Sponsored by The Tire Rack
Old 12-04-2012, 04:30 PM   #1
bimmernut3
My Ride: '05 330cic, '01 540i
Did E46's come with run flat tires?
Guys, I'm trying to figure out if my '05 330Ci convertible with the ZHP option came with run flats or not. I don't see anything on the side walls of the Michelin 255-35 x 18 rears. It did come with a compact spare in the trunk, which would tell me that it didn't but the previous owner thought it did. let me know
'05 330ci
[IMG][/IMG]
bimmernut3 is offline   Reply With Quote
Old 12-04-2012, 04:37 PM   #2
Stinger9
My Ride: '04 330Ci
Not in my awareness
Old 12-04-2012, 04:48 PM   #3
bratliff
My Ride: 330i
I don't believe so.
'02 330i
'97 318i
'95 325 Vert
'76 280z
bratliff is offline   Reply With Quote
Old 12-04-2012, 04:49 PM   #4
cityjohn
My Ride: 2001 M3
Even the M3 with its lack of a spare came with normal tires. An air compressor and sealant were supplied with these.
cityjohn is offline   Reply With Quote
Old 12-04-2012, 04:58 PM   #5
Wolrab
My Ride: 330Ci MT, 545i SMG
Wheels for run-flats come with an extra lip inside, that holds the bead in place while running flat. If you're thinking about getting run-flats, check to see if your wheels can take them first.
Engineers do it with a torque wrench
Wolrab is offline   Reply With Quote
Old 12-04-2012, 04:59 PM   #6
LeMansteve
My Ride: '04 330i 6mt ZSP ZPP
If you don't see any kind of EMT, ZP, RFT or other runflat branding, then they probably aren't runflats. Not all E46s came with runflats.
Old 12-04-2012, 04:59 PM   #7
bimmernut3
Even if the car came with the "Flat Tire Monitor" option?
'05 330ci
[IMG][/IMG]
Old 12-04-2012, 05:00 PM   #8
WDE46
My Ride: '13 128i, '04 330Ci
Don't get runflats unless you have TPMS. You need that to tell you when you have a flat because with runflats it's harder to tell. They also ride like ****.
Old 12-04-2012, 05:03 PM   #9
bimmernut3
The Michelin that are on the rear have the "RSC" inside a circle, which the owners manual says run flats come with this. If they are run flats on it, can I put 'standard tires' on it when these wear out?
'05 330ci
[IMG][/IMG]
Old 12-04-2012, 05:28 PM   #10
Stinger9
My Ride: '04 330Ci
Many have done that before you. The drawback is the knuckleheads haven't provided for a spare in most cars that come equipped with the RF's.
So they carry a can of inflate-a-tire.
Another reason for me to want to hang onto my car with a dipstick, no RF's, non-electric PS, and no stupid TMPS.
Old 12-04-2012, 05:56 PM   #11
Wolrab
That's exactly what I did on my E60. It has a temporary spare, just like your car. And FTM (not TPMS) which works fine on both kinds of tire. I've been happy with this arrangement for the last 130,000 miles.
Old 12-04-2012, 06:00 PM   #12
MercForHire
My Ride: M235i 6MT
run flats are the best thing since DSC. Haters with normal tires are just too poor to afford it like those poor ASC users.
Old 12-04-2012, 06:45 PM   #13
eneka
My Ride: 2003 325i
we had michelin PAX runflat tires (the same system Bugatti uses) on our odyssey and weren't too happy when it was going to cost us $2k to replace all 4 tires that were worn by 50k miles. Not to mention only certified honda dealers were able to work on them.
eneka is offline   Reply With Quote
Old 12-04-2012, 08:10 PM   #14
Stinger9
My Ride: '04 330Ci
Oh, Honda, that economical car?
Old 12-04-2012, 08:15 PM   #15
Zell
Zell's Avatar
My Ride: so turbo wow
I remember reading somewhere that some came with RFTs later on as an option or something?
Old 12-04-2012, 08:44 PM   #16
Stinger9
My Ride: '04 330Ci
Could be. Would be interesting to see a source for that.
But regardless, the e46 body would not have been retooled for this, so there would still be a deep tire well to be able to convert to storage for a spare.
Old 12-04-2012, 08:45 PM   #17
e4603
My Ride: #3 bus
My 03 330xi with sport package had the optional Goodyear run-flats plus spare tire. I went thru 2 sets of Goodyear, which worked fine but are not longer available. I'm currently running Michelin Pilot Sport A/S Plus. I had some balance/pull issues with the previous set of Conti DWS.
e4603 is offline   Reply With Quote
Old 12-04-2012, 08:56 PM   #18
Bemwe_03i
My Ride: 2003.5 E46 M3 smg IR
no, even the m3's with tpms didnt come with runflats but with a sealant and compressor in the trunk in place for a spare tire.
You can feel it on the steering when your have a flat tire if you have run on flat tires. It will pull to one side well i guess i had a flat on the front once and it pulled hard. Cant tell u much about a rear...
Bemwe_03i is offline   Reply With Quote
Old 12-04-2012, 09:02 PM   #19
Zell
Zell's Avatar
I had a flat on my RFTs (no TPMS, PO decided to put them on?) and had absolutely no idea. I checked my pressure weekly and the week I went to do my oil change, the guy told me my rear tire had no pressure at all. It's almost impossible to tell.
Glad I ditched those - the ride quality is so much better without them. BMW now designs their suspension around RFTs, so that shouldn't be an issue on newer cars.
Old 12-04-2012, 09:10 PM   #20
Stinger9
My Ride: '04 330Ci
Most of the car tests I read indicate that the professionals are not liking RF's.
BMW can design around them, but not eradicate the effect of lousy riding and handling tires.
I'll do my best to avoid them.
