///M3 Forum
The BMW E46 ///M3 is the M version E46 and puts out an amazing 333 HP and 262 lb-ft of torque at stock specs! There are an amazing amount of modifications for both the coupe and convertible models so read up and get started modifying your cars today! |
#1 |
shuddering when coming down the gears
my m3 e46 smg 2 shudders when its changing down the gears ?????
#2 |
When is the last time you did the SMG reset? (above 40mph, put the car in neutral and hold both paddle shifters for approx 2-5 seconds)
At all speeds? At high speed? At low speed? All downshifts experience the shudder? Anything done to the car recently?
"! First rule of Italian driving, that which is in your mirror is not important !"
#3 |
Seriously not enough info. But try the reset.
![]() -2003 M3 Vert -1967 Mini Cooper |
#4 |
Modded ///Member
Explain in more detail.
![]() ** Too much for a signature ** Instagram @ j_cerna |
#5 |
I think he means when he's approaching a red light or stop sign applying the breaks when his car downshifts it lightly shudders, mine does that usually from 3rd to 2nd
![]() Carbon Black Metallic SMG II Verttttt VCSL Front Bumper VCSL 1 Piece Splitter VIS GTR Hood 6K Angel Eyes VMR VB3 19's KW V2 coilovers |
#6 |
It's when slowing down for stop sign car judders through every gear til it stops and a light judder when taking of again ?would it just need smg reset?
#7 |
Fully Deeked Out
Just do the reset and see if it fixes it. It literally takes a few seconds to do so there's no reason not to try it.
#8 |
If that fails is it a new clutch ?
Thanks for all your help people much appreciated |
#9 |
It could be a warped flywheel, it could be numerous things.
