Sponsored by The Tire Rack
Old 12-04-2012, 10:32 AM   #1
ajai
My Ride: 330ci***65104; 328i
Dunlop direzza star lost grip so fast
after one night of hard testing of my coilover.
the front tires grip are like 30% less..
missed the ci, welcome the i
ajai is offline   Reply With Quote
Old 12-04-2012, 10:59 AM   #2
simsima325
'a certain moderator'
simsima325's Avatar
My Ride: Honda Civic
sounds like a very scientific analysis has been performed.
-Brendan
Old 12-04-2012, 12:56 PM   #3
Grande D
My Ride: E36 M3
http://forum.e46fanatics.com/showthread.php?t=957696
It will change your life!
Old 12-04-2012, 01:06 PM   #4
Riverbmr3
My Ride: MB E350 & BMW 325i
Tried Dunlop before and never buy again...
Riverbmr3 is offline   Reply With Quote
Old 12-04-2012, 01:38 PM   #5
ajai
the tires still have a lot of thread , just that the grip is lost.
The surface of the tire became less smooth.
is there ways to regain tire grip or make the surface smooth again? Since tires is still very new, I don't want to get another set
if I exchange the smoother ones all in front, and the bad ones in rear. and try to go up in rear damper ( to fix oversteer)
will that be a good ideA?
Old 12-04-2012, 06:21 PM   #6
Grande D
My Ride: E36 M3
The Star Spec Z1 is a badass tire if grip is your goal.
This coming from someone who's a total Michelin/Bridgestone fanboy otherwise.
Old 12-04-2012, 10:17 PM   #7
ajai
Z1 has great grip ! but only when grip last..
Old 12-05-2012, 12:26 AM   #8
fth001
My Ride: 325i, e36m3, s13
Sticky compound tires are not supposed to be smooth. I know you feel that you have to let everyone know about your daily dilemmas with your car but thats what Facebook is for. Stop flooding the forums with nonsense.
fth001 is offline   Reply With Quote
Old 12-05-2012, 09:34 AM   #9
Rudy@Tirerack
Moderator
Rudy@Tirerack's Avatar
My Ride: 1-800-428-8355 X4664
Refer to 'Rudy/E46Fanatics' as your previous contact when you order online. Credit E46Fanatics.com by clicking here.
Rudy@Tirerack is offline   Reply With Quote
Old 12-05-2012, 01:07 PM   #10
ajai
Originally Posted by Gary@Tirerack View Post
What I was to explain is that I only did about 4 to 5 hard cornering and u turns in wet road. It did power slide a little, but then this little of cornering is big enough to cause the tire to lost grip by that much? That's seems not reasonable. And the tires looks fine. now the car feel like flowing on the road even in dry...
will increase the psi more helps?
Old 12-05-2012, 01:13 PM   #11
Grande D
My Ride: E36 M3
Maybe you broke a sway bar end link or something. I don't think your issues are tire related.
Old 12-05-2012, 08:39 PM   #12
ajai
As from what I can see, one side of the car, the front tire have wear at where the sidewall meets the thread. well right where the triangle ar pointing. But the other side have non wear.
I assume tahrs because the turns are all in one direction? And 34 psi might be too low so that when hard corner the side wall meets the road?
Old 12-07-2012, 01:56 AM   #13
ajai
okay.. I finally know what is werid. I have front camber -2.30
however, the inner tread has no wear, but the outer tread got wear instead. which makes it slippery,
but with neg camber, isn't it suppose to be the other way around,?
Old 12-07-2012, 05:49 AM   #14
HELLBOUND
My Ride: 2004 BMW 325 CI
New coilovers with poor set up equals poor grip, is there damping adjustment with these coilovers and if so were are they set.
HELLBOUND is offline   Reply With Quote
Old 12-07-2012, 02:10 PM   #15
ajai
Yea it got damper adjust. 32 way
I am at 20 front 13 rear
Old 12-10-2012, 12:19 AM   #16
always-there
My Ride: 2002 BMW 330I
^ This happened to me and the handling got really crappy real quick. Take a look under and inspect it.
Old 12-11-2012, 02:13 AM   #17
ajai
since I have explain before about the werid tire wear, will an alignment do the work? however alignment was done three months ago, will a hard cornering change the alignment ? since my tire is still very new . Just one side of the front outer tread is more wear out
Old 12-11-2012, 11:19 PM   #18
fth001
Seriously, this thread reeeeeaaaaalllly needs to DIE!!!
Old 12-11-2012, 11:33 PM   #19
Grande D
My Ride: E36 M3
however if I get it corner weighted, but my suspension is new and now with 30% more metal. But with more metal I got less grip, so my tires wore upside down? But alignment is expensive, my new coilovers have 15% higher ratio of horsepower.
Old 12-14-2012, 12:01 AM   #20
ajai
I booked a appointment to check the sway bar end link and stuff next week. Will update. The shop look at itand think the tires are ok and don't think that's the cause. after checking the sway, I might recheck the alignment too.
I have heard from local BMW ppl, they said bc coilover are easy to get loose on e46, and that might cause the alignment toe to change easily.
when I first got the coilover, I have redo my toe 2 times in a month.
After checked the coilover are not mounted tight enough.....
