#21 |
Ice scraper and winter washer fluid
If snow accumulates AT ALL then you shouldn't even THINK about driving on the highway with summer tires. It will be literally like driving on an ice rink... incredibly dangerous. |
#22 | |
Ice is much more "interesting" than snow. Freezing rain is the worst. If you must drive, then have your traction cables handy (standard chains won't work on those 18" wheels). And get used to putting them on before you leave. It isn't terribly hard once you figure it out. But you don't want to have to do this for the first time on the side of the road, when it is freezing cold, and probably dark. Chances are, though, that, as long as the road is plowed, everything will be uneventful. |
#23 |
Does this guy work for ISO?
![]() It gets to below 0F every winter here in Upstate NY never had to put that stuff in my fuel and my car is ALWAYS outside. The only case i could see it being a problem if you left the tank really low and let it sit over night or 24hrs. my 2c. but like he said its only 3 bucks guess why not........just wondering why dog loves it sooo much.
![]() ![]() -Ivan PS3N ID: siberiasurvivor |
#24 |
My car had no problem making it through winter in central Missouri with no fuel additives. Our high temp from January to march was somewhere around 15 degrees.
-Mike
** Removed ** Ask an Insurance Adjuster Anything Cup of Joe for a Joe! http://www.greenbeanscoffee.com/coj/ buy my O.Z. Ultraleggeras! |
#25 |
#26 |
-Mike
#27 | |
Weagle Weagle
All I said is that it's not necessary, and it's not. You're just trying to scare the OP. Where is he going it is not a concern. Holy f*****. I have literally never heard of anybody having a problem with freezing gasoline. Like I said, OP is not on a mission to the North Pole.By the way, most gas nowadays is 10% ethanol which is molecularly very similar to isoproyl alcohol. There is no need for it. You simply don't use logic. Last edited by WDE46; 12-06-2012 at 07:19 AM. |
#28 | |
Bottom line, it's just the price of a cup of coffee. If it makes a driver feel better, adding a cup of isopropyl (ISO) or methanol (HEET) won't hurt anything. Objectively, though, it seems like overkill when the temps aren't likely to fall even to 0F. Our winter car lives outside and temps in the 0F range aren't uncommon. That vehicle has never had a fuel-related problem. I did work in Alberta, CA, during one winter. Temps fell to the -40 range. Never added "dry gas" to any of the rental cars. Again, no problems. The most likely cause for problems is buying gas that is contaminated with water. With tighter regulations, most modern (as in, since the late '80s), busy stations shouldn't have that problem. If this means buying from a busy station near a highway in an unfamiliar location, it might cost another 5 cents a gallon. Even if your tank was bone dry (not recommended in the winter, of course), the difference is less than a bottle of "dry gas". |
#29 |
Buy good snow tires. That will be fine. If you're in a situation where you find you need chains, you simply brought the wrong car.
You need nothing else other than ice scraper and maybe a car bra if you so desire. Not really needed
#30 |
op, lucky_doggg7 is correct.
carry tire chains when going to norcal. you probably wont need it but if there is a snow dump, authorities wont let you pass thru unless the chains are on the tires. there are tire chain install areas at both ends of mountain passes. and put gas antifreeze in your gas tank. you probably wont need those if the weather cooperates so check the weather forecast and act responsibly. but mother nature is cruel sometimes when you least expect it, and we know how them weather forecasts are damn accurate ![]() an ounce of prevention is worth a pound of cure !
![]() Last edited by Hoebama; 12-06-2012 at 11:02 AM. Reason: sp |
#31 |
holy **** people like to beat things to death on here don't they? OP is probably back from his trip already...
#32 |
Weagle Weagle
#33 | |
Just throwing this out there, so the guy from Southern California, who probably only sees temperatures below 50 degrees a couple times a year, says we need to buy some gasoline additive for 2 day trip in 20 degree weather..
I live in Ohio and two winters ago there was a couple weeks that barely got above 0F. I park outside. I never had a problem.Only thing to keep in mind is that, possibly due to all the SoCal people who have no idea how to drive in snow, California from what I hear has mandatory chain laws on many mountain roads with checkpoints. As far as washer fluid, etc etc dont worry about it unless you have your car serviced by a hobo you won't have anything in your car freezing. Quote:
Photo in Cleveland, Ohio 1999 323i - 210,000 miles and counting. Rear Wheel Bearing Tool (SitTools B90) Rental, ~$60 |
#34 | |
2003 Jeep Wrangler Rubicon 2000 BMW 323ci 1995 Saab 900 SE - JZW Stage 4 |
#35 | |
It ca get seriously bad seriously quick up there.
#36 | |
x2. On my first cross-country drive, we were treated to sleet and snow in Wyoming. This was in late June and it had been 90+ the day before in South Dakota! Ever since, I've carried traction cables whenever I drive in the Rockies or the Pacific Coast mountains. It's a no-brainer to have them in the winter. |
#37 | |
Weagle Weagle
#38 | ||
![]() E92 convert. BMW Fanatic. |
#39 | |
obviously not the most competent.
![]() ![]() -Ivan PS3N ID: siberiasurvivor Last edited by CoupeMagic323ci; 12-06-2012 at 03:12 PM. |
#40 | |
I dont carry snow chains but they do a pretty good job on clearing the highways when it snows or they close it completely. I made it from Aspen to Denver last february in blizzard like condition through the i70 stretch. Very tricky but was uneventful. As long as you dont do anything stupid you will be fine. Be careful of the other drivers and keep distance. A teenager texting in her acura RDX is more dangerous than a RWD car. Heavier the car, more difficult to stop. Higher the car sits, more difficult it gets to control. Basic rules of physics. Having good tires is a must, snow tires are the best bet. Our cars and fluids available these days are very much capable of handling sub freezing temperatures. Winter blend gas, proper coolant, proper oil, windshield fluid topped up is all you need to worry about as far as fluids are concerned. These cars are designed to be driven in norway, why would you worry about driving it in california. Now I am going to tell again, if the snow is touching your side skirts, be worried. Our cars have very low ground clearance. You get stuck easily once the snow is packed under the belly and the car just pivots on that compact snow. Nothing you can do about it. While driving, a bit of common sense and a good distance from other cars is all you have to worry about.
