depo is doing something that makes it take a little longer to light up the led on their tails.
Sent from my Galaxy Nexus using Bimmer App
greenskycity is offline   Reply With Quote
Old 01-21-2013, 09:53 PM   #8
TnT817
My Ride: 01 330ci
Yes, but on e46's we have an led 3rd brake light. Its something to do with the resistors that are built into the depo tail lights that aren't the correct ohm rating. I need someone with ee tails to ohm their brake lights and see what the reading is to compare with mine.
Old 02-04-2013, 02:24 AM   #9
Kris.R
ttt
- Kris -
-Abraham Lincoln-
