Old 12-15-2012, 11:55 PM   #21
Viktimize
My Ride: 2002 325i,2003 330ci
Originally Posted by lcoleman View Post
Fasle. If the switch never contacts the "crank" position, there will be no signal sent to the starter. Cranking = working ign switch...not to say they can't fail intermittently.
Might be true in some cases. My ignition switch failed and it would crank till the battery died, just wouldn't start.
Viktimize is offline   Reply With Quote
Old 12-16-2012, 03:11 PM   #22
UnoriginalUsername
My Ride: 2003 320i
OK, I got a chance to check the voltage going to the starter(and I tell you, it was a really tight squeeze even with the intake boots off), ~10.5V. Onboard, voltmeter registers ign at ON position as 11.3V(sitting on the driveway for a couple of days).
Even if it registers about 10.5, it should still be enough to crank right?
UnoriginalUsername is offline   Reply With Quote
Old 12-16-2012, 03:53 PM   #23
lcoleman
My Ride: '79 Massey Ferguson
It should be doing something. Sounds like it's time to replace the starter. I recommend a new unit (not a parts store refurb) unless you fancy doing the job twice.
Old 12-17-2012, 11:34 AM   #24
UnoriginalUsername
My Ride: 2003 320i
I was afraid of that. Oh well, you gotta do what you gotta do. Do you happen to know the part #? I see the solenoid and starter motor have different ones
http://realoem.com/bmw/showparts.do?...92&hg=12&fg=25
Old 12-17-2012, 03:33 PM   #25
lcoleman
I just noticed you have a 320i. Plug your VIN into realOEM and see what p/n it spits out. On the 6cyl cars you have to replace the solenoid and starter as a unit, perhaps you could get by with just the solenoid itself?
Old 12-17-2012, 03:53 PM   #26
UnoriginalUsername
My Ride: 2003 320i
All good. I looked at the bosch site and searched for the part number by year and model.
SR0448N
I just ordered a new one and try to do it or have someone help me. I'll keep you posted.
Thanks again!
EDIT: by order, I meant ordered both solenoid and motor. I might as well replace it with a new one
