Sponsored by BimmerWorld
Old 12-04-2012, 09:21 AM   #1
23dilbert
My Ride: 2000 BMW 323I (RHD)
Rokkor suspension
Hi all,
I put in my rokkor suspension this weekend and now when i turn my wheel i can hear a knocking noise from the 2 front suspension. Has anyone had this problem? if so how did you fix it? i have my helpers out.
23dilbert is offline   Reply With Quote
Old 12-04-2012, 10:32 AM   #2
murac14
My Ride: 2001 325i
Originally Posted by 23dilbert View Post
Hi all,
If your all the way down with out the helpers try lifting it up tires might hit some of the fender when you turn
Sent from my PC36100 using Bimmer App
murac14 is offline   Reply With Quote
Old 12-04-2012, 10:38 AM   #3
23dilbert
My tires are not hitting the fender. It almost sounds like the spring itself.
Old 12-04-2012, 05:13 PM   #4
LeMansteve
My Ride: '04 330i 6mt ZSP ZPP
First, I would suggest removing your $400 Rokkor suspension and throw it away. Your car will be much better off. If that's not an option, check to see if the sway bar endlinks are tightened to spec.
Old 12-04-2012, 07:00 PM   #5
murac14
My Ride: 2001 325i
Check endlink Idk to be honest what else it might be but lift the car up in the front and recheck everything
Old 12-04-2012, 07:08 PM   #6
jerseyzillest
My Ride: 325 CI
Your wheel is hitting your strut, you need spacers.
I'm 100% sure that's what it is.
Photobucket
^Taken with iPhone^
:rofl:
jerseyzillest is offline   Reply With Quote
Old 12-04-2012, 07:09 PM   #7
murac14
My Ride: 2001 325i
Yeah most likely
Old 12-05-2012, 08:17 AM   #8
subieworx
My Ride: ZHP, 335, E53, E30
The wheel would hit the strut at all angles of turning then which would still not create a knocking noise.
Is it a repeated knocking noise that happens as you turn the wheel? Does it sound anything like a "boing" sound?
subieworx is offline   Reply With Quote
Old 12-05-2012, 08:19 AM   #9
jerseyzillest
My Ride: 325 CI
Mine did that, only when I turned is when it made a noise. It sounds like grinding.
Photobucket
^Taken with iPhone^
:rofl:
Old 12-05-2012, 09:33 AM   #10
euG!
My Ride: ZHP SALOON
Send a message via AIM to euG!
unless your struts are flopping around under there your wheels will never touch your strut just when turning. If they touch, they would have always been touching. Try turning your wheel and going in circles. If your wheels are truly touching your struts you will see and/or smell smoke.
'04 330i ZHP
TiAg/Alcantara
3.46/APEX/KONI/COBY/JAFFSTER
euG! is offline   Reply With Quote
Old 12-05-2012, 09:59 AM   #11
lucky_doggg7
My Ride: 2005 M3
Let's run through this with some methodical thought here. A few questions first: 1) The spring perch atop the coilover, what style was it? Meaning did it have a detent for the coil spring forthe end of the coil spring to seat in, or is it flat. 2) The top perch, does it spin, or is it solidly affixed? 3) The strut bearing, what condition was it in? If the strut bearings were re-installed, how many miles were on those bearings. Did you install new one's? You see, all these things matter because it affects the answer. Without knowing these things, it is difficult to diagnose your problem. My shot in the dark is this: the strut bearing is not functioning as it should, meaning allowing rotation; this causes the spring perch to rotate in the assmebly; it's my guess there is a detent for the spring perch and since the perch is rotating around, it makes the spring pop out of the detent and when it falls back into the detent, the spring does what a spring does, it'll unload energy and wire end of the coil spring falls into the detent making a knocking noise.
Old 01-04-2013, 04:17 PM   #12
23dilbert
Sorry for the late reply. Yes it's a repeating noise and it sounds like a boing.
Old 01-04-2013, 04:45 PM   #13
jerseyzillest
My Ride: 325 CI
it's your wheels hitting your strut, i had the exact same problem. take off your front wheels your strut will be all scratched up just like your wheels lip. Just buy 10mm spacers and you'll be fine.
Photobucket
^Taken with iPhone^
:rofl:
Old 01-07-2013, 02:01 PM   #14
23dilbert
I made a video of the noise i'm hearing, it's not this best video but you can hear the knocking and there's also a squeaking noise also.
Old 01-10-2013, 09:46 AM   #15
jerseyzillest
My Ride: 325 CI
take off your front wheels when you get the chance and post a picture of the strut and of the inner wheels.
Photobucket
^Taken with iPhone^
:rofl:
Old 01-10-2013, 11:34 AM   #16
ZeeZoo
My Ride: '99 323i
Sorry to thread jack but jerseyzillest can you empty your inbox lol. Send me a PM.
ZeeZoo is offline   Reply With Quote
Old 01-10-2013, 12:34 PM   #17
Jesse M
My Ride: 05' ZHP
It sounds like the spring is binding. I would take them apart and reassemble them to be 100% sure the spring was seated correctly upon installation.
Jesse M is offline   Reply With Quote
Old 01-14-2013, 10:26 AM   #18
23dilbert
Here are the pictures I couldn't get a good picture of the strut but I didn't see any marks on the strut itself. I took pictures of some marks I seen inside of the rim so i'm pretty sure it's not my rim hitting my strut.
ID:	486003   Click image for larger version
ID:	486004   Click image for larger version
ID:	486005   Click image for larger version
Old 01-14-2013, 10:33 AM   #19
M325er22
My Ride: 2001 325i
Did you reuse the washer between the strut bearing and tge strut?
I had a similar problem like yours.
Sent from my LG-P509 using Bimmer App
M325er22 is offline   Reply With Quote
Old 01-14-2013, 01:42 PM   #20
23dilbert
I reused everything from the top hats.
