Old 12-04-2012, 10:39 PM   #1
s_israr
My Ride: E46 M3
California M3 survival in Chicago's winter
Hey,
Recently moved to Chicago with my E46 M3. Got my oil change at an indie BMW repair shop. As I was leaving, the owner of the shop recommended me to have the coolant/antifreeze ratio changed because the harsh winter could freeze the coolant I have in the car now. He recommended this because I just moved from California. Does this sound accurate?
I was quoted around $190 for the job, which seems a little high, but it was $100 for the oil change (which is a relatively fair price).
Any tips/recommendations to prepare my car for the snow would be appreciated
Cheers!
s_israr is offline   Reply With Quote
Old 12-04-2012, 10:49 PM   #2
Zell
Zell's Avatar
My Ride: so turbo wow
Depends on what the current ratio of antifreeze is in your car right now. A 50/50 mix is how almost everyone does it, and I'd be surprised if your car didn't have that ratio. 50/50 mix is good 'til -40F, and a 33/67 is good 'til 0F. Chances are it's a good time to replace your coolant anyway. I would just DIY it, it's a very easy process.
Other good tips/ideas:
- Get Blizzaks for your snow tires. Ain't nothin' better. If you don't wanna get different tires, go with Continenal ExtremeContact DWS. They're still great in the snow. Not as good as a snow tire, but hands-down the best all-season out there.
-Edit: Stick with BMW 10w60, it's the oil recommended for your M3. Good to -20F
- Get good windshield wipers. Bosch Icons or BMW's bracketless design are excellent year-round
- Ice scraper
- Textile snow chains for if you get stuck: http://www.ecstuning.com/News/ISSE_T...SnowChains_VW/
- RainX or AquaPel your windows. It will help ice slide off more easily
- Get your battery tested at an auto parts store to make sure it is still in good condition
That's really all there is to it!
Old 12-04-2012, 10:51 PM   #3
Grande D
My Ride: E36 M3
He has an E46 M3. 5w30 is a horrible idea.
Get snow tires. If you think it'll snow heavily do not buy the DWS. Matter of fact just do not buy the DWS period.
It will change your life!
Old 12-04-2012, 10:55 PM   #4
328ci906
My Ride: 2003 M3
Solid advice except...
Originally Posted by Zell View Post
- BMW LL-01 5w30 is good
^Stick to 10W-60 for the S54. 5W-30 is fine for non-M's.
-2000 E46 328i
-2006 E60 M5
328ci906 is offline   Reply With Quote
Old 12-04-2012, 11:12 PM   #5
Zell
Zell's Avatar
Sorry, forgot about that.
Old 12-04-2012, 11:30 PM   #6
tcphoto
My Ride: E92 335 MT Coupe
I don't know about the adjustments between California and Chicago, but after living there for over four years I would store the M3, buy a DD, cab it or use public transportation.
tcphoto is offline   Reply With Quote
Old 12-05-2012, 10:20 AM   #7
jsfbmw
My Ride: 06 330Ci ZHP
+1 great advice
jsfbmw is offline   Reply With Quote
Old 12-05-2012, 10:26 AM   #8
GSherbs
My Ride: 2002 330 xi
+1
And, welcome to Chicago!
GSherbs is offline   Reply With Quote
Old 12-05-2012, 10:31 AM   #9
T R E
My Ride: 2000 328ci
what year M? storing for winter is good idea. if not, get a winter wheel set.
2000-328-Ci (Sold after 10 years and 40k miles)
T R E is offline   Reply With Quote
Old 12-05-2012, 10:37 AM   #10
sammk
My Ride: Bone-stock E92
+1 on the winter wheels. And I'm not too sure about the coolant because it's difficult to tell what was put into the car. I would guess it's 50/50 if it's as-built from the factory, possibly different if you ever had a shop in California change it. Wouldn't be a bad idea to change it, $190 seems reasonable for a shop, but still steep. DIY..?
Also - for sure, purge your windshield washer fluid and fill with the good stuff. I can almost guarantee what you have in there will freeze and possibly damage the seals, windshield washer tank or solenoid. Don't ask me how I know...
E92 convert. BMW Fanatic.
sammk is offline   Reply With Quote
Old 12-05-2012, 05:29 PM   #11
//Maxwelljuppercut
My Ride: e46
go to any parts store and buy a hydrometer (antifreeze tester) for like 6 dollars and you will know for sure if your good or not.
//Maxwelljuppercut is offline   Reply With Quote
Old 12-06-2012, 06:22 PM   #12
s_israr
My Ride: E46 M3
Hey,
@T R E - She's a 2006 ZCP, Carbon Black
Thanks to everyone for the feedback, looking into all of this! I'm definitely going to be using more public transportation when it starts to snow, just wanted suggestions on how to keep the car from malfunctioning when I do drive it in freezing temperatures. Weather has been relatively moderate so far, thank GOD.
Initially, I was going to sell my car for an AWD (possibly an 335xi)... Later, people on this forum helped bring me to my senses lol
Happy Holidays y'all, cheers!
Old 12-06-2012, 06:57 PM   #13
jfoj
My Ride: 330CiC, M5, X5, E93
Nothing can survive the Chicago Winters, salt, ice & potholes, not to mention the people that cannot control their car and run into you!!!
Good luck, store it for the Winter.
Old 12-07-2012, 10:53 AM   #14
sunsetcoast
My Ride: '99 323i & '00 323iT
This is why we have a winter car. Intersections are bad. So are uncleared interstates with drivers who insist on driving as if it is 70F and sunny.
sunsetcoast is offline   Reply With Quote
Old 12-07-2012, 05:57 PM   #15
//Maxwelljuppercut
My Ride: e46
whats worse than that is the idiots that are in the fast lane of the expressway going 15 mph when everyone else is going 50. then they get mad when they get rear ended. if you or your car cant handle driving in the snow then dont. of course you have to slow down when theres snow, but there is a point when it becomes dangerous to be going that slowly. i drive the chicago expressways everyday and i can tell you that when the first snow of the year comes dont expect to be anywhere, its not gonna happen. 3 hours to go 20 miles no joke. last year i counted 11 cars in ditches and into dividers on a 30 mile drive home.
Old 12-07-2012, 06:00 PM   #16
Zell
Zell's Avatar
