///M3 Forum
Old 12-03-2012, 09:08 PM   #1
abbas_m3
My Ride: bmw m3
Drive shaft vibration when taking of hard !
Hi guys,
when I accelerate hard from a stand still I'm getting a vibration from the middle/drive shaft area, its literally under my seat. Now im 90% sure its either the guibo or center bearing.. My brother had to replace his center bearing and it was making a different type of vibration, his one was a aggressive knocking and It would occur at speed upto around 60kms.
My issue is vibration only if accelerating from a standstill and sometimes if im on a Hill.
Anyone experienced the same issue ? Guibo or driveshaft ?
Thanks, Also car is a SMG.
abbas_m3 is offline   Reply With Quote
Old 12-03-2012, 09:39 PM   #2
choxor
My Ride: JDM
Step 1: visual inspection
Old 12-04-2012, 03:15 AM   #3
bmwTuner1
My Ride: Bmw, 330ci
I had that problem. Mechanics sucked so I ended up replacing a bunch of parts. Turned out to be the drive shaft CV joint.
Photobucket
bmwTuner1 is offline   Reply With Quote
Old 12-04-2012, 08:58 AM   #4
S54Dan
My Ride: '05 M3 '03 ZHP
Sounds like a guibo or a center support bearing
2005 M3 6MT | Weekend toy & Track rat
2003 330i ZHP 6MT | Wife Mobile
1994 325i 5MT | DD
Instagram @S54Dan
S54Dan is offline   Reply With Quote
Old 12-04-2012, 09:05 AM   #5
bimer21
My Ride: stick 325i
Its guibo or center support! And believe me go OEM! I replace mine 3 time for put others brands!
bimer21 is offline   Reply With Quote
Old 12-05-2012, 07:24 PM   #6
bmwTuner1
My Ride: Bmw, 330ci
^ +1 Definitely go OEM
Photobucket
