Sponsored by BAVSOUND
Old 12-01-2012, 12:26 AM   #1
hardtop
hardtop's Avatar
My Ride: 05' 3 pedals 2 doors
Exclamation Sub install problems HELP!
Hi all,
I am installing a subwoofer and amp into my 2005 e46 coupe and I used the BSW sub install pdf. The problem that I am having is that even with the sub gain turned all the way down, there is no sound coming through any of my interior speakers, only the sub. All the wiring seems to be in order. Does anyone have any troubleshooting advice?
Much appreciated!
Owen
hardtop is offline   Reply With Quote
Old 12-01-2012, 12:31 AM   #2
323i2011Y
My Ride: BMW
Pretty sure you need to wire in a crossover if your amp doesn't have one built in
Steel Blue
3 Pedals, 4 Doors
323i2011Y is offline   Reply With Quote
Old 12-01-2012, 12:37 AM   #3
hardtop
hardtop's Avatar
I have a line output converter wired in right now. With everything wired back to stock it still works fine so I didn't blow anything during the install
Owen
Old 12-01-2012, 12:38 AM   #4
323i2011Y
My Ride: BMW
A crossover is different than a LOC. Look up active crossover. If you have an older amp you may not have one built in.
Steel Blue
3 Pedals, 4 Doors
Old 12-01-2012, 12:45 AM   #5
hardtop
hardtop's Avatar
I will check it out. Messing around with it more, it works wired in stock configuration but does not work when the LOC is wired in even with the RCA leads disconnected so it must be the LOC or maybe the fact that I have no crossover.
Also, could anyone give a link to an inexpensive active or passive crossover that would work for my application?
Owen
Old 12-01-2012, 03:40 AM   #6
hardtop
hardtop's Avatar
I seem to have resolved the issue by wiring the signal from the rear deck speakers, but can anyone confirm why my setup was not working before?
Owen
Old 12-03-2012, 12:01 AM   #7
timthefunnyman
My Ride: 2004 325xi
I'm having the same exact issue that you're having, except, even when I wired everything back to normal, my speakers still aren't working. I figured it was the amp, so I bought another amp that matches the serial number off of ebay. This time, only the left side of the speakers have sound coming out of them, and I mean sound. It's mostly static and other stuff where you can barely make out the song that's playing.
timthefunnyman is offline   Reply With Quote
audio, diy, install, subwoofer
