Sponsored by BimmerWorld
Old 11-30-2012, 01:09 PM   #1
jazz5000
My Ride: e46 e60 e92
Brake lights staying on!!
Hi
Have a e46 318
Mileage is around 30k
Having a problem where the brake lights come on and dash lights stay on when key is removed.
When car is started there are no problems.
Also remote fob is not working.
I have to disconnect battery to stop it draining from the brake lights staying on.
I am trying to use Inpa to diagnose it but am having trouble with that,
Is this a known issue? Anything i can do to try and fix it?
jazz5000 is offline   Reply With Quote
Old 11-30-2012, 01:19 PM   #2
lcoleman
My Ride: '79 Massey Ferguson
Brake light switch.
Edit: Sorry, sounds like an ignition switch if stuff stays on with the key removed.
Old 11-30-2012, 01:22 PM   #3
jazz5000
After a bit of research found it could be n/s/r abs sensor or speedometer sensor.
Anyone have any thoughts on that?
Old 11-30-2012, 01:29 PM   #4
tcphoto
My Ride: E92 335 MT Coupe
My brake lights were staying lit so I changed the brake switch and then the grounds in the holders. It ended up being the ground in the more solid connection of the two.
tcphoto is offline   Reply With Quote
Old 11-30-2012, 01:33 PM   #5
jazz5000
Also the temperature gauge goes to max,
Even though car is off
The ground for the brake switch?
Is there a diy on how to access the switch?
Old 12-05-2012, 10:10 AM   #6
tcphoto
The brake switch is mounted on the brake pedal assembly. My problem was the ground in the tail light bulb carrier in the trunk which caused all kinds of other strange things, like the radio going out and the steering wheel controls not working.
Old 12-05-2012, 10:30 AM   #7
jazz5000
After disconnecting the battery overnight, the problem seems to have gone.
So hopefully all it needed was a reset.
