Old 12-02-2012, 11:22 PM   #1
gameowinner
My Ride: bmw
help me M52tu
Listen to my engine.
It follows from parts of the engine.
_a_
gameowinner is offline   Reply With Quote
Old 12-05-2012, 01:11 PM   #2
gameowinner
My Ride: bmw
Old 12-05-2012, 01:13 PM   #3
Nerdy46
My Ride: 328i
That sounds like a rod knock or a broken rocker..
Daily: 1999 328i (202k)- Sport and winter package, 5speed, Jet Black, hellbeige, e60 Short throw, cross drilled rotors, koni, H&R, ASA AR1, Vibrant stealth, basslink
Track: 1995 Mustang GT (230k)- 306ci, 5 speed, MGW shifter, Trickflow Heads, Trickflow intake, street cam, shaved and tucked engine bay, slammed, 1 3/4'' long tubes, tuned with moates.
On the Water: 7' Boneyard Retro Quad Fish
Nerdy46 is offline   Reply With Quote
Old 12-05-2012, 03:09 PM   #4
DougL3NC
My Ride: 2000 323Ci
Header/Manifold gasket leak? Collector gasket leak? Sounds exhaust related to me!
BTW, nice factory headers....and your damn steering wheel is on the wrong side!
DougL3NC is offline   Reply With Quote
Old 12-05-2012, 03:42 PM   #5
RayPooley
My Ride: 320i SE Coupe
Weak or busted valve spring or hydraulic lifters perhaps. Don't run it any more until you have investigated.
To check valve springs and lifters you will need to remove the valve cover and take a look at them. Whether they are the problem or not you will need to replace the valve cover gasket when you put it back. But it sounds clacky like a cold diesel engine. Ergo lifters.
Old 12-06-2012, 07:46 AM   #6
gameowinner
My Ride: bmw
I will try to make the hydraulic valve view.
Thanks for your comment.
