///M3 Forum
Old 05-09-2014, 06:51 PM   #1
alpinm3
My Ride: '01 E46 M3
M3 spring rates.
Hi all, does anyone know what the spring rates are for a stock m3. I'm trying to calculate which rate I should get for lowering springs without revalving my shocks. (they are brand new)
Any suggestions toward a spring kit are welcome. I will be using them with OEM shocks.
Please don't reply saying "Get Coilovers," When I retire my car to the track I will make that transition.
I'm just trying to get rid of that hideous 4x4 gap that e46's come with.
Thanks!
alpinm3 is offline   Reply With Quote
Old 05-09-2014, 08:10 PM   #2
Teslazerok
My Ride: 2003 M3 6SPD
https://spreadsheets.google.com/pub?...3I3mP8cOvc5vZQ
Not sure how accurate this is however.
As for your shocks, the bigger concern is the height of the spring you choose, not the rate. Shocks burn through super quick when they no longer have the normal amount of travel.
Originally Posted by svtmike
Your TL is an eminently replaceable mass production inaninimate object that doesn't give a sh*t about you.
Teslazerok is offline   Reply With Quote
Old 05-10-2014, 09:50 AM   #3
SushiRoll
My Ride: M3
I would keep the same spring rate. Just get springs with tighter windings and lower overall height.
SushiRoll is offline   Reply With Quote
Old 05-12-2014, 01:14 PM   #4
Mahjik
My Ride: 2002 BMW M3
Send a message via ICQ to Mahjik Send a message via AIM to Mahjik
Take a look at the Eibach or H&R springs. Both will work with the OEM dampers and aid you in ridding the car of the 4x4 look. Neither will break the bank and will tide you over until you go to a full coilover. I've been using Eibach for about 5 or so years.
That would just be bad. Less travel requires more spring rate to account for that lack of travel. Otherwise, the car will just be binding on the coils on larger dips on the road (providing a terrible ride and undesirable handling).
Mahjik is offline   Reply With Quote
Old 05-12-2014, 01:27 PM   #5
TrickTizzle
My Ride: 325i
I'm pretty sure the OEM spring is a dynamic variable spring, so the spring rate varies based on compression.
Are you looking for static spring rate recommendations?
Old 05-12-2014, 02:07 PM   #6
Mahjik
H&R springs are progressive rate springs. Eibach will be linear (even though they typically advertise they have progressive rates).
Old 05-13-2014, 02:50 PM   #7
Nelson
Nelson's Avatar
My Ride: Alpin weiß ///M
Eibach Pro-Kit was designed to be used with factory shocks. I used them on my factory shocks for years until I decided to upgrade to Koni's.
///M
| eBay mod'ing sUUCks
Nelson is offline   Reply With Quote
