Old 12-03-2012, 01:02 PM   #1
Robaidh
My Ride: e46 318 2.0 coupe
How do i replace my indicator stalk?
Hey guys
I need to replace my indicator stalk it has the BC button on it, my car is a 51 plate e46 coupe 318 ci. I can see one screw on the top of the plastic steering column cover, is their more or or does it just pull out?
Robaidh is offline   Reply With Quote
Old 12-03-2012, 01:34 PM   #2
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Steering wheel has to come off
Old 12-03-2012, 02:11 PM   #3
Robaidh
Really? I was told that you have to take the covers off and then disconnect the air bag and you can get to it then.
Old 12-03-2012, 02:23 PM   #4
Ken@BavAuto
Bavarian Autosport
My Ride: 1989 325is
I'm looking at the Bentley Repair Manual for you. Solidjake is correct, steering wheel/airbag need to be removed.
Basically they are saying to:
1. Disconnect negative battery terminal
2. Remove airbag
3. Remove steering wheel
4. Remove steering column trim
5. Detach EWS ring antenna harness connector
6. Detach wiper/washer connector
7. Detach dimmer switch connector
8. Detach airbag harness connector
9. Remove turn signal stalk by sliding it off of the column.
Steering wheel torque is 46 ft-lb. Installation is done in reverse order of removal.
CONTACT US
WEB: http://www.bavauto.com/ | E-MAIL: kenb@bavauto.com | PHONE: 800-535-2002
HOURS (EST): Monday - Thursday 8AM - 9PM | Friday 8AM - 7PM | Saturday 9AM - 4PM
CONNECT WITH US
Facebook | YouTube | DIY Tech Blog | Twitter
Ken@BavAuto is offline   Reply With Quote
Old 12-03-2012, 02:28 PM   #5
Solidjake
Zero. Leaks.
Solidjake's Avatar
Nice, we have Bav Auto in the house!
Old 12-03-2012, 02:38 PM   #6
Robaidh
Thanks for the help guys bigger job than i had expected but need to get it sorted cheersh guys
Old 12-03-2012, 02:39 PM   #7
Zell
Zell's Avatar
My Ride: so turbo wow
Ah it's not too bad, the hardest part is getting the airbag out
Old 12-03-2012, 02:44 PM   #8
WDE46
My Ride: '13 128i, '04 330Ci
Just hit the front bumper with a sledge hammer and then use the actual bag as a grip to pull it out.
Old 12-03-2012, 02:51 PM   #9
jdstrickland
My Ride: '94 325iC & '00 323i
CHEERSH?
You type like you talk after you've done a few pints...
Old 12-03-2012, 03:25 PM   #10
Robaidh
2. Remove airbag
So how long should i disconnect the battery for so not to risk having the air bag go off?
Old 12-03-2012, 03:26 PM   #11
Robaidh
Haha think i will stay clear of that idea
Old 12-03-2012, 09:21 PM   #12
willsbma
My Ride: 99 323i
Not sure why you're replacing the stalk but if the button stopped working you may be able to repair it. I just soldered two small wires and it works again.
Sent from my DROIDX using Bimmer App
Matte Black Kidney Grilles | Smoked Tails & Corners | Mtech II Bumper | Hotchkis Springs | ACS Roof Spoiler | M3 Spoiler | 20% Tint
WTB: Black sun visors & grab handles - PM ME!
I have P.A. Soft and a 20-pin adapter. Only used it a few times but pm me if you need anything coded!
willsbma is offline   Reply With Quote
Old 12-03-2012, 09:34 PM   #13
afstud
My Ride: 2003 ZHP 6-speed
when i swapped out my stalk for one with the BC button onto my car i didn't need to remove the steering wheel. i just took off the plastic steering column cover and there was two screws holding it on.. simple as pie.
2003 330i ZHP 6 speed
afstud is offline   Reply With Quote
Old 12-03-2012, 10:33 PM   #14
rizwan1377
My Ride: 04 M56,LC 100,RX300
Send a message via AIM to rizwan1377 Send a message via MSN to rizwan1377 Send a message via Yahoo to rizwan1377
Just Leave it disconnected while you are working.
Sent from my ADR6400L using Bimmer App
rizwan1377 is offline   Reply With Quote
Old 12-03-2012, 10:35 PM   #15
Zell
Zell's Avatar
Problem: Solved
Genius.
Old 12-07-2012, 11:07 AM   #16
Robaidh
See i have read on the net that you just take the plastic covers off and ur abel to get at it this way and then on this thread ive been told the wheel needs to come off. Now im confused.
Old 12-07-2012, 12:08 PM   #17
Bimmer_Addict
My Ride: E46 323i
i have the stalk with no BC button, when i replace it with the one with the BC, will it work right away or programing is needed by dealer or Indi?
00 E46 323I current
08 Jeep Grand Cherokee Laredo current
08 E60 535I LEASE OVER
02 E66 745LI LEMON
98 E39 528I SOLD
91 E30 316I SOLD
Bimmer_Addict is offline   Reply With Quote
Old 12-07-2012, 12:18 PM   #18
Ken@BavAuto
Bavarian Autosport
My Ride: 1989 325is
It would not surprise me at all if this was accurate. I've seen the Bentley Manual go a little overboard before with extra steps. I would still be cautious about the airbag and disconnect the battery anyway, just to be safe.
CONTACT US
CONNECT WITH US
Old 12-07-2012, 01:12 PM   #19
FenderGuy05
My Ride: 2002 BMW 325i
I did this when doing a OBC retrofit, in fact if you search for OBC retrofit there's a thread I followed the DIY for. Same logic applies if only changing the turn stalk.
Addict, to get the stalks BC button working you will have to have it programmed. You can do this with PA soft by chaning the features coded to the car, very easy this way and worked perfect for me.
FenderGuy05 is offline   Reply With Quote
Old 12-07-2012, 03:30 PM   #20
afstud
you DO NOT have to take off the steering wheel. ive done it before.
