Old 12-06-2012, 03:31 PM   #1
diM3tri
My Ride: 330ci + stg2 Scoobie
Smoke from engine.. Fire smell.. Help!
I drove my car 2 blocks, parked it, then got out popped the hood and smoke was coming from the valve cover and that area. Smoke was coming out mostly from the back of the engine. I also smelled a strong burning oil/fire smell.. I then heard a crackle from the engine in the same area and a lot of heat was coming from it.. This got my really worried! I originally thought it was my valve cover gasket but this problem seems way worse.. I let it sit for about 10 minutes and the smoke is going away but still a little there. Any ideas what could be wrong?! I included some pics of where the smoke was coming from.. My car has 133k miles. I just did an oil change less then 500 miles ago and I checked my dipstick.. I have enough oil!
ID:	481174   Click image for larger version
ID:	481175   Click image for larger version
Current Cars:
'99 Big Turbo B5 A4 (the red one) ^^^
'13 GLI
'91 Ford F150 v8 5spd
Previous Cars:
'05 stg 2 scoobie wagon
'82 VW rabbit vert
'01 330ci
'84 633csi
diM3tri is offline   Reply With Quote
Old 12-06-2012, 03:33 PM   #2
diM3tri
Just checked.. My coolant light is on as well..
Current Cars:
'13 GLI
Previous Cars:
'82 VW rabbit vert
'01 330ci
'84 633csi
Old 12-06-2012, 03:47 PM   #3
diM3tri
Anyone??
Current Cars:
'13 GLI
Previous Cars:
'82 VW rabbit vert
'01 330ci
'84 633csi
Old 12-06-2012, 04:08 PM   #4
trj
My Ride: 325Ci
Symptoms point to a VCG leak, but the crackle and Coolant light being ON would worry me.
Check if you have enough coolant in the tank.
Get cracking with checking for coolant leaks.
Check for oil in coolant and coolant in oil.
Hopefully it was just an air pocket or a small leak.
I get the oil light ON all the time after I drive about 10 miles, not because I am running low on oil, but because of faulty CCV. Also have a small leak on VCG.
Old 12-06-2012, 04:10 PM   #5
ElrichMeister
My Ride: 06 325Ci M56
Check coolant level if the coolant light came on, if its still hot wait for the car to cool down before you check. Check to see if you have anything dripping under that car.
ElrichMeister is offline   Reply With Quote
Old 12-06-2012, 11:39 PM   #6
DBrown
My Ride: BMW 325 Ci
I got those smells when vcg was leaking a lot. Could get that if vcg is done improperly too. Do vcg, as for the coolant not sure. Small leak somewhere or air pocket. Look under your expansion tank for leaks, that's where mine leaked. Auto trans thermostat was cracked from age.
2001 325 Ci
DBrown is offline   Reply With Quote
Old 12-07-2012, 11:23 AM   #7
diM3tri
so you guys just thinks its the VCG? because to me it seems way worse.. ill bring it to a shop and see what they say.
Current Cars:
'13 GLI
Previous Cars:
'82 VW rabbit vert
'01 330ci
'84 633csi
Old 12-07-2012, 11:27 AM   #8
Treburkulosis
My Ride: BMW
First things first get that battery cable disconnected until you figure it out. If it is electrical your car could burn to the ground.
Treburkulosis is offline   Reply With Quote
Old 12-07-2012, 11:29 AM   #9
diM3tri
Good point.. i dont think it is electrical because smoke is coming out of the valve cover are in the engine not anywhere near the lights/interior.. hopefully its not electrical.
Current Cars:
'13 GLI
Previous Cars:
'82 VW rabbit vert
'01 330ci
'84 633csi
Old 12-07-2012, 11:49 AM   #10
peytonracer4
:D
peytonracer4's Avatar
My Ride: '00 328i
You have electrical components on every square foot of your car. Not just things that light up.
Old 12-07-2012, 12:33 PM   #11
diM3tri
Your right. Ill get it checked out soon. Thanks! I hope it's not electrical..
Current Cars:
'13 GLI
Previous Cars:
'82 VW rabbit vert
'01 330ci
'84 633csi
Old 12-07-2012, 12:40 PM   #12
Teddy7
My Ride: slides
Yes, I do think it is 100% your valve cover gasket but I would be concerned over the coolant level being low. The crackling is normal, it is often the heat shields or cats cooling off. However, the crackling may also be due to drops of oil hitting the very hot heat shields, thus lots of smoke. Personally cooling system (i.e. finding out where your coolant went) would be priority rather than the smoke.
Teddy7 is offline   Reply With Quote
Old 12-07-2012, 12:49 PM   #13
diM3tri
I will definitely be doing my VCG. The thing about the coolant light is it comes on randomly and goes off at different times. I have full coolant too. I checked it and topped it off a few weeks ago.. There doesn't seem to be a coolant problem and my engine temp gauge never shows it getting too hot.. What I'm thinking is the coolant light has to do with my heating system because I'm getting heat randomly. It doesn't come on all the time. I'm also not throwing any coded web I plug in my obd2 scanner.. I'm gonna start with my VCG then while it's in the shop ill check out the cooling system as well
Current Cars:
'13 GLI
Previous Cars:
'82 VW rabbit vert
'01 330ci
'84 633csi
Old 12-07-2012, 12:57 PM   #14
peytonracer4
:D
My Ride: '00 328i
Sounds like your system isn't bled correctly and there's air in there. If I'm remembering correctly the coolant level sensor is actually partitioned off in the expansion tank and can be subject to air bubbles making it think its low.
That would also explain your intermittent heat situation.
When's the last time your coolant was changed? Maybe a flush and fill would do you good. The key ingredient in these cars is bleeding it correctly though.
I think it's your vcg too. It's somewhat common for bmws to leak oil out onto the headers and it leaves no trace because it burns off.
An oil leak won't cause a smell. Burning oil will. I think that's what you're getting.
Old 12-07-2012, 01:00 PM   #15
FenderGuy05
My Ride: 2002 BMW 325i
If your getting intermittant heat, you may need to bleed the system.
I believe an air pocket could cause an issue with the sensor tripping too...not too sure.
FenderGuy05 is offline   Reply With Quote
Old 12-07-2012, 01:05 PM   #16
diM3tri
I bought the car about 4 months ago and they said they changed all the fluids.. Not sure if that includes coolant or if they did it correctly.. Ill bleed the system and do VCG. Hopefully that will help.
Current Cars:
'13 GLI
Previous Cars:
'82 VW rabbit vert
'01 330ci
'84 633csi
Old 12-07-2012, 01:09 PM   #17
pleiades
My Ride: M52TU
This is from left-field .... See if you can look down under/around the exhaust manifold and header pipes and spot anything that looks like an artifact of burnt plastic. Check the areas on/around the firewall for missing or cracked plastic parts. These cars are getting older and the splashguard (firewall) black plastic cowling can age, crack, fall off, and melt on the exhaust .....
pleiades is offline   Reply With Quote
Old 12-07-2012, 01:09 PM   #18
Teddy7
My Ride: slides
I second the advice above, sounds like air is in your system and is in need of proper bleeding.
Old 12-07-2012, 01:16 PM   #19
diM3tri
When installing angel eyes I accidentally cracked one of the clips for my corner lights and it fell to the bottom of the engine but I didn't think this could burn..
Current Cars:
'13 GLI
Previous Cars:
'82 VW rabbit vert
'01 330ci
'84 633csi
