Old 12-02-2012, 11:26 AM   #1
Orchazum
My Ride: Steel Grey 330i
Smile tranny failure after 100k from fluid change ??
Hello my fellow e46r's got a question. Now I have seen many threads of transmission failure when changing out the fluids after 100k . I am currently at 117k and was told about 6 months or so ago ky tranny had good fluid in it. The question here is should I ? I don't want failure , current money troubles would make that car an ornament in my driveway if it did fail . Fluid still looks in good condition as of a few days ago.
Do i run the risk of failure upon changing fluids at current mileage or do i just leave it be ?
If left alone how long will it last ?
There is no slippage currently (knock on wood) no problems at all.
Multi Color Angel Eyes, MD, K&N, Sharked, Y-Rated Shoes
Orchazum is offline   Reply With Quote
Old 12-02-2012, 11:31 AM   #2
BMWCaptain
Location: TEXAS - Circuit of the Americas doing laps with my M5 and coming in for a pit stop.
My Ride: 03 330iT SportWagon
Search and you will find your answer.
BMWCaptain is offline   Reply With Quote
Old 12-02-2012, 11:38 AM   #3
limpiabota809
My Ride: 330 XI
This is a good question as I am contemplating tranny fluid change as well and I'm sitting on 112k...general consensus is to change it, so I'm leaning towards changing it...going to speak to some shops and of course bringing my own fluid
Instagram - @Limpiabota_e46
limpiabota809 is offline   Reply With Quote
Old 12-02-2012, 11:48 AM   #4
Orchazum
If the fluid has been previously changed I won't know, car fax doesn't say a whole lot, hell I have a reman alternator not on there . If the fluid has been changed, what is the failure rate hmmm
Old 12-02-2012, 11:55 AM   #5
HacksawMark
HacksawMark's Avatar
My Ride: 2014 Subaru XV
Hmmm, I would think that if the fluid change is done correctly with the right fluids, the chances of fluid-caused failure would be near zero. Any failure from that point on would be from non-fluid causes.
HacksawMark is offline   Reply With Quote
Old 12-02-2012, 12:00 PM   #6
shadow 2
My Ride: 07 328i
There must be 50 threads on this issue. Search! You won't get a definitive answer and will be taking a chance no matter what you do. I changed my fluids over 40k miles ago with no issues either before or after the change.
shadow 2 is offline   Reply With Quote
Old 12-02-2012, 12:30 PM   #7
cvx5832
My Ride: 325Ci, 325Cic, C300
Out of curiosity, how did you check the transmission fluid?
cvx5832 is offline   Reply With Quote
Old 12-02-2012, 02:45 PM   #8
Orchazum
http://forum.e46fanatics.com/showthread.php?t=438667
the answer i wanted.
Old 12-02-2012, 02:50 PM   #9
wasp9166
My Ride: 04 330i jet black
Send a message via Yahoo to wasp9166
new fluid does not ruin a tranny, neglect, improper use and flushing ruin a tranny
"if polarity comes from protons, does morality come from morons?"
Originally Posted by russ330 View Post
"Mommy and Daddy are getting a divorce now because wasp9166 had to piitb with Mom."
wasp9166 is offline   Reply With Quote
Old 12-02-2012, 03:25 PM   #10
jfoj
My Ride: 330CiC, M5, X5, E93
This IS the correct answer!!
Guaranteed you will NOT have a fluid related failure from changing the fluid.
Usually people think they if they change the fluid on a high mileage transmission it will sort out problems they are currently having.
Only problem it is about 50-75k miles too late for new fluid to help matters!
Old 12-02-2012, 03:26 PM   #11
bumere46
My Ride: E92
you won't.
I did it on many of my cars and never had a problem
bumere46 is offline   Reply With Quote
Old 12-02-2012, 03:45 PM   #12
SteadyMobbin
My Ride: ImolaZHP 6spd M/T
Slush or stick?
SteadyMobbin is offline   Reply With Quote
Old 12-02-2012, 04:17 PM   #13
wasp9166
Originally Posted by SteadyMobbin View Post
Slush or stick?
slush is assumed, as when a manual fails it's usually the clutch, throw out etc
Old 12-02-2012, 04:42 PM   #14
Orchazum
Decision made. To change.
It is a slush driven as a stick all the time though. Just couldnt find a 330 without it being beat to death with a stick.
If it ever fails 6 speed swap def. It would cost around the same if i did it myself vs shop putting in a new AT
Old 12-02-2012, 05:32 PM   #15
auto180sx
My Ride: '02 Steel Blue 330Ci
Be sure to change the filter too!!!
Steel Blue FTMFW!!
OKI BMW
BMW CCA Member #444186
auto180sx is offline   Reply With Quote
Old 12-02-2012, 05:56 PM   #16
lucky_doggg7
My Ride: 2005 M3
Here is my 2 cents, if you are one of those types of fellahs who is easy on their car, meaning that you roll onto the accelerator nice and easy all the time and you don't spin up the motor to redline 20 times a day, changing the ATF might be okay, but, if you're in the crowd that treats the accelerator like a light switch each and every time your foot hits the accelerator, and you spin it up to redline 100 times a day, then reconsider the flush. The harder one leans on the car, the clutch packs work harder and thus experience more wear. The abrasive clutch pack particles get carried away by the ATF and accumulates making life even harder on the clutch packs. If the clutch packs are too worn, the worn clutch pack will now rely on the abrasive clutch pack particles floating around in the ATF to help it grab so to speak. Now if one pressure flushes out all the abrasive filled ATF with new "slippery" ATF, the worn clutch packs will slip even more thereby shortening their life sooner; at some point, the clutch pack will fail to hold, and as an added bonus, in this degradation process, the temperature will rise in the box, the ATF gets cooked/burned and itself becomes a less effective lube. It's a wicked circle. So again, if your driving style/habit is of an easy nature, you might just be okay, but if you beat your sled, perhaps letting a sleeping dog lie, as the saying goes, is a better choice.
Old 12-02-2012, 06:07 PM   #17
Orchazum
Oh a filter change is certainly on that list. I feel it would be like changing the oil without changing the filter
I drive my car normally , I like to get on her at least once a week though . Most of the miles on my car are highway though. Out of the 40k I did last year. 60 % is highway.
Old 12-02-2012, 07:24 PM   #18
SHOoff11
My Ride: 1999 Lexus LS400
I just changed the filter, fluid, and diff oil in my automatic at 136k, there was a world of difference in shifting afterwards.
Originally Posted by SPDSKTR
You drive a BMW. That means you make $600,000 a year and date supermodels without pointy elbows or hairy arms. Need I say more?
2001 BMW 330ci vert 5-MT Steel Grey/Tannin Red
1993 BMW 325i 5-MT Black/Tan
2010 Chevrolet Silverado 2500HD Z71 Summit White/Black
SHOoff11 is offline   Reply With Quote
Old 12-02-2012, 07:50 PM   #19
jfoj
+1
Fluid friction and lube properties break down with heat over time.
Fluid change is good!
Old 12-02-2012, 07:53 PM   #20
DOB2009
My Ride: 325i
Mine died twice under 60k miles. Granted the 2nd time was due to a poor rebuild. I eventually just bought a low mileage 330i used tranny which has been running strong and cost about the same as a rebuild. I've had bad luck with trannys though. I also had it go in my Integra GSR a few months before my e46, and had 4 failures on an 93 celica GT about 10 years ago. Again it was a crappy rebuild that kept failing. I have had terrible luck with rebuilds.
DOB2009 is offline   Reply With Quote
failure, gm, transmission
