Old 12-04-2012, 10:23 AM   #1
KevinWitek
My Ride: 2005 330ci
2005 330ci Interior Trim 2-door Question?
I've been browsing for brushed aluminum interior trims to replace the stock wood grain that I'm not a fan of. I've found a few, such as www.realoem.com, but they all include rear armrest paneling pieces. I have a two door, so I'm worried if I were to buy the parts (even if I just purchase the front armrests) that the sizing will be off since a 2-door's door is larger than that of a 4-door. Am I fine to purchase all pieces minus the two rear ones? Or do I need to find 2-door specific pieces?
http://www.realoem.com/bmw/showparts...65&hg=51&fg=95
Thanks,
Kevin
KevinWitek is offline   Reply With Quote
Old 12-04-2012, 10:51 AM   #2
lmr2wil
My Ride: '00 328Ci
You definitely need two-door specific pieces. The last link is on the right track. Also, you should check the classified section here as well as ebay to see if you can source used parts. The trim pieces aren't cheap!
Luke
lmr2wil is offline   Reply With Quote
Old 12-04-2012, 10:53 AM   #3
aikmanson
My Ride: E30
You need trim from a coupe, trim from a sedan will not fit in a 2 door. The front dash pieces and shifter housing will, but the doors are not the same size and not even close to the same shape.
1990 BMW 325is - Stroker Build
2010 MINI Cooper S
1995 Saab 900 SE - JZW Stage 4
aikmanson is offline   Reply With Quote
Old 12-04-2012, 11:07 AM   #4
lmr2wil
My Ride: '00 328Ci
Won't the shift trim be different too? The sedan should have a different cutout for window switches.
Old 12-04-2012, 11:10 AM   #5
aikmanson
My Ride: E30
+ 1 You are right
Window switches are different, there is a window lock switch or something like that for sedans, right?
2010 MINI Cooper S
Old 12-04-2012, 02:22 PM   #6
KevinWitek
My Ride: 2005 330ci
So basically every piece needs to be 2-door specific?
Thanks for your help!
2-door, 330ci, interior, trim
