Old 12-04-2012, 06:46 PM   #1
btownbuckeye46
My Ride: 2001 BMW 330i
Airbag light e46
hello, i recently had my my front passenger window regulator go out and i had to take the door apart to fix it. me being dumb i forgot to unplug the battery before i took the door apart now im stuck with the airbag light on. i tried unplugging the battery didnt work. SO my question is how do i clear the airbag light?
btownbuckeye46 is offline   Reply With Quote
Old 12-04-2012, 06:47 PM   #2
tks
My Ride: slower than yours
take out cluster and find the airbag bulb
WTB:: Natural Brown Sedan Full Interior
tks is online now   Reply With Quote
Old 12-04-2012, 07:11 PM   #3
taveet330i
My Ride: Jet Black 2002 330i
Take it to your local BMW dealership and have them reset the OBD II or I think even autozone will clear them out
Dedication
_______________
Dedication
2002 Jet Black 330i|ZPP|Hellbeige interior|Carbon Fiber Interior Trim|Alzor 703 CSL Reps|Custom Flowmaster Catback Exhaust|LED Halo Rings|Black ECSTuning Kidney Grilles|Eonon D5150|
taveet330i is offline   Reply With Quote
Old 12-04-2012, 07:14 PM   #4
MercForHire
My Ride: M235i 6MT
use an INPA cable and software.
A bit hard to install, computer geeks only
Old 12-04-2012, 07:15 PM   #5
///MPR77
My Ride: 02 ///M3 Tri-Ped
Originally Posted by ruskisky View Post
DON'T take out cluster and find the airbag bulb
Fixed.
Dedication
Autozone will not be equipped to reset that. Go to an Indy, or find someone local who has PA soft.
Old 12-04-2012, 07:52 PM   #6
btownbuckeye46
Well I have had advanced auto clear my service engine light after I replaced my fuel pump recently I just assumed since it was an airbag light that they wouldn't clear because of any liability I'll go by Tomo and see but the closest bmw dealer is a good hour drive away
Old 12-04-2012, 08:02 PM   #7
MercForHire
My Ride: M235i 6MT
listen to me, get INPA cable
Old 12-04-2012, 08:41 PM   #8
btownbuckeye46
What exactly is that!? I'm pretty computer savvy as my dad is an electric engineer and my brother is a computer programming major I just have no clue when it comes to ECUs in cars
Old 12-04-2012, 08:46 PM   #9
MercForHire
My Ride: M235i 6MT
http://forum.e46fanatics.com/showthread.php?t=770882
Old 12-04-2012, 09:03 PM   #10
btownbuckeye46
That looks like mandarin to me haha
Old 12-23-2012, 04:44 PM   #11
bmwmp
My Ride: 99 328 i
ok dumb question, but after a "crash" after you redo the battery connects and such, after i reset the airbag light it should fire back up correct?
if not what else do i need to replace or repair?
bmwmp is offline   Reply With Quote
Old 12-23-2012, 05:36 PM   #12
Nerdy46
My Ride: 328i
What do you mean fire back up?? like have the car start???
Daily: 1999 328i (202k)- Sport and winter package, 5speed, Jet Black, hellbeige, e60 Short throw, cross drilled rotors, koni, H&R, ASA AR1, Vibrant stealth, basslink
Track: 1995 Mustang GT (230k)- 306ci, 5 speed, MGW shifter, Trickflow Heads, Trickflow intake, street cam, shaved and tucked engine bay, slammed, 1 3/4'' long tubes, tuned with moates.
On the Water: 7' Boneyard Retro Quad Fish
Nerdy46 is offline   Reply With Quote
Old 12-23-2012, 05:57 PM   #13
jfoj
My Ride: 330CiC, M5, X5, E93
www.xcar360.com $32 for BMW Scanner 1.4.0, much easier than INPA and does other things INPA does not.
Old 12-23-2012, 06:03 PM   #14
bmwmp
My Ride: 99 328 i
yes sorry for the crude terminology. after a crash even a minor one, i know and understand the whole battery disable thing, but after that is there other "fail safes" to deter the starting of the car?
Old 12-23-2012, 06:10 PM   #15
jfoj
If the front airbags deploy, then the seat belt pyro tensioner(s) and pyro battery cable should blow.
Once battery cable is repaired the car should start and run, however, the airbag controller may need to be reset and have the crash data info cleared as well as the deployed airbags replaced.
Old 12-23-2012, 06:29 PM   #16
bmwmp
My Ride: 99 328 i
ok cool i appreciate all the help, any idea where to send the box to and approximately how much to wipe it?
the seat belt charges didnt go off just the pass front door by the pull bar and the pass side curtain at the top but neither deployed even halfway, they popped enough to come out, but didnt deploy as supposed to.
Old 12-23-2012, 07:38 PM   #17
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Scan it with a software that can read the specific SRS codes. Let us know what shows up.
Old 01-13-2013, 02:59 PM   #18
bmwmp
My Ride: 99 328 i
ok sorry it took so long to get back to you guys about this, i used the b800 tool and it read as follows for the codes: 02 08 03 01 09 od oe
now, i read a pdf on what the codes mean and it is registering the pass head airbag, pass front door bag, says circuit closed 2 times and malfunction x2 and pass seat tensioner. so where do i send the controller to have it reset? and do i have to replace these after i removed the bags in order for it to start? it will crank but wont start.i tried to reset the obd2 codes, they wont reset and the srs codes will not reset either. so what now? i refuse to give up on this car, it will be fixed.
