Go Back   E46Fanatics > Everything Else > The Off-Topic > Home Improvement
Home Improvement
Home Improvement ideas, help, DIYs, and show room. Got a home improvement project you need help with or want to share. Post your project now!
Old 12-04-2012, 02:34 PM   #1
Hockeyman17
My Ride: 2005 E46 M3 SMG
Installing laminate Floor in my apt
Hey guys, I know I've been absent for a while, I've discovered reddit, and it takes up most of my free time.
I replaced the old scratched up cheap engineered hardwood and replaced with a nice chocolate rosewood laminate. I also installed new baseboards. I had to sand and repaint the wall because the baseboards were lower. I would not suggest replacing baseboards with smaller ones, you are creating a lot of extra work for yourself.
ID:	480857   Click image for larger version
Hockeyman17 is offline   Reply With Quote
Old 12-04-2012, 02:36 PM   #2
Hockeyman17
I can take more photos once I'm done cleaning everything up. Also the baseboards still need to be painted to clean up some of the seams
Old 12-04-2012, 02:42 PM   #3
Hockeyman17
Feel free to ask any questions. I am very happy with the end product
Old 12-04-2012, 06:29 PM   #4
sea6speed
My Ride: 2010 335i Msport 6MT
Interesting choice on the baseboards. They look very traditional for a modern apartment, especially if you're leaving them white. The floor color looks good with the window frames, the baseboard really stands out and says "this is where the room ENDS". That style is more common in suburban homes where there is nothing worth looking at outside the window.
sea6speed is offline   Reply With Quote
Old 12-04-2012, 06:32 PM   #5
Guest100615
Account closed per your request
It looks good.
Guest100615 is offline   Reply With Quote
Old 12-04-2012, 09:23 PM   #6
Hockeyman17
This is in a high rise apt building. Tomorrow I will paint all of the baseboards as well as the window sills you see in the pic and the door frames. I think it will clean it up even more with those matching
Old 12-05-2012, 10:47 AM   #7
sea6speed
Great! I'm sick of that "white trim on everything" style. We're starting to tackle a remodel of a modern house and this is one of the big mistakes I've seen on similar jobs.
Old 12-05-2012, 11:39 AM   #8
BimmersGarage
My Ride: E46 330i
Great job!
I use to not like dark colors for wood flooring... but it does give the room a classic look&feel.
BimmersGarage is offline   Reply With Quote
Old 12-05-2012, 11:51 AM   #9
NCLee
My Ride: 2004 330xi
Send a message via AIM to NCLee
Ugh. I know what you mean about using the shorter baseboards. I installed some hardwood and replaced stair treads in my 105 year old house, and some of the original baseboard was damaged. You can't just go to Home Depot and buy that old 8" baseboard!
I didn't want to sand and re-paint the whole length of the wall, so I ended up making my own baseboard. I needed two router bits to recreate the pattern of the original, and it looks close enough. I would not have been willing to do more than about 10 feet of that though!
What I've learned so far:
  • don't start working on the car unless you have a ride to the parts shop.
  • whatever you're doing, Mango's guide is probably right.
  • the Bentley manual skips steps. LOTS of them. Don't tear your hair out when the next step makes no sense.
NCLee is offline   Reply With Quote
Old 12-05-2012, 12:04 PM   #10
SLVR JDM
My Ride: 4Runner
Looks great!
I happen to like all white trim - simple and clean. I don't know what other color you would make it unless it is simply a wood stained color, which I don't happen to like (though I do have some of it in my own house that I've left alone since it looks good in certain circumstances).
SLVR JDM is offline   Reply With Quote
Old 12-05-2012, 01:48 PM   #11
sea6speed
Originally Posted by SLVR JDM View Post
Looks great!
Yeah, except you rarely see it used in modern designs to contrast against both the walls and floors. If the walls were white it wouldn't stand out so much. As it is, it's like he's trying to make the place look traditional despite the wall of windows.
Old 12-07-2012, 03:17 PM   #12
DylloS
My Ride: nothing
looks awesome
DylloS is offline   Reply With Quote
Old 12-07-2012, 04:18 PM   #13
SamDoe1
My Ride: 4cyl of fury
What's typically used in modern designs?
Old 12-07-2012, 07:58 PM   #14
sea6speed
Flat molding painted same color as wall or floor. The idea is to not draw your eye to the edge but to have it blend. It makes the room look bigger.
Something like this you barely notice it's there. If the walls were dark with the white trim this room would look like a small cave.
Old 12-07-2012, 08:11 PM   #15
sea6speed
Old 12-10-2012, 11:45 AM   #16
rohde88
rohde88's Avatar
My Ride: S2000
is it fastened to the ground at all? my apartment has similar laminate flooring and theres one spot where it rises up and you can feel it go "flat" by 1/2" when you step on it.
-Ron
rohde88 is offline   Reply With Quote
Old 12-10-2012, 01:09 PM   #17
Hockeyman17
There's one spot where the concrete has a dip and you can notice at the bottom of the baseboard. It makes a light 'clack' when you step on that spot. My uncle is coming by this week to see what he can do
Old 12-10-2012, 01:11 PM   #18
rohde88
rohde88's Avatar
My Ride: S2000
Yep, thats exactly what I mean.
If you can put some padding i.e. carpet backing or foam, it would probably fix it.
-Ron
Old 12-10-2012, 04:22 PM   #19
SamDoe1
The picture you took seems like kind of an exception though. For starters the room is huge with very large windows which make it seem large no matter what color is on the wall.
Second, that room has light paint and what appears to be white baseboards and no trim around the windows.
Third, flat paint on trim would not be very durable at all... I wouldn't go any lower than satin paint for trim pieces and especially baseboards.
Last, we have an accent wall in my house painted dark blue. What color trim would you recommend to go on there? Currently the whole house is natural oak and I'm not a fan.
Old 12-12-2012, 06:49 PM   #20
sea6speed
The room isn't as big as it looks. I've driven by the house a few times, and it's more the open layout that emphasizes size - and the fact that the house spans the lot lengthwise. From the outside anyway, the windows don't seem that large - but from that side it's painted gray.
Dunno on the blue wall, I'm not much of a designer. I'm just in the process of figuring out how to restore a modern house we bought without screwing up the original style. So, if you were to ask about what to do with a blue wall in a mid-century modern house, I'd have some idea. Other than that I'm clueless.
