Sponsored by BimmerWorld
Old 12-07-2012, 12:19 AM   #1
boongsin12
My Ride: none
Koni sports adjustable adjusting
is it possible to adjust koni sports shocks without the adjusting unit? I don't seem to have one..
boongsin12 is offline   Reply With Quote
Old 12-07-2012, 07:29 AM   #2
lucky_doggg7
My Ride: 2005 M3
An ordinary pair of pliers will allow a user to turn the valving adjustment shaft. The adjustment shaft's protruding end is shaped like a flat blade screwdriver, albeit a small one. Assuming the suspension has proper travel, a good starting adjustment point is to make the front dampers one or two "clicks", so to speak, stiffer than the rear dampers. If general ride comfort is at all a concern, making the rear more compliant than the front will achieve this.
Old 12-07-2012, 09:06 AM   #3
boongsin12
My Ride: none
doggg, thanks for reply. The problem I am having is that I don't have the manual for the product because I bought it new from a private party. and I only have the rears (part number 8040 1271sport
As you can see in the picture, there is no flat screw driver like tip. Instead, there is a hex shaped hole that I could fit a hex key into. Is that how I would adjust the damping?
Old 12-07-2012, 09:42 PM   #4
fth001
My Ride: 325i, e36m3, s13
fth001 is offline   Reply With Quote
Old 12-07-2012, 09:44 PM   #5
SeanC
My Ride: 330i
Rears are compress-to-adjust. You have to take them out to do so. They can't be adjusted via a knob unlike fronts.
Black Sapphire MetallicNatural BrownSilver Cube e46 330i ZHP/6MT - Sold
HellrotDove Grey e36///M3 - RIP
Alpine WhiteTanSand High Gloss e46 330i SlickTop/5MT - Sold
Black Sapphire MetallicNevada BrownDark Bamboo e70 X5 xDrive4.8
Alpine WhiteCoral RedAluminum f30 328i Sportline/6MT
SeanC is offline   Reply With Quote
