///M3 Forum
Old 12-04-2012, 12:06 PM   #1
toolfan94
My Ride: 2005 M3 Vert. SMG
Random Electrical Problems
Hey guys,I currently have a 2005 M3 Vert SMG that I have been having strange electrical problems with.For example I cant put the top down, instrument cluster sometimes wont illuminate,whenever turn signal is engaged it wont illuminate on the dash,trunk button sometimes wont work,seat beat icon remains lit etc..All this is mainly from the inside, all lights from the outside illuminate properly and I don't have any problems starting the car or have had any driving issues. First thing I'm gonna check is my battery but its fairly new and have had it for a little over a year and cables seem to be very tight. The next thing is I can check are my fuses,any idea what could be causing the problem?
toolfan94 is offline   Reply With Quote
Old 12-05-2012, 12:39 PM   #2
illestminimike
My Ride: Project Drama
It's the battery. If not the battery it's the alternator.
Old 12-05-2012, 01:26 PM   #3
toolfan94
Already checked the battery its still good, haven't checked the alternator but if my alternator would be going bad wouldn't I have trouble starting the car or wouldn't it drain the battery? I found similar forums closely related to my problem and I think there might be something wrong with my k-bus
Old 12-05-2012, 06:15 PM   #4
illestminimike
Is your battery light on? Does it ever come on?
Old 12-05-2012, 06:59 PM   #5
toolfan94
No battery light isn't on,nor has it turned on recently. Cluster light is off, seat belt light remains light as well as the smg box which indicates the gears.
Old 12-05-2012, 07:05 PM   #6
Skchamaa11
My Ride: 2001 BMW 330ci
if your radio doesnt work that might be causing it i had a problem with my radio and the sunroof wouldnt open the right mirror wouldnt adjust and it wouldnt bring in cold or hot A/C
Whether you win by a inch or a mile winning is winning
Skchamaa11 is offline   Reply With Quote
Old 12-05-2012, 07:06 PM   #7
Skchamaa11
just an idea from past experience.
Old 12-05-2012, 07:06 PM   #8
Skchamaa11
after i got a new radio everything started working again
Old 12-05-2012, 11:23 PM   #9
toolfan94
Radio is working fine, the factory ipod adapter that came with my car isn't working though. I also noticed that the convertible top button is blinking the one to close the top, but i cant operate those buttons either. Also my ac isn't throwing cold air I guess im gona have to take it to an automotive electrician so he can check the kbus wires
Old 05-31-2013, 09:50 AM   #10
IMacDaddyI
My Ride: 323 ci
Did you ever sort this out? Mine started doing something similar... Once in a while my Seatbelt lcon remains lit; turn signals wont click or come on on the dash although all lights are working fine outside; i also noticed my high beams wont turn on when this is happening.
The strangest thing is that all i have to do is turn the car ignition On and off ... And everything is back to normal. Its happened a few times but happening more frequently now.
Let me know how you resolved yours.
IMacDaddyI is offline   Reply With Quote
Old 05-31-2013, 10:45 AM   #11
toolfan94
Re: Random Electrical Problems
Car is working fine now, weird thing is it happened during winter time only and now that its summer everything works. I don't know if I had a loose cable or if temperature was triggering these problems
Sent from my SGH-M919 using BimmerApp mobile app
Old 05-10-2014, 10:16 PM   #12
Jaypefelix
My Ride: 2004 m3
I have these same issues right now what was the fix to yours.
Jaypefelix is offline   Reply With Quote
Old 05-12-2014, 08:32 PM   #13
Teslazerok
My Ride: 2003 M3 6SPD
Could be a K-Bus issue.
Originally Posted by svtmike
Your TL is an eminently replaceable mass production inaninimate object that doesn't give a sh*t about you.
Teslazerok is offline   Reply With Quote
Old 05-13-2014, 12:38 AM   #14
t3ddftw
My Ride: 05 M3 6MT
Try having a look here: http://www.bmwgm5.com/K-Bus_Troubleshooting.htm
t3ddftw is offline   Reply With Quote
